Help needed for second Subwoofer - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By johnson636
  • 1 Post By johnson636
  • 1 Post By Red Five
post #1 of 12 Old 03-21-2020, 11:54 AM - Thread Starter
nanoodhaliwal's Avatar
Quoted: 89 Post(s)
Question Help needed for second Subwoofer
Hi Guys,
I am working on my home theater and need help to find a second subwoofer (design and subwoofer).
Current Subwoofer and other info
- I have one mini-Marty with UM18 and iNuke 6000DSP.
- Due to previous home space constraints, the woofer is installed on length side (2x2 side). Sub was laying flat on floor facing to the front.
- Can I design the other sub standing upright now ? or have to follow same design ?
- Both subs would go behind the projector screen.
- Any other design subwoofer which is better and will complement what I already have ?
- space behind screen is 2.5' (Room Dimensions W10' X H8' X L21')
- Which subwoofer ? UM18 ? LaVoce SAN184.03? any other ?
- Budget is flexible but not as flexible as NSW6021-6
- Don't listen to reference levels
- Future HT speakers would be from DISG (Kef's as of now)
Any help would be appreciated. Thanks in advance.
nanoodhaliwal is online now
post #2 of 12 Old 03-21-2020, 12:39 PM
johnson636's Avatar
Quoted: 1537 Post(s)
Liked: 1031
Devastator with LaVoce SAN214.50 21 or B&C 21DS115-4 21
Craig S King and OJ Bartley like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 12 Old 03-21-2020, 04:07 PM - Thread Starter
Quoted: 89 Post(s)
I don't think I have depth of 30" maybe mini Devastator?
Thanks for your reply.
post #4 of 12 Old 03-21-2020, 04:28 PM
johnson636's Avatar
Liked: 1031
Actually, I have two mini devastators They are a modified version that houses a 21.
Craig S King likes this.
post #5 of 12 Old 03-21-2020, 05:08 PM - Thread Starter
Quoted: 89 Post(s)
Great wall for time travel 😆!! Mini devastator looks promising :P what dimension you are using ?
post #6 of 12 Old 03-21-2020, 05:15 PM
johnson636's Avatar
Liked: 1031
post #7 of 12 Old 03-23-2020, 10:41 AM - Thread Starter
Quoted: 89 Post(s)
This fits my needs perfectly, I guess this would be my build with LaVoce SAN214.50 21". Am I on right track guys ?
post #8 of 12 Old 03-23-2020, 02:06 PM
johnson636's Avatar
Liked: 1031
Are you ready for the ride
post #9 of 12 Old 03-23-2020, 05:26 PM
Red Five's Avatar
Quoted: 1160 Post(s)
Liked: 1042
It has my vote! The Devastators are very articulate in delivery, but they can take that to down right brutal when called upon. I like my little Mini V1s, this box with a SAN is a big step up from that
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #10 of 12 Old 03-23-2020, 07:11 PM - Thread Starter
Quoted: 89 Post(s)
Thanks for you reply Red, really appreciate the work and effort you have put into for guys like me . How would you compare it to mini marty ? that is what I have right now.
post #11 of 12 Old 03-23-2020, 07:34 PM
Red Five's Avatar
Liked: 1042
Closet thing I had to the Mini Marty is my ported 21DS115. The Mini Devs are cleaner in presentation than even the B&C. I am running a lot less power on the Minis and they are positioned differently from the ported DS. Low end is pretty similar due to the trade-offs I made. I would take the Minis 9 times out of 10. The Version of the Devastator you are looking at should match the DS low end and beat it anywhere else. How quickly a sub gets to 30Hz from 20Hz is important due to room gain. The Devastators get up and moving faster than most ported rivals. I still like a 17Hz tune if possible.
OJ Bartley likes this.
This is the way...
post #12 of 12 Old 03-25-2020, 11:41 PM - Thread Starter
Quoted: 89 Post(s)
Thanks for your reply Red, looks like Dev's is the way to go.
