How to do driver cut outs? - AVS Forum | Home Theater Discussions And Reviews
 13Likes
  • 6 Post By smcmillan2
  • 1 Post By shellshox345
  • 3 Post By johnson636
  • 1 Post By tarponater
  • 2 Post By Augerhandle
post #1 of 10 Old 02-11-2020, 06:29 PM - Thread Starter
blake18's Avatar
Quoted: 681 Post(s)
Liked: 387
Is there a way to make 15" driver cutouts with a jigsaw?
Lumenlab "Community driven video lab".
blake18 is online now
post #2 of 10 Old 02-11-2020, 06:37 PM
smcmillan2's Avatar
Quoted: 1033 Post(s)
Liked: 885
Of course. Draw out your circle and cut on the line.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #3 of 10 Old 02-11-2020, 06:40 PM
Liked: 3
You can also get it started by drilling a hole, so you don't have to plunge the blade into the sheet
Green Chemist likes this.
shellshox345 is offline
post #4 of 10 Old 02-11-2020, 07:27 PM
johnson636's Avatar
Quoted: 1379 Post(s)
Liked: 864
A quick google or youtube search would have answered this question. No need to start a thread.
@Augerhandle , we have another one
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 10 Old 02-11-2020, 07:40 PM
tarponater's Avatar
Quoted: 196 Post(s)
Liked: 730
You can make a circle jig for your jigsaw with a scrap piece mdf or plywood. There should be some screw holes in the jigsaw base. Get longer screws to account for the thickness of the material you are using. Start your cut freehand inside the circle, slowly bring it out to the line and then attach the jig to the center of the circle lightly with a screw.
scottvalentin likes this.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is offline
post #6 of 10 Old 02-11-2020, 07:45 PM
tarponater's Avatar
Quoted: 196 Post(s)
Liked: 730
Also, use a scroll bit to limit the chances of the blade tracking straight. Practice the cut first. If it wants to track straight, very lightly shake the saw as you cut. That will make a slightly wider cut and allow the blade to turn better without binding.
post #7 of 10 Old 02-12-2020, 07:07 AM
lawdogx's Avatar
Quoted: 207 Post(s)
Liked: 243
Great advice above! I’ll only add a few tidbits: First, I found a beam compass to be really helpful in drawing large, perfect circles. Second, the 6 or 8 tpi blade that came with your jigsaw is not the right tool for this job. Grab a blade with a higher tooth count and the smaller the hole the more it will benefit from narrower blades (like Tarp explained, to better cut curves without binding or tracking straight).
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
post #8 of 10 Old 02-12-2020, 04:59 PM
kgveteran's Avatar
Quoted: 844 Post(s)
Liked: 247
@Augerhandle , we have another one[IMG class=inlineimg]/forum/images/smilies/tongue.gif[/IMG]
We gotta start somewhere, i much prefer a conversation than a search, even simple stuff :0)
Its a community of shared idea’s, even what speaker cable to purchase, and do all amps sound the same, and do we really have to discuss power cords and why $5,000 might be a hasty purchase.
I say “welcome to the forum“, good luck on the build !!
KG
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is online now
post #9 of 10 Old 02-12-2020, 05:08 PM
johnson636's Avatar
Liked: 864
KG
_K
post #10 of 10 Old 02-13-2020, 09:21 AM
Augerhandle's Avatar
Quoted: 1417 Post(s)
Liked: 1380
We gotta start somewhere, i much prefer a conversation than a search, even simple stuff ...
KG
I think that what johnson636 is trying to say, is that blake18 has started a few threads to ask one simple question in each.
We all love to help, so I suggest you ( @blake18 ) start a build thread ("Building a Sub, Please Help"), or go back to one of your other relevant threads, and ask all questions there. People will see when the thread has been updated, and they'll jump in to help.
Plus, all the info will be consolidated in one place to make it easy for you or anyone else to refer back to the One Thread To Rule Them All.
johnson636 and smcmillan2 like this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
