Subwoofer drivers that like smaller ported boxes? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By johnson636
  • 1 Post By michael hurd
post #1 of 18 Old 02-11-2020, 05:23 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
I know the Ultimax gets all the love here, but it doesn't seem to appreciate especially small boxes for ported alignments. Can someone suggest drivers that do well for extension in a smaller enclosure? I'm thinking 15" driver, aiming for an F3 at 16 Hz in the ballpark of Correction: 6 cubes.
Promit is offline
post #2 of 18 Old 02-11-2020, 05:59 PM
johnson636's Avatar
Quoted: 1380 Post(s)
Liked: 864
How much money are you looking to spend? Most any driver can play ULF, at what spl level is the question. So what spl are you looking to achieve?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 18 Old 02-11-2020, 06:06 PM
mtg90's Avatar
Quoted: 845 Post(s)
Liked: 1682
The Peerless STW-350F-188PR01-04 will do it but good luck getting a port large and long enough into a cabinet that small. Would be a better candidate for some passive radiators.
Otherwise if you could give up a few Hz the Dayton RSS390HO would work well in a cabinet that small.
mtg90 is online now
post #4 of 18 Old 02-11-2020, 06:14 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
I can throw a bit of money at the problem - let's say ballpark $500 on the driver but I am open to options. I'd like to achieve output comparable to the SVS PB-3000, anything more is gravy. I will have DSP on the front end too. I checked my numbers and turns out I lowballed the box size a little in the original post so I've revised it up to 6 ft³.
Promit is offline
post #5 of 18 Old 02-11-2020, 06:14 PM
smcmillan2's Avatar
Quoted: 1033 Post(s)
Liked: 886
HST-15 in a sealed box with a crap-ton of power and boost on the low end?
https://stereointegrity.com/product/hst15-15-subwoofer/
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #6 of 18 Old 02-11-2020, 06:19 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
I forgot about this beefy miracle of Xmax, thanks! That might just solve the problem here and now. Wish it was in stock at PE, I hate to wait a month
Promit is offline
post #7 of 18 Old 02-11-2020, 06:26 PM
johnson636's Avatar
Liked: 864
I'd go with the HST-15 if it were me.
18Hurts and STL D like this.
post #8 of 18 Old 02-11-2020, 06:33 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
Good lord I just modeled the HST-15. What is this thing??
Between the Peerless and the SI, I'm basically set here but please show me more beastly sub drivers!
Promit is offline
post #9 of 18 Old 02-12-2020, 02:07 AM
blake18's Avatar
Quoted: 683 Post(s)
Liked: 391
Dayton RSS390HO, all day.
Lumenlab "Community driven video lab".
blake18 is offline
post #10 of 18 Old 02-12-2020, 05:38 AM
Samps's Avatar
Quoted: 1258 Post(s)
Liked: 945
Mtx 9515-22
Samps is offline
post #11 of 18 Old 02-12-2020, 12:51 PM
michael hurd's Avatar
Quoted: 645 Post(s)
Liked: 695
Beefy miracle of xmax... hardly. I'd suggest reading the thread on it.
scottvalentin likes this.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, impulsivity, uncontrolled or repeated movements.
michael hurd is offline
post #12 of 18 Old 02-12-2020, 02:38 PM
TheGiantPeach's Avatar
Quoted: 142 Post(s)
Liked: 120
Not quite as beastly but WAY cheaper is SI's upcoming SQL line: https://stereointegrity.com/product/sql-15/
I have two on preorder.
TheGiantPeach is offline
post #13 of 18 Old 02-12-2020, 07:59 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
I was looking at that, but the RM isn't out of the question either. They just don't seem to be popular woofers and I can't find much information about them/
Promit is offline
post #14 of 18 Old 02-12-2020, 08:19 PM
smcmillan2's Avatar
Liked: 886
I think you're missing an aspect here. What amp do you intend to use?
The HST-15 likely (I haven't looked at every one) has the most Xmax and can handle the most power of any of the 15" drivers you have been looking at.
You want low extension in (and I quote) "smaller"? An HST-15 in a sealed box will do what you are after, given enough power. Run the sims in WinISD.
post #15 of 18 Old 02-12-2020, 09:26 PM
Quoted: 645 Post(s)
Liked: 695
https://www.avsforum.com/forum/155-d...l#post57846184
Going by the Klippel defined compliance limits, 5.95 mm one way excursion is all she's got cap'n. ( at least for the sample tested )
https://www.klippel.de/fileadmin/kli...inearities.pdf
Of course it can 'move' more than that, but the linearity will suffer, in turn generating distortion components that are not in the driving signal.
Per Klippel: Driven at Fs with a sinusoidal tone to a displacement equal to 0.75 of the at rest Cms will result in 10% distortion.
Source: page 7 of 10 https://www.klippel.de/fileadmin/kli...inearities.pdf
I have noticed that the spiders are assembled in the same direction on the coil former, they should be mirrored. This was shown in a cutaway photograph and from third party accounts of actual units in the wild.
post #16 of 18 Old 02-13-2020, 08:23 AM
Quoted: 142 Post(s)
Liked: 120
They're definitely a smaller company and they mainly focus on the car audio side of things. You may have heard of them a few years back when they sold HT-18's for $200 that a lot of people used in Marty subs. The RM line is hand made to order in the U.S., like the HSTs, whereas the new SQL line has been produced in China.
post #17 of 18 Old 02-13-2020, 11:51 AM
Quoted: 521 Post(s)
Liked: 448
Your issue is mainly going to be with your box and not really finding a driver that works in smaller boxes as there are quite a few of those (especially the SI's). The box, paired up with a driver that aligns better in smaller boxes will need to be tuned closer to 20hz, a box with total 6cu/f is really asking a lot for very little. Assuming double baffle and .75" material, this leaves you with 4.7 cu/f internal to work with and that includes the bracing, driver AND port.
A port small enough to fit in that enclosure (and not hit a too low 1st port resonance) would max out very early. I wouldn't suggest trying dump a lot of power into that alignment.
Trimlock is offline
post #18 of 18 Old 02-13-2020, 12:53 PM
Quoted: 54 Post(s)
Liked: 57
OP hasn't stated SPL goals, but you could go with 2 CSS SDX12 (12" sub) in 3 cubes each. Models pretty well at 20hz tuning, ports are pretty long though.
https://www.css-audio.com/online-sto...fer-p110031759
They have passive radiators that will work well with this as well to @mtg90 's point.
scottvalentin is offline
