1299 Design, Build, and Integration - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By johnson636
  • 1 Post By eng-399
  • 1 Post By blister64
  • 1 Post By eng-399
  • 1 Post By Jk7.2
post #1 of 24 Old 01-13-2020, 01:15 PM - Thread Starter
superkyle's Avatar
Quoted: 1029 Post(s)
Liked: 468
Hey guy I am planning on building a pair of 1299 ported towers and using a 1099 as a center. I want to use this thread to help guid others and myself on the build of these speakers as I try to do with my sub builds. I have never built a pair of speakers before only subwoofers so this is uncharted territory for me. I will be asking the community for assistance with getting the port dimensions and over all design. I plan to attempt things I’ve never tried before such as veneering and building grills etc. any and all assistance is welcome! I know several of you own these already and @eng-399 is pretty much a master at the designing of speakers so hopefully I can keep everything documented well enough that the help supplied to me can also help others gain the confidence to build these magnificent speakers!
Always destroying exergy!
superkyle is online now
post #2 of 24 Old 01-13-2020, 01:15 PM - Thread Starter
superkyle's Avatar
Liked: 468
Reserved for build plans
post #3 of 24 Old 01-13-2020, 01:15 PM - Thread Starter
superkyle's Avatar
Liked: 468
Reserved for integration with the devastators
post #4 of 24 Old 01-13-2020, 02:37 PM
johnson636's Avatar
Quoted: 1347 Post(s)
Liked: 831
Looking forward to your build. I assume you will go with a horizontal 1099 center, correct. Not much room between your entertainment center and the bottom of the tv.
superkyle likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 24 Old 01-13-2020, 05:46 PM - Thread Starter
superkyle's Avatar
Liked: 468
Yeah I actually rebuilt my TV console to accommodate the 1099 perfectly and because I bought a new 82” tv also and wanted to drop it down a tad. Here is the new version with the RC64iii in it and the marantz before swapping for the XMC-2 and selling the klipsch. Pardon the progress on the picture as I didn’t have the doors etc or everything back in the room when I took it. I know it’s frowned upon not having the waveguides at the same ear level but with a slight angle I’m sure it will be fine.
post #6 of 24 Old 01-15-2020, 03:24 AM - Thread Starter
superkyle's Avatar
Liked: 468
The wait continues while Erich is verifying stock etc. during this time I am hoping to be able to nail down the cut list and tune of the speakers. I’m not very proficient with winisd as I have only used them for subwoofers. Anyone mind giving me advise on what tune and port length etc people prefer for the 1299s?
post #7 of 24 Old 01-15-2020, 09:13 AM
johnson636's Avatar
Liked: 831
I would say a tune of 30hz or 35hz would be great for these speakers. The port length would depend on the enclosure dimensions you decide to go with.
post #8 of 24 Old 01-15-2020, 10:09 AM - Thread Starter
superkyle's Avatar
Liked: 468
The RF7iiis I’m coming from are +-3 at 32 so 30 would be ideal IMO. Two 12s should be ok there I imagine some 2 10s were close. My only worry is the phase switch of the devestators. @Red Five what frequency does the BMD switch phasing? I should prob keep it above that to ensure no Cancellations. I say that but then realize when running full scale I likely won’t be running BMDs so prob not a huge issue but one to think about none the less
post #9 of 24 Old 01-15-2020, 10:27 AM
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 721
The phase changes are effected primarily by the HPF and LPF. If one transducer type/alignment is running in a given frequency range your probability of phasing issues will be lower. Running something like 1299s in the same range as the Devastators could become more problematic. If you do run into phasing issues I would try different filter slops/frequencies until a positive summation is achieved.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #10 of 24 Old 01-15-2020, 11:20 AM - Thread Starter
superkyle's Avatar
Liked: 468
Thank you for the information. Just recalling from when I was playing around with my rythmik there was a point at which positive summation was possible above a certain frequency while not possible below but reversing caused the opposite result. I can’t remember exactly what that frequency was but I’m thinking it was right at 30hz maybe a tad lower.
post #11 of 24 Old 01-15-2020, 11:37 AM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
That was without the ability to control the HPF though, I assume. I’ve been playing with my multitune ported, and the 16hz tune was pretty easy to integrate by messing with HPF and LPF slopes, as @Red Five stated. I haven’t gotten to the 11hz yet, hopefully tonight.
With your setup, I’d shoot for a 30hz tune, and start with HPF at 40hz. That should avoid the port phase shift, and leave just the crossovers to deal with.
Chris
a77cj7 is online now
post #12 of 24 Old 01-15-2020, 12:09 PM - Thread Starter
superkyle's Avatar
Liked: 468
Chris
No he is right for sure I guess my question is if you go for a 30hz tune with aggressive slopes is that not basically the same as a 35hz tune with a less steep decline?
post #13 of 24 Old 01-15-2020, 12:19 PM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
The port phase shift and the crossover phase shift are separate, unrelated effects. The summation if the two (or more) phase shifts is the determining factor in cancellations.
