Mini Devastator 21" Version - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 84Likes
post #31 of 120 Old 01-30-2020, 05:47 PM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
Originally Posted by johnson636 View Post
I have no idea where the go
Oh, I forgot to give you your credit for the Pipe insulation idea...That is sweet
Ya know, hatch bracing is the one pic I didn’t take from my dev build. I’ll have to remedy that on the next one.
Here’s the general idea, shorter one goes between the two verticals. “H” for hatch, lol.
Pipe insulation was a super simple yet effective solution. I will continue to use it in the future. Glad you liked/implemented it.
EDIT: Another pic that kinda shows hatch bracing:
@Red Five , got a pic?
Chris
johnson636 and BP1Fanatic like this.
a77cj7 is online now
post #32 of 120 Old 01-30-2020, 05:59 PM - Thread Starter
johnson636's Avatar
Quoted: 1715 Post(s)
Liked: 1209
Chris
Like it, I love it Don't be surprised if you start seeing more builds using pipe insulation. I used to use zip-ties to hold the wire in place, but your method is way more nicer
a77cj7 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #33 of 120 Old 02-02-2020, 03:00 PM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
So my next build happened way sooner than expected, lol.
Hatch bracing:
Your version only has one horizontal, but same idea.
Chris
post #34 of 120 Old 02-18-2020, 08:26 AM - Thread Starter
johnson636's Avatar
Liked: 1209
Back at it again. I haven't cut the bracing yet" doing that once the box is glued together. I want to see where I went wrong last time so I don't repeat the same error.
post #35 of 120 Old 02-18-2020, 09:17 AM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Question
Hatch bracing:
Chris
Why not a cross or an x brace on the hatch?
You guys are better than me. I would have made the front panel removable. I'm lazy like that.
ID:	2686732   Click image for larger version
Name:	from Handset_20120204152426_55.jpg
ID:	2686734   Click image for larger version
Name:	from Handset_20120204150434_56.jpg
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #36 of 120 Old 02-18-2020, 10:30 AM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
Easier to make a rear hatch than dealing with bracing for the front. Plus, no visible screws.
X bracing would work fine, The square or H is easier to install IMO.
Chris
jujuman200 likes this.
post #37 of 120 Old 02-18-2020, 01:34 PM - Thread Starter
johnson636's Avatar
Liked: 1209
I'm not sure exactly what the hatch brace is reinforcing I can't make it out from the pics. At the moment, I don't have the hatch brace installed and I don't hear any ugly sounds from the enclosure. Now my room, that a totally different story. Windows, doors, joist, PJ all scream uncle
post #38 of 120 Old 02-18-2020, 01:42 PM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
Its to prevent the hatch panel from resonating.
Thats the reasoning behind all the cabinet bracing, preventing panel resonances, not reinforcement per se.
Chris
post #39 of 120 Old 02-18-2020, 01:48 PM
Red Five's Avatar
Quoted: 1275 Post(s)
Liked: 1193
The 10" rule is a good rule of thumb to follow for bracing. Once you get beyond 10" from a brace or a corner the panels will start to resonate more than they should. The Devastators do not have half double thick baffles/manifolds, part of the bracing is reinforcement for the baffle wall, but most of it is making sure panels do not resonate in case the 130db+ output is fully utilized
jujuman200 and BP1Fanatic like this.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #40 of 120 Old 02-18-2020, 01:56 PM - Thread Starter
johnson636's Avatar
Liked: 1209
I'm aware of how the rest of the bracing prevents panel resonance, just not sure what the hatch brace is wedged against once installed. Anyhoot, my cab isn't resonating at the moment. At least I can't tell. That may change once I install the 21ds115
post #41 of 120 Old 02-18-2020, 02:01 PM
jujuman200's Avatar
Quoted: 407 Post(s)
Liked: 422
I'm aware of how the rest of the bracing prevents panel resonance, just not sure what the hatch brace is wedged against once installed. Anyhoot, my cab isn't resonating. At least I can't tell.
