DIYSG ELUSIVE 1099's (UK BUILD) - AVS Forum | Home Theater Discussions And Reviews
 44Likes
  • 2 Post By mkohman
  • 3 Post By mkohman
  • 3 Post By mkohman
  • 2 Post By mkohman
  • 4 Post By mkohman
  • 4 Post By mkohman
  • 1 Post By chadsmith013
  • 2 Post By OJ Bartley
  • 1 Post By sbazzle
  • 5 Post By mkohman
  • 1 Post By johnson636
  • 9 Post By mkohman
  • 1 Post By DavidinGA
  • 2 Post By mkohman
  • 1 Post By soundhog
  • 1 Post By CallingMrBenzo
  • 2 Post By mkohman
post #1 of 26 Old 03-09-2020, 03:59 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Hello All,
After a few weeks of selling on my much beloved HTM-12's, I was in search for a new L C R build and narrowed my options to a couple of models. In the end I decided to go with the Elusive 1099's as my new L C R.
These are true beasts and whilst they are an extremely well designed three way speaker, they were the perfect width for my new in wall design. As some may know I had to sell on the HTM-12's not because I wasn't happy with them but because they were just too wide for what I had in mind with my new design.
Basically I am now building a new set of L C R with 18 inch subs in between each of the channels which will reside behind my acoustic transparent screen.
Below you will see some pictures of what I had to do to make the screen wall stronger in order to carry the weight of two huge subs and the new L C R when finished.
Quick rundown on what I have done so far. I cut all my MDF and prepared for the build. Monday I started gluing up the cabinets for the L C R and yesterday I was able to start and complete the build of all three crossovers. This actually took a lot longer than I had anticipated but the results were well worth it. I hope they will work and sound as good as they look
So, I will post some pics below for now and will try to keep on top of this thread as and when I improve in my build.
Here you will find some pictures of having to re enforce the screen wall:
ID:	2695508   Click image for larger version
ID:	2695510   Click image for larger version
ID:	2695512   Click image for larger version
chadsmith013 and OJ Bartley like this.
mkohman is offline
post #2 of 26 Old 03-09-2020, 04:01 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
The subs that I am still in the process of building which will sit between the L C R:
ID:	2695518   Click image for larger version
ID:	2695520   Click image for larger version
ID:	2695522   Click image for larger version
ID:	2695524   Click image for larger version
mkohman is offline
post #3 of 26 Old 03-09-2020, 04:06 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Pictures of drivers and parts that I had delivered from DIYSG, also some pics of my crossover build:
ID:	2695530   Click image for larger version
ID:	2695532   Click image for larger version
ID:	2695534   Click image for larger version
ID:	2695536   Click image for larger version
ID:	2695540   Click image for larger version
ID:	2695542   Click image for larger version
ID:	2695544   Click image for larger version
ID:	2695546   Click image for larger version
mkohman is offline
post #4 of 26 Old 03-09-2020, 04:13 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
The weekend was so horrible, it rained all day so I decided to stay in and crack on with the build I managed to cut the internal dividers (table saw inside the garage) for the speaker cabinets and for extra strength, I not only used gorilla wood glue but made 9 pocket holes per piece and used 38 mm screws. I also made 9mm holes for the cables to go through into the relative sections from the crossovers to the drivers.
ID:	2695552   Click image for larger version
ID:	2695554   Click image for larger version
ID:	2695556   Click image for larger version
ID:	2695558   Click image for larger version
ID:	2695562   Click image for larger version
ID:	2695564   Click image for larger version
krholmberg and OJ Bartley like this.
mkohman is offline
post #5 of 26 Old 03-09-2020, 04:17 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Some more pics of cutting out and preparing the acoustic foam insulation. I will also be adding some Polly Fill in the mid section :
ID:	2695568   Click image for larger version
ID:	2695570   Click image for larger version
ID:	2695572   Click image for larger version
ID:	2695574   Click image for larger version
ID:	2695578   Click image for larger version
ID:	2695580   Click image for larger version
mkohman is offline
post #6 of 26 Old 03-09-2020, 04:19 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
So today was a nice day and I thought it'd be a good idea to get the sanding out the way and prepare the speakers for painting.
