Mini Devastator 21" Version - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 84Likes
post #91 of 120 Old 04-29-2020, 12:41 PM - Thread Starter
johnson636's Avatar
Quoted: 1756 Post(s)
Liked: 1282
Originally Posted by chadsmith013 View Post
when we getting some titans or 1299s in there?
I'd love to, but I doubt I will be changing the speakers in that room. If I need more output from my lcr, I still have the Monoprice Stage Right 15 inch speakers They are damn loud!
BP1Fanatic and chadsmith013 like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #92 of 120 Old 04-29-2020, 12:43 PM - Thread Starter
johnson636's Avatar
Liked: 1282
Originally Posted by jujuman200 View Post
So you're suggesting replacing the dust cap? That could work, but I've never done that before. I'll investigate this further.
post #93 of 120 Old 04-29-2020, 01:03 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
Being that the dustcap is such a hard dome, I would not risk damaging the cone during removal and it would be a PITA..... I think that covering it would be a better solution. It will alter the T/S slightly due to more mass but not enough to actually hear. IMO, a ring around the dustcap looks much better than a big dent...
Juju
johnson636 likes this.
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #94 of 120 Old 04-29-2020, 04:05 PM - Thread Starter
johnson636's Avatar
Liked: 1282
Second one as beautiful as the first one
post #95 of 120 Old 04-29-2020, 05:02 PM
Audiophile75's Avatar
Quoted: 280 Post(s)
Liked: 277
To repair all my dented dust cap I used a very small drill and I drill in the center A SMALL HOLE that I can stick a small piece of metal through and then push out from the inside.
It’s time consuming and tedious but if done well you won’t be able to tell it was even dented.
Then to fix the hole you can use a small amount of hot glue to fill the hole or a small piece of clear tape that is carefully cut in a small circle. Or just slap a sticker over the hole....lol
chadsmith013 and sigpig like this.
Audiophile75 is online now
post #96 of 120 Old 05-01-2020, 08:01 AM - Thread Starter
johnson636's Avatar
Liked: 1282
We're good to go I forgot to put the pillows in while I had her open
Red Five likes this.
post #97 of 120 Old 05-01-2020, 08:06 AM
a77cj7's Avatar
Quoted: 1018 Post(s)
Liked: 1070
Nice upgrade.
Any chance you can take a close-mic measurement for me?
Chris
a77cj7 is online now
post #98 of 120 Old 05-01-2020, 08:38 AM - Thread Starter
johnson636's Avatar
Liked: 1282
Originally Posted by a77cj7 View Post
Nice upgrade.
Chris
Sure. I'm not home now, but I can have that measurement for by tomorrow. How close are we talking? Would you like the measurement of the one with the pillows or without?
post #99 of 120 Old 05-01-2020, 09:06 AM
a77cj7's Avatar
Liked: 1070
Awesome, thanks.
Mic 3” from port board, like so:
Eq and filters off.
Without pillows is best for my current project, working on rear chamber resonance modeling.
A measurement with pillow would be cool too, we haven’t seen the difference in a 40” cab yet. Its significant in the 48” and 60” cabs.
I’ll do a model overlay as well, see how close this one is.
I’ll pm you my email address.
Chris
post #100 of 120 Old 05-02-2020, 05:28 PM - Thread Starter
johnson636's Avatar
Liked: 1282
Mini DEV 21 Close Mic Without Pillow
Mini DEV 21 Close Mic With Pillow
It appears the pillow removes the big dip at 157Hz
jujuman200 and Red Five like this.
post #101 of 120 Old 05-02-2020, 06:00 PM
BP1Fanatic's Avatar
Quoted: 432 Post(s)
Liked: 406
How does the no pillows and pillows graphs look with 80, 100, and 120hz lowpass filters?
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is online now
post #102 of 120 Old 05-02-2020, 06:12 PM - Thread Starter
johnson636's Avatar
Liked: 1282
I can post those measurements tomorrow. The posted graphs are without Audyssey, eq, HPF and LPF.
post #103 of 120 Old 05-02-2020, 06:14 PM - Thread Starter
johnson636's Avatar
Liked: 1282
@Red Five Do my measurements with the pillow line up with your pillow test?
post #104 of 120 Old 05-02-2020, 06:41 PM
Red Five's Avatar
Quoted: 1328 Post(s)
Liked: 1245
@a77cj7
He has been doing the research on this topic. Based on graphs I have seen the response is the expected outcome. It does not look like the Mini really suffers from near band standing waves. That must occur somewhere over the 40" mark.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #105 of 120 Old 05-02-2020, 08:23 PM
a77cj7's Avatar
Liked: 1070
Thanks for taking the close-mics.