It's not wedges against anything... the hatch becomes STIFFER and thus less prone to resonance. The other way to fight resonances is to add MASS to the hatch....
Juju
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #42 of 120 Old 02-18-2020, 02:07 PM - Thread Starter
johnson636's Avatar
Liked: 1209
Got it. I'll add it once I install the 21ds115.
post #43 of 120 Old 02-18-2020, 04:20 PM
jujuman200's Avatar
Quoted: 407 Post(s)
Liked: 422
And don't forget to add a pillow as well.....
Juju
post #44 of 120 Old 02-18-2020, 04:33 PM - Thread Starter
johnson636's Avatar
Liked: 1209
A Pillow?
post #45 of 120 Old 02-18-2020, 04:57 PM
Red Five's Avatar
Liked: 1193
A Pillow?
Towards the back end of the experimental Quad thread. We have measurements!
This is the way...
post #46 of 120 Old 02-18-2020, 05:00 PM - Thread Starter
johnson636's Avatar
Liked: 1209
Juju
First I've heard of it. I haven't been following that thread.
post #47 of 120 Old 02-19-2020, 01:19 PM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Actually, 2 pillows standing up inside the enclosure!
post #48 of 120 Old 02-19-2020, 01:26 PM - Thread Starter
johnson636's Avatar
Liked: 1209
Has the pillows been used in any of the other builds?
post #49 of 120 Old 02-19-2020, 01:45 PM
jujuman200's Avatar
Quoted: 407 Post(s)
Liked: 422
Yes... I have 2 in my LFE and 1 in my Mini...
Juju
post #50 of 120 Old 02-19-2020, 01:48 PM - Thread Starter
johnson636's Avatar
Liked: 1209
Juju
Pics?
post #51 of 120 Old 02-19-2020, 01:56 PM
jujuman200's Avatar
Quoted: 407 Post(s)
Liked: 422
Pics?
I have them stapled horizontally to the front to back braces....one pillow on the bottom and the other pillow on the mid braces...this is for the LFE.... The Mini has the pillow attached to the hatch behind the driver....
EDIT: https://www.avsforum.com/forum/155-d...l#post59247766
Juju
post #52 of 120 Old 02-19-2020, 04:53 PM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Talking
pics?
Here ya go!
johnson636 likes this.
post #53 of 120 Old 02-19-2020, 04:58 PM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Talking
Here are the measurements between no pillows (red) vs 2 standing pillows (orange).
post #54 of 120 Old 02-19-2020, 05:01 PM - Thread Starter
johnson636's Avatar
Liked: 1209
Here ya go!
Pillows in a ported enclosure...that's a first for me. How do you like the Rockville SPG88? I'm using a set as surrounds I wanted to try the SPGN108, but I was unsure if they would fit into my column.
post #55 of 120 Old 02-19-2020, 05:05 PM - Thread Starter
johnson636's Avatar
Liked: 1209
Looks like it cleans the FR from about 110hz - 200hz
post #56 of 120 Old 02-20-2020, 07:41 AM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Thumbs up
I love them! You can't beat them for $92 a pair. I would like to try a 15" setup with 6 of them pole mounted to their 15" subs.
post #57 of 120 Old 02-20-2020, 07:49 AM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Unhappy
Wow, they are only showing the 12" speaker pole mounted to the 15" sub.
Name:	Screenshot_20200220-104703_Samsung Internet.jpg
post #58 of 120 Old 02-20-2020, 08:23 AM - Thread Starter
johnson636's Avatar
Liked: 1209
I love them!
Thought I was the only one
post #59 of 120 Old 02-20-2020, 08:24 AM - Thread Starter
johnson636's Avatar
Liked: 1209
I'm sure you could piece it together.
post #60 of 120 Old 02-20-2020, 01:00 PM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Talking
4 pairs of 15" two ways plus six 15" subs = $1,579.50!
Name:	Screenshot_20200220-154524_Samsung Internet.jpg
ID:	2687678   Click image for larger version
Name:	Screenshot_20200220-153438_Samsung Internet.jpg
