My V.B.S.S build has started - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By qguy
  • 1 Post By a77cj7
  • 1 Post By a77cj7
  • 1 Post By qguy
  • 1 Post By qguy
  • 1 Post By qguy
post #1 of 11 Old 03-10-2020, 07:33 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Finally my build has started, but there is a gap on one of my panels, The gap can clearly be seen using a flashlight and a dark room. Need to make a lot of sawdust tomorrow to fix this
ID:	2695826   Click image for larger version
ID:	2695828   Click image for larger version
ID:	2695830   Click image for larger version
bebb likes this.
qguy is offline
post #2 of 11 Old 03-10-2020, 07:42 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Not really an issue, just hit it with some PL or silicone.
Bondo or spackle works for finishing the outside.
Chris
bebb likes this.
a77cj7 is offline
post #3 of 11 Old 03-10-2020, 07:48 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Chris
I will most likely sand it down, the finish will be natural, so I am not able to use body filler. Orbital sander should make this an easy fix
qguy is offline
post #4 of 11 Old 03-10-2020, 07:51 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Ahh, I thought you had already glued it.
Chris
qguy likes this.
a77cj7 is offline
post #5 of 11 Old 03-12-2020, 10:49 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Made some progress and it dwarfs my 15 inch sub
Name:	test fit 2.jpg
OJ Bartley likes this.
qguy is offline
post #6 of 11 Old 03-14-2020, 08:15 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Getting closer to the finish line
Name:	diy sub clamp.jpg
ID:	2697556   Click image for larger version
Name:	VBSS vs PB 12 `.jpg
ID:	2697558   Click image for larger version
Name:	VBSS vs PB 12 2.jpg
qguy is offline
post #7 of 11 Old 03-14-2020, 08:33 AM
Liked: 3
Looks good. I was thinking about doing one or two VBSS. I can't wait to see how it turns out.
reddman71 is offline
post #8 of 11 Old 03-14-2020, 08:43 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Better midbass than the PB12, Have not tried on movies yet, will test on movies next week after I finish the subwoofer enclosure
qguy is offline
post #9 of 11 Old 03-16-2020, 07:22 AM
Quoted: 236 Post(s)
Liked: 223
Looking good!
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #10 of 11 Old 03-16-2020, 08:12 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Almost done, I know, I $uck at staining wood I might redo the finish when I have extra time, so far this works as most of the sides of the enclosure is hidden anyways, still need to make a grill to protect the sub driver
ID:	2698548   Click image for larger version
ID:	2698550   Click image for larger version
qguy is offline
post #11 of 11 Old 03-23-2020, 05:53 AM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Did not like the outcome of the stain, so BLACK it is
ID:	2700870   Click image for larger version
Name:	sub black 1.jpg
ID:	2700872   Click image for larger version
Name:	sub black 2.jpg
Bnaan likes this.
qguy is offline