Steeper slopes can help to mitigate the effects of cancellation just because the content drops off so quickly that you don’t get noticeable loss below crossover frequency.
I prefer to play with slopes, frequencies, and time alignment to completely avoid destructive cancellation.
Staying 10hz or so off port tune helps to take the port shift out of the equation, so you don’t get the rapid slope change of phase shift.
Chris
post #14 of 24 Old 01-15-2020, 01:04 PM - Thread Starter
superkyle's Avatar
Liked: 468
Chris
I see. Thanks for the detailed explanation. I’ll shoot for a 30hz tune with the 1299s then. Maybe if @eng-399 has some free time he can give me a hand with the design as his modeling skills are second to none. With tuning decided now it’s just size and port length etc
post #15 of 24 Old 01-15-2020, 01:06 PM
eng-399's Avatar
Quoted: 2457 Post(s)
Liked: 5115
No problem happy to help. Let take a look at winisd and see what I can come up with.
eng-399 is offline
post #16 of 24 Old 01-15-2020, 01:24 PM - Thread Starter
superkyle's Avatar
Liked: 468
You are incredible thanks a ton!
post #17 of 24 Old 01-16-2020, 03:20 PM
Quoted: 266 Post(s)
Liked: 334
@eng-399 is great, he helped with bouncing a few ideas around and with the design of my 1299 towers. I went with a ~35Hz tune on mine. Here are the dimensions and a link to my thread for the whole discussion and build.
1299 Ported Towers
Baffle- 45" x 14.75" (Included with kit, modified and extended. To be flush trimmed with router)
Top- 14.75" x 17"
Sides- 44.25" x 16.25"
Bottom- 13.25" x 15.5"
Back- 44.25" x 13.25"
Port- 13.25" x 8.25"
Braces- 15.5" x 13.25"
**Port Dimensions**- 2" x 13.25" x 9" Gives the box a tune of roughly 34-35 Hz
Link to Thread
eng-399 likes this.
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva XPA-7 Gen3 | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Three Stereo Integrity HS-24 mkIII's sealed | Sinbosen FP20000Q
YouTube Channel for builds and reviews Life Of Bliss YouTube
blister64 is offline
post #18 of 24 Old 01-17-2020, 03:53 PM
eng-399's Avatar
Liked: 5115
eng-399 is offline
post #19 of 24 Old 01-18-2020, 01:14 PM
Jk7.2's Avatar
Quoted: 1674 Post(s)
Liked: 3016
The most helpful Mike also worked on my 1299 ported towers. This is how they turned out.
Check out my thread for more ideas.
1299 Ported towers
https://r.tapatalk.com/shareLink/top...ink_source=app
Craig S King likes this.
Jk7.2 is online now
post #20 of 24 Old 01-18-2020, 02:34 PM - Thread Starter
superkyle's Avatar
Liked: 468
1299 Ported towers
1299 Ported Towers
Top- 14.75" x 17"
Link to Thread
Sorry for the delay. Not sure why I’m not getting notifications of new post on the thread.
He really is a special member!
Thank you all for all of your guidance! I have certainly been reading over both of your threads in great detail to dive myself an idea of what I want. I really like how you recessed the back it looks great! I plan to veneer mine also but do not have much experience with it so should be interesting to say the least.
post #21 of 24 Old 01-18-2020, 03:24 PM
Jk7.2's Avatar
Liked: 3016
Well the good news is you really can’t go wrong with these speakers. You’ll love them. Heck, I built 2 just to hear them. Because I had always wanted to. And Mike will hook you up with a good plan for sure. I’ll be watching!
Jk7.2 is online now
post #22 of 24 Old 01-18-2020, 04:25 PM - Thread Starter
superkyle's Avatar
Liked: 468
Yeah I’m going into the build blind. I have never had the opportunity to hear them but I have read so many outstanding compliments about the 1099s I figured the 1299s souls match that and some. I loved the rf7iiis but in reality I enjoy being able to say...yeah I built those. Something very satisfying about it for sure. Even if I had to cheat a little and use the design by @Erich H
post #23 of 24 Old 01-18-2020, 08:00 PM
Liked: 0
what will you be running for subs with these, just the devistators
James Scerbo is offline
post #24 of 24 Old 01-18-2020, 08:46 PM - Thread Starter
superkyle's Avatar
Liked: 468
In the immediate future it will be “just” the devistators. I won’t “need” anything more as they are running the eminence NSW 21”. With that said I have plan to build two more minis or possibly micros but what comes next will be determined by the measurements of REW and how well everything sounds together.