Here’s the two overlaid with the model:
It looks like much like the other rear chamber damping tests.
Here’s the quad, a 48” cab:
Alpha, a 60” cab:
As you can see, the taller the cabinet, the lower the rear chamber resonance moves.
For a 40” cab like your mini 21, the resonance is far enough out of the standard pass-band with an 80hz lpf that its not really an issue. It appears to start making a difference around 135hz.
However, for the minimal cost and effort required to add a pillow, I’d still suggest adding one while building.
Chris
post #106 of 120 Old 05-03-2020, 03:15 AM - Thread Starter
johnson636's Avatar
Liked: 1282
I'll post a measurement of each at my MLP. I know it will be a measurement of my room, but iirc, the Mini with the pillow doesn't have a nasty dip a 70Hz.
post #107 of 120 Old 05-03-2020, 10:30 AM - Thread Starter
johnson636's Avatar
Liked: 1282
Following Mini Dev measurements are taken at my MLP with no eq, no filters at all, and no audyssey:
And for giggles and grins. Mini DEV 21 Pillow (Red) and Ported 24 (Orange)
BP1Fanatic and Red Five like this.
post #108 of 120 Old 05-03-2020, 12:35 PM
Craig S King's Avatar
Quoted: 468 Post(s)
Liked: 572
Any major differences between using the B&C DS21 and the 21SW115 ?
Craig S King is offline
post #109 of 120 Old 05-03-2020, 04:42 PM - Thread Starter
johnson636's Avatar
Liked: 1282
I believe it has been mentioned the ds115 models a little better than the sw115. In the Dev that is. In this case, probably be best to save yourself some coin and get the ds115.
post #110 of 120 Old 05-03-2020, 07:20 PM
Red Five's Avatar
Liked: 1245
The Mini does not look all that midbass heavy at the MLP from the graph
This is the way...
post #111 of 120 Old 05-04-2020, 04:59 AM - Thread Starter
johnson636's Avatar
Liked: 1282
My front row (MLP) is not very good to bass. The second row However is murder...all the subs are near-field
post #112 of 120 Old 05-04-2020, 08:38 AM
Quoted: 468 Post(s)
Liked: 572
The sw115 was on clearance for $395 over the weekend. Unfortunately it looks like they sold out already though, as the sw115 is no longer available.
post #113 of 120 Old 05-04-2020, 09:01 AM - Thread Starter
johnson636's Avatar
Liked: 1282
What I would have purchased that without hesitation.
BTW, PE looks to have more Open box B&C 21DS115-4. I purchased one last week Currently contemplating purchasing another or a NSW 21. Either will be going into a ported enclosure
post #114 of 120 Old 05-04-2020, 12:11 PM
Quoted: 468 Post(s)
Liked: 572
I know, I'm mad at myself for not buying a pair as soon as I saw them at that price. I woke up this morning excited to buy a set, only to discover they are gone now.
post #115 of 120 Old 05-04-2020, 12:30 PM
BassThatHz's Avatar
Quoted: 4052 Post(s)
Liked: 4571
Looks good.
A bit rough above 120hz but that is to be expected from a high-order box.
One could easily make that flat from 19-120hz with some EQ, or just keep the excessive mid-bass hump for extra chest-kick db's.
BassThatHz is offline
post #116 of 120 Old 05-04-2020, 12:33 PM
a77cj7's Avatar
Liked: 1070
Originally Posted by BassThatHz View Post
Looks good.
From the MLP measurements, looks like the room is already knocking the midbass below flat. Its a good case for the dev’s response curve being a useful in-room.
Chris
post #117 of 120 Old 05-22-2020, 02:46 PM - Thread Starter
johnson636's Avatar
Liked: 1282
Not even sure what I'll do with these
post #118 of 120 Old 05-22-2020, 03:40 PM
Red Five's Avatar
Liked: 1245
Do you have a design in mind? M21V3?!
This is the way...
post #119 of 120 Old 05-22-2020, 04:00 PM - Thread Starter
johnson636's Avatar
Liked: 1282
I really haven't given any thought as to design yet. I had these sitting in my cart for a while and PE sent me a "one day only" 10% discount...No brainer I wanted a NSW6021-6, but 2 LaVoce SAN214.50 will best 1 NSW6021-6. At least that is my thinking. I believe I'm going with at least one ported cab, for simplicity's sake Besides, I don't think my drywall or PJ can take 2 more Devs
post #120 of 120 Old 05-23-2020, 06:55 PM
BP1Fanatic's Avatar
Quoted: 432 Post(s)
Liked: 406
I vote for v3's! Screw the drywall...lol!
