Volt 8 and 1099 popping sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-16-2020, 12:59 PM - Thread Starter
Liked: 0
Question Volt 8 and 1099 popping sound?
I have just finished building my 1099 and volt 8 speaker kits and they sound incredible. Only issue I have is that when pausing and unpausing a movie or simply changing the volume, they make a popping/crack noise. Is this normal, does every speaker do this. Like if i hold down the volume up or down it's like each increment the volume goes up it makes a popping noise. It does this also with pausing and un pausing. Bad connection? Speaker blown somehow?
ps my receiver is denon avrx1600h
Velocity Games is offline
post #2 of 13 Old 03-16-2020, 01:16 PM
johnson636's Avatar
Quoted: 1540 Post(s)
Liked: 1036
Does the popping/cracking sound come through all your speakers?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 13 Old 03-16-2020, 01:43 PM - Thread Starter
Liked: 0
It's hard to tell, I think it's mostly the surrounds (Volt-8s), but a little bit from the 1099 too
post #4 of 13 Old 03-16-2020, 02:30 PM
johnson636's Avatar
Liked: 1036
You can disconnect the surrounds and leave the LCR connected and play content. Then do the same for the surrounds. This way you can determine if the popping sound comes through all or some of the speakers.
post #5 of 13 Old 03-16-2020, 03:00 PM
eriksells916's Avatar
Quoted: 752 Post(s)
Liked: 274
What happens when you change sources? I agree with 636 above, disconnect speakers randomly and then maybe change sources too, especially if the main source is your cable box. I know they can cause a hum in the system, but clicking from each remote input seems different.
eriksells916 is online now
post #6 of 13 Old 03-16-2020, 04:09 PM
johnson636's Avatar
Liked: 1036
Yup. If the sound emanates through all the speakers, then I'd inspect the sources.
post #7 of 13 Old 03-17-2020, 06:23 AM
dtsdig's Avatar
Quoted: 1135 Post(s)
Liked: 1400
In my old life repairing consumer electronics equipment (lots of receivers and amps), this was usually caused by a defect in the AVR sending the popping or clicking noise into the audio path. Since all modern AVRs are using digital stepper type controls for volume and other adjustments instead of old-school potentiometers, sometimes those digital pulses can be carried into the audio path. It is very likely not your speakers.
dtsdig is offline
post #8 of 13 Old 03-17-2020, 08:15 PM - Thread Starter
Liked: 0
Thanks guys! It heavily depends on what I'm playing at the moment. It only does it for certain movie scenes or music, usually it's more apparent when there is a lot of bass happening.
post #9 of 13 Old 03-19-2020, 06:21 PM
JohnDean's Avatar
Quoted: 569 Post(s)
Liked: 268
Sounds like clipping or distortion to me. I had some cheaper dome MTM that would do this. I have no idea why yours is happening though.
JohnDean is offline
post #10 of 13 Old 03-20-2020, 07:21 AM
HFGuy's Avatar
Quoted: 240 Post(s)
Liked: 259
What speakers did you have before ? Remember the new speakers are like 99dB/w/m, you might just now be hearing a sound that was always there.
HFGuy is offline
post #11 of 13 Old 03-20-2020, 09:33 AM
DigiWega's Avatar
Quoted: 62 Post(s)
Liked: 77
I agree, this sounds like your AVR or your source material.
I would plug the speakers into another amp if you have one.
DigiWega is online now
post #12 of 13 Old 03-26-2020, 03:00 PM - Thread Starter
Liked: 0
I was just playing the movie Midway and in chapter 3 when all the planes are flying by and explosions are going off there seems to be a sustained bass note or something in the soundtrack. Whenever I pause the movie around there, the surround speakers (volt-8s) let out a loud pop when I pause and unpause during that scene. I am only at -22 for volume. Could it actually be a problem in my receiver, should I replace it?
post #13 of 13 Old 03-26-2020, 04:08 PM
johnson636's Avatar
Liked: 1036
Yes. That was suggested as a suspect earlier.