By the time I had finished for the day, I realised I had spent 6 hours in the garden
When you sum it up , it works out to be 2 hours per speaker (not that bad really). So what did I do?
First off, I sanded all the speakers with 40, 60, 120, 240, 400 and 600 grit sandpaper. I took my time when doing so especially with the 40 and 60 grit as these are the most crucial part of sanding.
So after sanding I moved onto rounding over all the speakers to give it a professional look and then moved onto the cut outs at the back (speak on connection is for actually connecting the speakers to the power amp and the speaker terminal connection above it will act as a jumper for using the High Frequency Padding) which is usually accessed on the crossover board , however bringing the cable from the crossover board to the back of the speakers which will be much easier to access if I ever needed to use this feature
ID:	2695584   Click image for larger version
ID:	2695586   Click image for larger version
ID:	2695588   Click image for larger version
ID:	2695590   Click image for larger version
ID:	2695594   Click image for larger version
ID:	2695596   Click image for larger version
ID:	2695598   Click image for larger version
ID:	2695600   Click image for larger version
mkohman is offline
post #7 of 26 Old 03-09-2020, 07:13 PM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Nice work on those cabinets. Building speakers always takes longer than expected but is well worth it. What are the subs you are using?
Sent from my SM-G950U using Tapatalk
Jedi940 is offline
post #8 of 26 Old 03-09-2020, 10:12 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Thank you well I currently have 4 x 18" Ultimax in sealed cabinets which I built end of last year. These two new 18" 's are Faital Pro drivers.
mkohman is offline
post #9 of 26 Old 03-10-2020, 05:14 AM
chadsmith013's Avatar
Quoted: 2596 Post(s)
Liked: 2645
awesome....great job man.
mkohman likes this.
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 4 DIYSG Volt 6's
Subwoofers: Dual Eminence NSW 21's in Cyclops enclosures w/Inuke 6000
Nearfield: 4 B-52 SP-1804 18s w/Inuke 6000DSP
chadsmith013 is offline
post #10 of 26 Old 03-10-2020, 06:15 AM
OJ Bartley's Avatar
Quoted: 595 Post(s)
Liked: 708
Great build so far, and you're really moving along. I like the mod to put the jumper on the back of the speaker too, that's thinking ahead.
mkohman and krholmberg like this.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
post #11 of 26 Old 03-10-2020, 06:28 AM
sbazzle's Avatar
Quoted: 12 Post(s)
Great build. Can you post a photo or two from maybe the inside of the box showing how the crossover is wired to both ports on the rear?
mkohman likes this.
Professional home theater lurker.
sbazzle is offline
post #12 of 26 Old 03-10-2020, 11:53 AM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
I will definitely do so when I am at that stage .. next step is to get the cabinets all painted.
I am thinking of adding some threaded inserts at the bottom of each speaker and using some rubber feet. Would you guys reccomend this? or will it be ok to place them directly on the platform ?
I am thinking of either busing these:
https://www.amazon.co.uk/MiCity-Spea.../dp/B0753CFZ1J
or these:
https://www.amazon.co.uk/Hudson-Hi-F...tronics&sr=1-3
Which do you guys feel may be the best solution? Also will be using them for the subs too which will be sitting inbetween the LCR. Thanks
mkohman is offline
post #13 of 26 Old 03-15-2020, 05:56 AM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Good afternoon all, just a few more pics of the painting process... I am happy to be finished with this stage as for me it's a very delicate process in order to get a perfect or at least, near enough perfect finish. I ended up with 3 coats of primer and 6 top coats of matt black paint. Next stage will be lining up the inside of the cabinets and cabling before finally placing in the drivers and finishing them off
ID:	2698128   Click image for larger version
ID:	2698130   Click image for larger version
ID:	2698132   Click image for larger version
ID:	2698134   Click image for larger version
ID:	2698138   Click image for larger version
ID:	2698140   Click image for larger version
mkohman is offline
post #14 of 26 Old 03-15-2020, 06:23 AM
johnson636's Avatar
Quoted: 1748 Post(s)
Liked: 1280
Mighty fine paint job there sir
mkohman likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #15 of 26 Old 03-16-2020, 04:35 AM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Thank you for your kind words
mkohman is offline
post #16 of 26 Old 03-16-2020, 04:37 AM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Just finished insulating the cabinet walls. I will also use poly fill in the middle chamber.
