Devastator LFE build thread - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By jujuman200
  • 1 Post By rockironwebb
  • 1 Post By Jedi940
  • 1 Post By a77cj7
post #1 of 16 Old 03-16-2020, 11:36 AM - Thread Starter
rockironwebb's Avatar
Liked: 51
Title says it all.
I'm using a lavoce 21",,powered by 1 channel of an fp14000.
Hopefully I've scraped the relevant plan information from the devastator thread as it seems like it is full of variations. If anyone happens to have a more concise plan for the lfe I'd appreciate having it.
rockironwebb is offline
post #2 of 16 Old 03-16-2020, 07:18 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 859
Originally Posted by rockironwebb View Post
Title says it all.
Latest version of the LFE is found here.
Devastator 21" Finalizer HCR 48"25.5"x34" 16Hz Tune (an optimized LFE)
This, and other versions can be found linked in the first post of the Index thread.
Chris
a77cj7 is online now
post #3 of 16 Old 03-16-2020, 07:21 PM - Thread Starter
Liked: 51
Much appreciated!
post #4 of 16 Old 03-17-2020, 12:08 PM
jujuman200's Avatar
Quoted: 341 Post(s)
Liked: 314
Title says it all.
Welcome to the club of LFE builders..... you are gonna love it....
Juju
johnson636 likes this.
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20Hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #5 of 16 Old 03-19-2020, 04:06 AM - Thread Starter
Liked: 51
I was able to get going on making cuts. Every time I build a very large sub I vow that I'm going to buy a high end fence system for the large panel cuts but I never get around to it. I'll end up using 2.5 sheets of MDF just because I like to cut my large side panels at the same time. I put 2 full sheets on the saw horses, get them lined up perfect and run a couple of screws to secure them together. I then use a super straight 1x8 as a guide and a circular saw to cut both sheets at the same time. (I also vow to buy a track saw but it hasn't happened yet)
This takes care of 2 identical cuts and also leaves the remaining sheets to be manageable for the table saw.
post #6 of 16 Old 03-19-2020, 08:08 AM
MTBDOC's Avatar
Quoted: 121 Post(s)
Liked: 93
If you don't want the cost of a tracksaw (I have an interesting setup developed by a guy years ago under the 'Eurekazone' name), then a clamp on aluminum cutting guide is well worth it. Trying to do this with a piece of lumber is going to be frutstrating! And if you are really serious, take diagonal measurements to make sure you are laid out square.
MTBDOC is offline
post #7 of 16 Old 03-19-2020, 09:34 AM
Jedi940's Avatar
Quoted: 303 Post(s)
Liked: 220
I have used an 8 foot level from harbor freight clamped to the board. Works pretty well.
Jk7.2 likes this.
Jedi940 is offline
post #8 of 16 Old 03-21-2020, 07:51 AM - Thread Starter
Liked: 51
I just went with the jigsaw for my baffle cut out. I figured since the driver was hidden there was no need to break out the router and make a jig to get it perfect.
A problem I've had with certain jigsaws is they pile up sawdust onto the line I'm trying to cut, so I like to set up a fan to blow away the dust and keep my line visible.
To get my line I set a screw dead center,, I use a flat metal ruler that has a hole at the end. I mark and drill my radius point just big enough for a sharpie to fit through and pivot the rule around.
ID:	2700146   Click image for larger version
ID:	2700148   Click image for larger version
ID:	2700150   Click image for larger version
post #9 of 16 Old 03-21-2020, 07:52 AM - Thread Starter
Liked: 51
Don't forget to caulk as you go. I have learned this the hard way.
post #10 of 16 Old 03-22-2020, 04:01 PM
Red Five's Avatar
Quoted: 1160 Post(s)
Liked: 1042
Do you have more pictures and impressions?
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #11 of 16 Old 03-22-2020, 08:58 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 859
I picked up a new dewalt 20v jigsaw recently. It has a jet of air that blows sawdust away from the blade. I think its my favorite new feature.
Chris
post #12 of 16 Old 03-23-2020, 04:25 AM
johnson636's Avatar
Quoted: 1537 Post(s)
Liked: 1031
Chris
Is it a constant jet of air or in intervals?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #13 of 16 Old 03-23-2020, 04:37 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 859
It’s constant.
Chris
post #14 of 16 Old 03-23-2020, 04:41 AM
johnson636's Avatar
Liked: 1031
It’s constant.
Chris
Wow, that's very handy! I do struggle with impaired vision due to sawdust building on my cut line. Will you provide a model# or link to your jigsaw.
post #15 of 16 Old 03-23-2020, 04:48 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 859
Speaking of visibility, it shines a light on the line too.
https://www.dewalt.com/products/powe...l-only/dcs334b
Mine was actually a birthday present from my fiance. She isn’t thrilled about the giant subwoofers, but still supports my hobby, lol.
Chris
post #16 of 16 Old 03-24-2020, 12:33 PM
Red Five's Avatar
Liked: 1042
Your build thread has been added to the Devastator Index
This is the way...
