If weight was no concern.... - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Weight is no concern - thicker walls or more bracing? Why?
Thicker walls 0 0%
More Bracing 14 100.00%
Voters: 14. You may not vote on this poll
 4Likes
  • 1 Post By Russdawg1
  • 2 Post By Trimlock
  • 1 Post By A9X-308
post #1 of 8 Old 02-13-2020, 01:51 PM - Thread Starter
AVB
AVB's Avatar
Would you go with thicker walls or more bracing? Why?
There is no such thing as too much clean power.
AVB is offline
post #2 of 8 Old 02-13-2020, 02:04 PM
N8DOGG's Avatar
Quoted: 1403 Post(s)
Liked: 1652
More bracing
N8DOGG is online now
post #3 of 8 Old 02-13-2020, 02:44 PM
Quoted: 1948 Post(s)
Liked: 1549
More bracing.
I’m not an expert but with thicker walls you are relying on the shear strength of the wood. With more bracing you rely on the compressive strength of the wood. Wood has a much higher compressive strength than shear.
So by using braces you end up with a physically stronger box, one that has less resonances, and will probably be just as light, if not lighter, than if you used thicker walls for your box
eljaycanuck likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 8 Old 02-13-2020, 03:17 PM
Quoted: 503 Post(s)
Liked: 421
Bracing, you get more room and a much easier build.
smcmillan2 and eljaycanuck like this.
Trimlock is offline
post #5 of 8 Old 02-13-2020, 03:50 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1131
more bracing
windowed bracing
there is also the possibility of using 3/4" x 3/4" x 1/8th angle iron with good screws on 6" (?) centers for the length
minimum volume reduction
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #6 of 8 Old 02-13-2020, 05:33 PM
smcmillan2's Avatar
Quoted: 1031 Post(s)
Liked: 879
What Trimlock and Russdawg said.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #7 of 8 Old 02-13-2020, 05:34 PM
eljaycanuck's Avatar
Quoted: 2022 Post(s)
Liked: 2877
eljaycanuck is offline
post #8 of 8 Old 02-13-2020, 06:14 PM
A9X-308's Avatar
Quoted: 1874 Post(s)
Liked: 1606
More bracing, cross connected in 3D a la B&W matrix. Why? Because it ties all the panels together into one structure and adds far more rigidity than thickness. This is the only way I build now, especially for larger enclosures.
mhutchins likes this.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
