Cylinder sub material selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-14-2020, 01:47 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
I know that the traditional material for cylinders is a branded concrete form product called Sonotube, which is essentially round cardboard but isn't necessarily available in reasonable sizes. Home Depot carries a Sakrete form but I've heard that these aren't always in the best condition. In looking around I've seen several other similar options and I'm wondering if one of these would be a good or bad choice to build a sub around.
  • Commercial HVAC ducting, I think this is usually aluminum. There's a build thread out there but it strikes me as worryingly thin.
  • PVC pipe. Not sure where to source this stuff.
  • HDPE based concrete form (Ceme-Tube). Might be a promising choice?
  • Cylindrical plywood rings. Rather expensive and need to be glued to get a tall cylinder, but maybe a much more robust and inert choice.
I'm really interested in the ceme-tube, although I haven't gotten pricing info yet. Is there a wrong answer here?
Promit is offline
post #2 of 6 Old 02-14-2020, 02:30 PM
zeus33's Avatar
Quoted: 1908 Post(s)
Liked: 2072
The sonotube is the one to use. What are "reasonable sizes" to you? These come in pretty much any size you would need for subs.
They are made in 6" up to 36.9" diameter.
zeus33 is online now
post #3 of 6 Old 02-14-2020, 02:33 PM - Thread Starter
Promit's Avatar
Quoted: 75 Post(s)
Liked: 35
Sorry, I meant length. I don't need twelve feet of sonotube (and frankly I'm not sure where or how to buy it).
Promit is offline
post #4 of 6 Old 02-14-2020, 02:45 PM
zeus33's Avatar
Liked: 2072
Just search local supply places by you. They can cut them down to the length you need.
I don't know what's in your area, but some members have mentioned Menards.
HD Supply: https://www.whitecap.com/locations/
post #5 of 6 Old 02-14-2020, 02:47 PM
jujuman200's Avatar
Quoted: 280 Post(s)
Liked: 272
Well, If you go with ANY type of pipe solution.... the minimum length will be 10 feet.... it is what it is....
https://www.menards.com/main/buildin...4442809765.htm
Juju
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20Hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #6 of 6 Old 02-14-2020, 03:01 PM
a77cj7's Avatar
Quoted: 634 Post(s)
Liked: 680
One of my local contractor supply stores sells sonotube by the foot. A few others sell in complete 10ft sections. Your best bet is to call around.
Chris
a77cj7 is online now
