Buttkicker amp died, need a replacement for TC-2000 sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-14-2020, 07:53 PM - Thread Starter
radchad3's Avatar
Hello all!
I have a Buttkicker BKA 1000-4A amp that I have been using in a sonotube sub with a TC sounds 15" TC-2000 since 2006! It is true old school but I really like it and I want to stay with it for the time being. That said, I think my amp may have bit the dust. The standby light turns green but I get no output. Any thoughts? How can I check to see if I am getting output to the sub?
If it truly is dead, any suggestions on what I should get to replace it? I would like to future proof the amp in case I decide to do another DIY project down the road....Devastator or Full Marty.
Here are the specs to the TC sub in case that makes any difference.
https://www.avsforum.com/forum/155-d...000-specs.html
Thank you for the advice!
Chad
radchad3 is offline
post #2 of 9 Old 01-15-2020, 03:21 AM
Liked: 5
It is probably worth checking out what a repair would cost. If else, most people on here use pro amps like crown, behringer, clone amps and so on. They usualy have some fan noise to go with them though.
My 2.1: Minidsp2x4 HD,Hypex UCD400HxR,SI HT-18,HTM-10
HTM 10 build
felix94 is offline
post #3 of 9 Old 01-15-2020, 03:32 AM
Quoted: 130 Post(s)
Liked: 64
The fans are easily replaced for silent ones.
Source: Gaming/HT PC, i7 3770K, 16GB DDR3 2400Mhz, 2x GTX 980Ti SLI, MPC-HCx64 w/ MadVR & SVP frame interpolation
Display: Panasonic VT30 55" Plasma ::: Receiver: Denon AVR-1910
5.1 Speakers: Behringer B215XLs
Subwoofers: 4x SI HT18 D4 - iNuke NU4-6000 w/ silent-fans (1 driver per channel at 2ohm)
Ormy is offline
post #4 of 9 Old 01-15-2020, 07:07 AM - Thread Starter
radchad3's Avatar
Thank you for the replies. I will look into a repair. I may also look new. I am thinking of maybe the NX3000. Would that work for my currently setup? I was thinking 1 channel would work for what I have now, then I could also use it if I decided to go with something from GSG audio in the future.
Thoughts?
Chad
radchad3 is offline
post #5 of 9 Old 01-15-2020, 07:36 AM
buggers's Avatar
Quoted: 47 Post(s)
Liked: 33
I have one of those I use for outdoor movies. With it's very high distortion, when it dies I will throw it out. They would not be worth the cost to repair...
buggers is offline
post #6 of 9 Old 01-15-2020, 08:03 AM - Thread Starter
radchad3's Avatar
I am just learning more about its high distortion and crap output levels compared to spec. Back in the day (2006) it was pretty well regarded but the facts soon became known. I think you are right that getting a new instead of fixing this is likely the route I will go.
Chad
radchad3 is offline
post #7 of 9 Old 01-15-2020, 12:10 PM
noah katz's Avatar
Quoted: 2257 Post(s)
Liked: 828
I'd get an inuke DSP model so you can tailor the response.
Noah
noah katz is offline
post #8 of 9 Old 01-15-2020, 12:34 PM
Samps's Avatar
Quoted: 1250 Post(s)
Liked: 930
Get the 6000dsp if you are planning on adding more sub later. One channel of a 3000 is not enough to get the most out of the bigger drivers.
Samps is online now
post #9 of 9 Old 01-15-2020, 12:46 PM - Thread Starter
radchad3's Avatar
Thank you for the responses.
1. Do I go with or without a DSP model? Or get a miniDSP? I run Macbook only at home, will the NX edit software work with Macs?
2. My currently setup was being pushed by ~900 watts at 4 ohms. The 3000 would be about the same with each channel. Then if I went with a Devastator, I could use the same NX3000 in bridged mode, correct? If I am not doing anymore than 1 sub, do I need the NX6000?
Chad
radchad3 is offline
