Mini Devastator 21" Version - AVS Forum | Home Theater Discussions And Reviews
 24Likes
  • 7 Post By johnson636
  • 2 Post By johnson636
  • 4 Post By johnson636
  • 3 Post By johnson636
  • 1 Post By Red Five
  • 2 Post By Falonious
  • 1 Post By Trimlock
  • 1 Post By johnson636
  • 2 Post By BP1Fanatic
post #1 of 27 Old 01-11-2020, 07:39 AM - Thread Starter
johnson636's Avatar
Quoted: 1352 Post(s)
Liked: 834
Yes, another one I'm not even sure where/how/who started this Devastator craze Anyway, this will be the first of 2 devastator builds. I'll be using a B&C 21DS115 21 (I nabbed from @Nexgen76 ) for the builds. I really don't know what to expect in terms of "in my room" performance, but below is the sim that Red Five came up with. I won't be closing up the hatch until I actually have the driver in hand. Nexgen76 will be bringing it over along with his 3 GSG devastator flatpacks Enough rambling...off to the lab
Name:	Mini Dev 21 Front shot 91 volt SPL 20H2ndOHPF.jpg
Rcris, Red Five, femi and 4 others like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #2 of 27 Old 01-11-2020, 04:29 PM - Thread Starter
johnson636's Avatar
Liked: 834
Done with the cutlist
My plan was to begin assembly today, but I wasted a ton of time attempting to build a crosscut sled...I'll try again some other time. Can't wait until tomorrow Me and the wife are about to have movie time Fried chicken and tater tots for dinner. Oh, almost forgot the hot sauce
mcallister and Jedi940 like this.
post #3 of 27 Old 01-12-2020, 03:35 AM
mcallister's Avatar
Quoted: 223 Post(s)
Liked: 90
I just picked up 2 eminence 21’s from Ricci and was going to go Devastator route but may not now do too the size and the place I could fit them being very tight. Curious too see your results with the mini version.
mcallister is offline
post #4 of 27 Old 01-12-2020, 07:41 AM - Thread Starter
johnson636's Avatar
Liked: 834
Originally Posted by mcallister View Post
I just picked up 2 eminence 21’s from Ricci and was going to go Devastator route but may not now do too the size and the place I could fit them being very tight. Curious to see your results with the mini version.
I had my eye on those eminence 21's Ricci posted; next thing I know they all were sold. Happy for ya. What size can you fit?
post #5 of 27 Old 01-12-2020, 07:59 AM
mcallister's Avatar
Quoted: 223 Post(s)
Liked: 90
I’ve got roughly 29”5 x 38” footprint. I’m going to be trying to calibrate them with 4 Danley DTS-10’s. Hoping I can make this work.
post #6 of 27 Old 01-12-2020, 08:01 AM
mcallister's Avatar
Quoted: 223 Post(s)
Liked: 90
Forgot to mention, I’m very unhandy so looking at flat packs from GSG or diysoundgroup. Been chatting with EricH about a 21” of the Kuda flat packs coming. I may go with that considering he’s only an hour from me and I can pick them up.
post #7 of 27 Old 01-12-2020, 06:11 PM - Thread Starter
johnson636's Avatar
Liked: 834
Well, I didn't get nearly as far along as I had hoped I ran into a few issues. I'm not sure whose build I referred to in regards to cutting the notch in the driver rail, but as you can see from the photo I cut too close to the end of the rail. I placed a block on the short end of the rail to provide more support. Also, because I didn't have enough area on the top end of the driver rail, I could use a pocket screw. I had to use clamps to hold the rail in place until the glue dries. In regards to fastening the side and top panel, I discovered the panel moved after screwing in the pocket screws. Obviously I had to abandon the pocket screws and use clamps after I realigned everything.
I will resume assembly early tomorrow morning
ID:	2668978   Click image for larger version
ID:	2668980   Click image for larger version
ID:	2668982   Click image for larger version
ID:	2668984   Click image for larger version
ID:	2668988   Click image for larger version
ID:	2668990   Click image for larger version
ID:	2668992   Click image for larger version
ID:	2668994   Click image for larger version
Red Five, mcallister, femi and 1 others like this.
post #8 of 27 Old 01-13-2020, 09:19 AM - Thread Starter
johnson636's Avatar
Liked: 834
Man am I exhausted. I've been up every since 1:45am. Storm came through and woke me up and I couldn't go back to sleep. The thought of tornadoes absolutely freak me out Anyhoot, I decided to spend some time in the lab since I was awake. All that's left is the backside of the box Oh, I got very concerned when it came to installing the baffle assembly. I went through every build in the dev index to get an idea as to how you guys pulled this off. In the end it took a bit of creativeness, but I got it done
Went overboard on the glue
Not sure you guys can see in the photo, but it looks like I was about 1/16" short on the last side panel. I'm not perfect, but such is life I'll look to finish up later...I have to get some sleep.
ID:	2669278   Click image for larger version
ID:	2669280   Click image for larger version
ID:	2669282   Click image for larger version
ID:	2669284   Click image for larger version
ID:	2669288   Click image for larger version
ID:	2669290   Click image for larger version
ID:	2669292   Click image for larger version
ID:	2669294   Click image for larger version
Red Five, Falonious and Jan3 like this.
post #9 of 27 Old 01-13-2020, 09:32 AM
Red Five's Avatar
Quoted: 949 Post(s)
Liked: 760
I updated the Index and added your build thread
johnson636 likes this.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #10 of 27 Old 01-13-2020, 10:16 AM
Falonious's Avatar
Quoted: 108 Post(s)
Liked: 107
Oh crap....Glue!....I knew I forgot something on my build......
johnson636 and jujuman200 like this.
