Paint Match? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JohnDean
post #1 of 3 Old 02-14-2020, 02:01 PM - Thread Starter
nexus99's Avatar
Quoted: 188 Post(s)
Liked: 86
Paint Match?
Anyone know how to get a paint match for a pantone code? My speakers have that glossy automotive finish look and I want to paint subs to match. I asked what the color is and was told Pantone 2747c.
If you google that you can see the rich blue color. Any thoughts on how to get something that mostly matches?
JDM World: https://www.youtube.com/jdmworld
GSG Devastator Build Eminence 21" https://youtu.be/DgtVxjg06to
GSG Full Marty Build: https://youtu.be/-U1deD_0j9c
UM18-22 Sealed Subwoofer Build: https://youtu.be/7ifac8Rh8gk
nexus99 is offline
post #2 of 3 Old 02-14-2020, 02:10 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1131
check with the Dupli-color automotive line of rattle cans . .
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 3 Old 02-14-2020, 02:14 PM
JohnDean's Avatar
Quoted: 568 Post(s)
Liked: 266
You can take the codes to a paint store and they should be able to mix it. If you go somewhere like Home Depot you can even get a sample size to see how it compares. I'm sure auto paint places will do the same.
RGB 0 26 114
HEX/HTML 001A72
CMYK 100 85 0 37
jujuman200 likes this.
JohnDean is offline
