Diy Sound group Volt-8 Kit VS Martin logan motion 4i for surrounds - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By Rowan611
post #1 of 4 Old 02-08-2020, 02:34 PM - Thread Starter
Liked: 0
DIY Sound group Volt-8 Kit VS Martin Logan motion 4i for surrounds?
Velocity Games is offline
post #2 of 4 Old 02-09-2020, 02:17 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1131
you need to post so much more info about the room, seating, ad nauseum
D: ALL of the ABOVE
it depends . . .
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 4 Old 02-09-2020, 07:17 PM
Rowan611's Avatar
Quoted: 636 Post(s)
Liked: 729
What’s with all these VS threads??
The whole point of DIY is to equal or out perform name brands. If you want to go DIY - then do. Be happy with it. If you want to spend more money for a name brand. Fine, do it. But I promise you no one here has compared the two. So...it’s a literal shot in the dark.
Personally, I’d build Volt 8s or 10s for what ML costs and be done with it.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is online now
post #4 of 4 Old 02-12-2020, 11:21 AM
OJ Bartley's Avatar
Quoted: 562 Post(s)
Liked: 667
If this is to match a set of ML mains, and they fit into your budget, maybe it makes sense to keep it in the family. If you're looking for a great performer at a significantly lower price, then any of the DIYSG models would be worth considering. But basically to get any kind of helpful advice you will need to post more information. Not a big deal, but the differences matter. Post the rest of your equipment, tell us about the room, what are your listening habits, etc. That should get you some better answers.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
