4ft3 Cabinet for an 18" Sub: best PA Fit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-21-2020, 07:45 AM - Thread Starter
mastermaybe's Avatar
Quoted: 577 Post(s)
Liked: 427
Hola all,
I have an old 4ft3 cabinet for an 18" sub laying around and I want to throw a sub together for my/my daughters "new" game room. It's only ~ 300 sq st, so I don't need to go nuts.
Let's just say I can grab any of these sub $300 PA sub options awfully cheap. I want to stay sealed - and I know most PA subs like vented enclosures. Opinion on the best option, here?
https://www.sweetwater.com/store/sea...WluZW5jZSJdfX0
James
My Parlor and Theatre: "Jimbo's Dugout" : https://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #2 of 10 Old 01-21-2020, 07:52 AM
a77cj7's Avatar
Quoted: 636 Post(s)
Liked: 681
Originally Posted by mastermaybe View Post
Hola all,
James
Drop in a PA460 for $90, and use lots of eq.
https://www.parts-express.com/dayton...SAAEgJtcfD_BwE
Better option is to add some 4” precision ports as well.
Chris
a77cj7 is online now
post #3 of 10 Old 01-21-2020, 07:55 AM - Thread Starter
Quoted: 577 Post(s)
Liked: 427
Thanks- I can actually get any of those sub $300 Sweetwater options less expensively. Are any of those options superior? EQ will be tough, as I will just be running an entry-level Denon AVR to a EQ-less amp.
James
post #4 of 10 Old 01-21-2020, 08:49 AM
a77cj7's Avatar
Quoted: 636 Post(s)
Liked: 681
James
I can’t say without modeling each driver. Also depends on how much amplifier power you have available.
Any pro driver sealed is going to need eq to perform properly sealed. Check out the minidsp 2x4. It will also allow you to set HPF if you decide to go ported.
Chris
post #5 of 10 Old 01-21-2020, 08:50 AM
Vergiliusm's Avatar
Quoted: 271 Post(s)
Liked: 507
A PA sub wouldn't be my first choice but I would start by looking at drivers with middling Qts and lower Fs. Model and season to taste.
"Rock and roll is alive and alright" Sloan
Vergiliusm is online now
post #6 of 10 Old 01-21-2020, 09:44 AM - Thread Starter
Quoted: 577 Post(s)
Liked: 427
Yeah, I hear ya guys, really just cheaping out here. I'm going to go with this and let is serve double duty in the game room and for garage-gigging.
https://www.sweetwater.com/store/det...ered-subwoofer
James
post #7 of 10 Old 01-21-2020, 10:52 AM
Vergiliusm's Avatar
Quoted: 271 Post(s)
Liked: 507
That went a different direction quick.
For cheaping out and a better bang for the buck, I'd do a budget 18 in a ported cab, but we all have different needs.
Good luck
post #8 of 10 Old 01-21-2020, 11:47 AM
Chris Popovich's Avatar
Quoted: 281 Post(s)
Liked: 258
I'd just do a PA460 sealed and use a plate amp that you can turn the crossover very low on. Poor man's eq.
Chris
Chris Popovich is online now
post #9 of 10 Old 01-21-2020, 01:06 PM
STL D's Avatar
Quoted: 432 Post(s)
Liked: 523
If it's going to be game and gigging duty...
Four letters solve your issue.
V.B.S.S.
That way you can tune it high for gigging and tune it low for games and switch back and forth. Gaming actually can have heavier bass than movies and dig just as deep while sustained for long periods of time.
STL D is offline
post #10 of 10 Old 01-21-2020, 04:42 PM
Quoted: 503 Post(s)
Liked: 421
Yup, I used to use the newer Doom to demo a bit, the music and game has some serious bass.
Trimlock is offline