ID:	2698510   Click image for larger version
ID:	2698512   Click image for larger version
mkohman is offline
post #17 of 26 Old 03-28-2020, 02:26 PM
Liked: 0
Nice build! I have the same PCB board as you and I can't find any diagrams on how to set it all up. Everything I'm finding is different. My main question is which resistors go in which slot? I'm pretty new to this stuff.
zendofzwrld is offline
post #18 of 26 Old 03-28-2020, 06:42 PM
mtg90's Avatar
Quoted: 903 Post(s)
Liked: 1740
I sent you a PM with a link to the PCB layout sheet.
mtg90 is online now
post #19 of 26 Old 03-28-2020, 07:19 PM
DavidinGA's Avatar
Quoted: 624 Post(s)
Liked: 293
Excellent build!
Sent from my Pixel 2 XL using Tapatalk
mkohman likes this.
Epson 5040, 150" 16:9 1.1gain, Source: HTPC w/madVR, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 4 diy Slim VBSS 18" Subs w/NX3000D.
DavidinGA is offline
post #20 of 26 Old 03-29-2020, 06:51 AM
Liked: 0
Does anyone know if I can line these with glued down R30 insulation instead of foam? I have a whole role of it sitting in my garage. Thanks.
post #21 of 26 Old 03-29-2020, 08:47 AM
fullhorn's Avatar
Quoted: 33 Post(s)
Liked: 67
Yes, That will work.
fullhorn is offline
post #22 of 26 Old 05-14-2020, 06:33 PM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
Guys I apologise for not updating this thread but I finished my 1099's and built 2 x subs that go in between them as well as 7 x Volt 10's with some magnetic grills
Here are some updated photos:
ID:	2726424   Click image for larger version
ID:	2726426   Click image for larger version
ID:	2726428   Click image for larger version
ID:	2726430   Click image for larger version
Crantastic and CallingMrBenzo like this.
mkohman is offline
post #23 of 26 Old 05-15-2020, 12:10 PM
soundhog's Avatar
Liked: 3
Hi mkohman, great build thread and a really nice job of those speakers. Can you share some details of the volt 10's and the magnetic grills you mention above.
I am about to embark on a very similar build, 1299 LCR and 4 x volt 10's for surround and 2 x 21" subs. My difficulty is that I am trying to make it an "invisible build" in my lounge with the volts in the ceiling. I am struggling to find grills to fit the volts in white. I am hoping you may have some go bye's I can plagiarise. Thanks.
mkohman likes this.
soundhog is offline
post #24 of 26 Old 05-24-2020, 05:01 PM
CallingMrBenzo's Avatar
Quoted: 816 Post(s)
Liked: 2079
Time to update your thread HULK cant do all of it on Instagram
mkohman likes this.
Marantz 7011- Panasonic UB-820- Xbox One X -Nvidia Shield - JVC RS4910 * - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R -VOLT 6 Surrounds - Atmos: SVS Elevations Atmos X2, Volt 6 x 2- Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ *HOVER BOSS* UM-18, 2 JBL's, Maxxis Fat tubes, Behringer NX4-6000
CallingMrBenzo is offline
post #25 of 26 Old 06-28-2020, 07:11 AM - Thread Starter
mkohman's Avatar
Quoted: 517 Post(s)
Liked: 479
mkohman is offline
post #26 of 26 Old Today, 12:23 PM
Quetzalcoalt's Avatar
Quoted: 131 Post(s)
Liked: 181
Would love to see how the Closed Faitals do, can you post some measurements with only those two playing ?
Quetzalcoalt is offline
