1099 redo - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By dorri732
  • 1 Post By Samps
  • 1 Post By Purenv
post #1 of 11 Old 01-16-2020, 08:00 PM - Thread Starter
thisismyname123's Avatar
Quoted: 185 Post(s)
Liked: 77
1099 redo
I built 3 1099s last year for my family room.... horizontal center.
Haven't used them there due to a few reasons.
But anyway they are going behind an AT screen in a to be built dedicated HT.
So I want to redo the center to match the L & R.
Is there an easy way to modify an existing horizontal to a vertical?
I was thinking of doubling the baffle then cutting out the areas in the horizontal baffle to fit. That may change the sounds of it?
Or just build a whole new cabinet I guess
Sent from my Pixel 4 using Tapatalk
thisismyname123 is offline
post #2 of 11 Old 01-17-2020, 04:58 AM
Quoted: 155 Post(s)
Liked: 135
I suspect that if you just put the center on tall stands to get the waveguide height to match the others, you'll never hear the difference.
joker927 and Craig S King like this.
dorri732 is offline
post #3 of 11 Old 01-17-2020, 05:42 AM
Quoted: 247 Post(s)
Liked: 238
Doubling the baffle shouldn't change the sound much at all. The only change in volume will be the addition of the old cutouts, can't amount to much. Seems like your best bet.
Another option would be to try to cut out just the center section and patching in a new piece, would be a lot more work but with a nicer finished look. Kinda like @Jk7.2 's htm-8 towers. https://www.avsforum.com/forum/155-d...l#post57989198
Denon X1300W/DIYSG Fusion 12 LCR/Volt-10 Rears/Micca M-8C Heights
2 @ VBSS End Tables - 2 More VBSS complete!
Epson 2030/DIY 110" AT Screen
Eosone RSF1000 for Enjoying Music
jevchance is offline
post #4 of 11 Old 01-17-2020, 06:17 AM - Thread Starter
Quoted: 185 Post(s)
Liked: 77
Was thinking that.... will probably test that out before I put any effort into it. thanks!
post #5 of 11 Old 01-17-2020, 02:17 PM
joker927's Avatar
Quoted: 80 Post(s)
Liked: 57
I suggest raising it since it's behind a screen. If you don't want to do that then I'd look into taking apart glued wood and cut the center piece out and rotate it 90 degrees and glue back.
Sent from my ONEPLUS A6013 using Tapatalk
joker927 is offline
post #6 of 11 Old 01-17-2020, 03:20 PM
Samps's Avatar
Quoted: 1338 Post(s)
Liked: 1010
Flush trim bit should ride on the internal divider panels and the inside of the top and bottom panel. That would leave you with a nice hole to work with. Then attach blocks inside to attach the new section.
The vertical arrangement is superior to the horizontal so it would be worth the trouble.
Craig S King likes this.
Samps is offline
post #7 of 11 Old 01-18-2020, 01:31 PM
tarponater's Avatar
Quoted: 228 Post(s)
Liked: 810
Carefully plunge cut into the center section along the side so you cut through flush with the side. Grind the teeth off the bottom half of the blade and use that to cut flush with the sides and divider boards. Glue some strips of 1/2" stock to the inside of the chamber flush with the back of the baffle. Now just rotate the center section 90 deg and glue it back to the 1/2" strips. I believe the internal dimensions of each section is 11"x11", if so, this will work.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii sealed, Dual SAN 214.5 Devastators, Dual Crowson actuators, NU12000, NX6000, XLS-2502, MINIDSP 2X4
tarponater is offline
post #8 of 11 Old 01-18-2020, 03:43 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 77
Sounds like a lot of work. I think starting over would be easier.
post #9 of 11 Old 01-18-2020, 04:35 PM
Purenv's Avatar
Quoted: 235 Post(s)
Liked: 148
1099 redo
You could just order a vertical baffle from Erich at the DIY sound group. Cut the old baffle off your enclosure and just glue on the new baffle. Then finish it to match whatever finish you have on your speakers.
Purenv is offline
post #10 of 11 Old 01-18-2020, 04:37 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 77
What if I just left it as a horizontal speaker but put it on a vertical stand? So the waveguide would be left or right of the mids instead of on top of them...would it matter?
post #11 of 11 Old 01-19-2020, 04:43 PM
Purenv's Avatar
Quoted: 235 Post(s)
Liked: 148
Yes it would matter greatly in regards to the waveguide now being vertical instead of it’s intended purpose of being horizontal for better dispersion of the frequencies from the compression driver.
thisismyname123 likes this.
Purenv is offline
