HT12 cover troubles - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By backwoods 99
post #1 of 8 Old 02-20-2020, 06:31 PM - Thread Starter
backwoods 99's Avatar
HT12 cover troubles
Had my daughter test her soldering skills and assemble all 3 crossovers. First one worked fine but the last two both are reading neg across both hp terminals. Advice?
Sent from my Pixel 4 XL using Tapatalk
backwoods 99 is offline
post #2 of 8 Old 02-20-2020, 06:46 PM - Thread Starter
Ha, long day tired brain wrong mm setting. We good . Carry on.
post #3 of 8 Old 02-20-2020, 06:47 PM - Thread Starter
Photo of first finished HT12 for posterity so the thread isn't a total waste
asarose247 and bubbrik like this.
post #4 of 8 Old 02-20-2020, 07:29 PM
mtg90's Avatar
Quoted: 852 Post(s)
Liked: 1693
The inductor leads need to be soldered on the pre-tinned ends. If you trimmed those leads shorter you need to scrape off the thin red coating/insulation before you solder them otherwise you won't get a good connection.
mtg90 is online now
post #5 of 8 Old 02-20-2020, 07:34 PM - Thread Starter
That was the issue on the first one, easy to find and correct. She's learning. These have been a great project so far. Some rough moments with contact cement and tinning an iron but it's going well.
post #6 of 8 Old 02-21-2020, 02:25 PM
asarose247's Avatar
Quoted: 1308 Post(s)
Liked: 1151
wait til you hear those 15" SEOS horns singing
be sure to experiment with toe in
Name:	3 x 15's.jpg
ID:	2688142   Click image for larger version
Name:	3 x 15 SEOS F0775.jpg
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #7 of 8 Old 02-21-2020, 07:23 PM
dasa2131's Avatar
Quoted: 94 Post(s)
Liked: 91
@backwoods 99
How do you like the HT12's? I'm really interested in hearing since I'm close to buying 3 of them.
Dave
dasa2131 is offline
post #8 of 8 Old 02-27-2020, 07:23 AM - Thread Starter
I have another thread about them. Once I get all the kinks worked out, I'll get you details on the performance. pa speakers especially seem to have stiff suspensions and take some break in time. So far, I think these are going to be a great investment. I'll give some comparisons soon.
