DIY front height speakers - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By asarose247
  • 1 Post By John Frank
post #1 of 6 Old 02-10-2020, 07:15 PM - Thread Starter
weng2x's Avatar
Planning to add a front-height speakers by using an external amp coming from the pre-outs of a non-atmos Onkyo TX818.
What are the DIY speaker options that can achieve something like an SVS Prime Elevation but at a cheaper cost? Thinking about those 6.5" drivers from Parts Express.
I'd like to copy the slanted cabinet form factor of the Prime Elevation and prefer to build my own as I have some spare MDF board laying around.
My current speakers are all SVS (7.1)
SCS-01M (LCR)
SSS-01 (bipole rear surrounds)
SBS-01 (front-wide)
PB13Ultra and a JL12W7 DIY sub
Will there be a significant issue on panning sound if the front-height speakers are non-timber matched?
weng2x is offline
post #2 of 6 Old 02-10-2020, 07:25 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1131
Alllll-riiiiiight-teeeeee
another VS inquiry
and NO info about the room, distances, seating,
and budget
a quick search show
shows prime elevataions for only $200 but the prime elevation height effects are $400 -crutchfield
it's not my money but since we're just spaghetti testing anyway
https://www.diysoundgroup.com/home-t...led-combo.html
yer done.
save the spare MDF for eventually throwing away . . .
Remy.Alexander likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 6 Old 02-10-2020, 09:20 PM - Thread Starter
weng2x's Avatar
another VS inquiry
and budget
a quick search show
yer done.
The room is 3100 cubic feet, the front height mounting distance is about 3.2 meters from the listening position and preferably cost below $200 for the drivers and x-overs.
I don't need a flat pack kit as I already have an MDF board.
Weng
weng2x is offline
post #4 of 6 Old 02-10-2020, 11:12 PM
asarose247's Avatar
Liked: 1131
It's assumed you've searched the SVS owners thread
wrt comparative expectations . .
and looked around at DIY sites for kits wrt a tight budget
these don't have an angled cab
https://www.diysoundgroup.com/home-a...-plus-kit.html
but sometimes a tight budget lends itself to creative solutions
while it seems they may not dig as deep as the SVS units,
as heights, that xo could be 100 or more
you don't want localized bass
and the notion / importance of "matched timbre" isn't much of a talking point in a discussion involving a $100 speaker,
which flavor of REQ do you have?
heights may not have that much info anyway
and when you say non-ATMOS, then there is no DSU
but I've found that NEO:X-using FH's can, source dependent, add to the front sound stage, using Audy XT32.
post #5 of 6 Old 02-11-2020, 07:59 AM
John Frank's Avatar
Quoted: 92 Post(s)
Liked: 42
I just finished 2 new back speakers using Mark Audio from Japan. Damn good full range (no coax or crossover) drivers at a great price. Have a new Anthem MRX720, haven't decided to do Atmos speakers yets. Good luck!
https://meniscusaudio.com/product/mark-audio-chp-70a-p/
ID:	2683654   Click image for larger version
eriksells916 likes this.
John Frank is offline
post #6 of 6 Old 02-11-2020, 10:31 AM
asarose247's Avatar
Liked: 1131
"The CHP-70 Gen. 2 will assist in the control of sharp or hard sounding compressed music
(digital) . This CHP delivers a tone that appeals to classic music enthusiasts using smaller
amplifiers. The off-axis and sound-spread of the CHP-70 is excellent. This driver is capable of
filling a room environment with an “easy listening” experience, especially for human voice. The
bass response from the CHP-70 Gen. 2 in a properly tuned box is excellent for this smaller
sized driver. Typically, in a Bass-Reflex or Vented box, lower responses close to 40Hz can be
obtained."
let us know how it goes . .