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
T. E. Lawrence
Falonious is offline
post #11 of 27 Old 01-13-2020, 06:17 PM - Thread Starter
johnson636's Avatar
Liked: 834
More progress. Actually, I'm almost done...well at least until I get the driver. I'll hold off on the access hatch until then.
Obviously, I didn't learn my lesson last time.
Gonna have leave here for the day. About to watch my Bayou Bengal play for the National Championship
ID:	2669554   Click image for larger version
ID:	2669556   Click image for larger version
ID:	2669558   Click image for larger version
ID:	2669560   Click image for larger version
post #12 of 27 Old 01-14-2020, 02:35 PM - Thread Starter
johnson636's Avatar
Liked: 834
I can see the finish line my bracing dimensions turned out to be a tab off causing the back panel to not sit flush I'll make sure I dry fit that area on the next one I used a ton of glue, clamps and screws to make sure I had an airtight seal @Red Five I'm a bit confused as to the placement of the hatch bracing. Care to shed a little light on that? Do you see any issues with the bracing around the hatch area as is?
ID:	2669992   Click image for larger version
ID:	2669994   Click image for larger version
ID:	2669996   Click image for larger version
ID:	2669998   Click image for larger version
ID:	2670002   Click image for larger version
ID:	2670004   Click image for larger version
post #13 of 27 Old 01-14-2020, 02:50 PM
Red Five's Avatar
Quoted: 949 Post(s)
Liked: 760
It should look like this.
Name:	Mini Dev 21 back shot.jpg
ID:	2670022   Click image for larger version
Name:	Mini Dev 21 rear angled shot.jpg
post #14 of 27 Old 01-14-2020, 02:59 PM - Thread Starter
johnson636's Avatar
Liked: 834
So I'm good then?
post #15 of 27 Old 01-14-2020, 03:14 PM
Red Five's Avatar
Quoted: 949 Post(s)
Liked: 760
So I'm good then?
If the sub fits through the back you should be good! Some hatch bracing might require tweaks.
post #16 of 27 Old 01-14-2020, 03:28 PM - Thread Starter
johnson636's Avatar
Liked: 834
Jeezus I didn't think about that. Man I hope that sub fits in there
post #17 of 27 Old 01-14-2020, 03:32 PM
Quoted: 489 Post(s)
Liked: 407
I think you are fine even if you have to take a jigsaw and cut out some small curves in those 2x4's.
Trimlock is online now
post #18 of 27 Old 01-14-2020, 03:44 PM - Thread Starter
johnson636's Avatar
Liked: 834
Yeah, that's doable. Hopefully no more boneheaded mistakes are discovered.
post #19 of 27 Old 01-15-2020, 05:58 AM - Thread Starter
johnson636's Avatar
Liked: 834
All that's left is the terminal cup, driver, and hatch installation @Nexgen76 I'm ready whenever you are.
OJ Bartley likes this.
post #20 of 27 Old 01-15-2020, 12:13 PM
BP1Fanatic's Avatar
Quoted: 279 Post(s)
Liked: 253
Can't wait to read your review!
johnson636 and Craig S King like this.
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #21 of 27 Old 01-16-2020, 03:39 PM - Thread Starter
johnson636's Avatar
Liked: 834
@Red Five I've been thinking of a way to utilize The two PA460s I'll have freed up. I want to build mini devs for them, but I don't want to waste the cabs or the space in case I decide to fill the rest of the sub area with mini devs 21. What if I build regular mini devs for the PA460 and when I get the other B&C 21s, I somehow alter the cutout to fit a 21 and use the B&C in the mini dev. Will there be any major issues with using a 21 in a devastator meant for the 18? Or should I just build a mini dev 21 and make the baffle cutout for the PA460? Any issues there? The latter would ensure a cab meant for a 21 when I change over.
post #22 of 27 Old 01-16-2020, 03:49 PM
Red Five's Avatar
Quoted: 949 Post(s)
Liked: 760
Any of the 21" variants will work with the PA460. 18" to 21" can be a problem on the HCR designs. What I would do is cut the 10" radius hole for a 21" and then make an adapter for an 18" to sit over that hole. Easy upgrade later.
post #23 of 27 Old 01-16-2020, 03:51 PM
a77cj7's Avatar
Quoted: 440 Post(s)
Liked: 375
Build mini 21’s and use an adapter ring to mount the PA460. The 21’s are way too much for the original mini, hence why the mini 21 was designed.
EDIT: @Red Five beat me too it.
Chris
a77cj7 is online now
post #24 of 27 Old 01-16-2020, 04:04 PM - Thread Starter
johnson636's Avatar
Liked: 834
Chris
Something like this
post #25 of 27 Old 01-16-2020, 04:13 PM
a77cj7's Avatar
Quoted: 440 Post(s)
Liked: 375
Something like this
Yup. If you have a 21 for mockup, you could install the threaded inserts for the 21, and drill the adapter ring at that pattern. Super easy upgrade in the future.
You should top mount the pa460 on the adapter ring to avoid spacing it back.
Chris
post #26 of 27 Old 01-16-2020, 04:25 PM - Thread Starter
johnson636's Avatar
Liked: 834
Chris
So you're saying cut the baffle for a 21 and then make a 21 to 18 reducer ring? The threaded inserts would make it very easy to change between the two
post #27 of 27 Old 01-16-2020, 04:26 PM
a77cj7's Avatar
Quoted: 440 Post(s)
Liked: 375
Exactly.
Chris
