Pro Drivers for Home Speakers? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Promit
post #1 of 13 Old 03-21-2020, 08:32 PM - Thread Starter
brireeves629's Avatar
Quoted: 231 Post(s)
Liked: 97
I happened to purchase a pair of Celestion T5745A SP-1200 12” drivers from PE on a buyout that I had planned to use for something else and have changed my mind. I was wondering how these would work to build a pair of subwoofers or possibly putting them in a pair of diy tower speakers. Does the fact they are “Pro” drivers make a difference compared to home audio? I have also included a snapshot of the specs.
brireeves629 is offline
post #2 of 13 Old 03-22-2020, 07:08 AM
N8DOGG's Avatar
Quoted: 1432 Post(s)
Liked: 1693
They will work ok in a 40-50hz tuned ported cab.
N8DOGG is online now
post #3 of 13 Old 03-24-2020, 06:15 PM
A9X-308's Avatar
Quoted: 1913 Post(s)
Liked: 1631
Yeah, might be useful for that, more an MBM than a sub unless the OP is planning on usiing it in a car, but without knowing the Xmax, it's difficult to determine whether it's worth it. Most Celestion stuff has a modest Xmax.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #4 of 13 Old 03-25-2020, 05:28 AM
mustang guy's Avatar
According to the Q&A on the Parts Express page for the driver, the Xmax is 2.5mm.
edit - Here is the full Q&A on that driver:
What is the Xmax of this Celestion T5745A SP-1200 speaker?
: You can contact Celestion for technical support. Drdecibel at their domain (I'm not allowed to post it here)
Here's what he sent me.
"Xmax 2.5 mm
Coil winding ht 13 mm
Gap ht 8mm"
This is a very conservative rating based only on the amount of voice coil overhang. Speakers from other manufacturers with similar topology will be rated higher because they use a different formula, like overhang + a percentage of the gap ht, or by audio measurement up to an arbitrary amount of distortion (usually 10%).
A comparable speaker from another manufacturer would likely be rated between 3.3 - 5 mm depending on their method.
I modeled it, and here is what it looks like with the recommended enclosure size, with a 45Hz 2nd order HPF, and 100 watts, which keeps it within the 5mm xmax.
mustang guy is offline
post #5 of 13 Old 03-25-2020, 06:00 AM
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Suitable for Fronts, center and Rears, it would struggle when implemented as a sub
qguy is online now
post #6 of 13 Old 03-25-2020, 08:13 AM
Promit's Avatar
Quoted: 75 Post(s)
Liked: 38
DIYSG designs use a lot of pro woofers, you could do a modified version of one of those speakers.
Craig S King likes this.
Promit is online now
post #7 of 13 Old 03-25-2020, 12:20 PM - Thread Starter
Quoted: 231 Post(s)
Liked: 97
I was actually hoping it could be used as part of a 3-way design. Thanks for the information.
post #8 of 13 Old 03-25-2020, 02:30 PM
A9X-308's Avatar
Liked: 1631
It would be OK as the midbass in a 3 way, if you also ran subs.
As a general response to your header question, yes, there are many pro audio drivers that work very well in domestic designs and builds. I've been using little else for 20 years; JBL. PHL, BMS, B&C, Faital Pro, RCF, EV, Eminence, 18Sound, Emilar and Beyma for example, but it depends on the specific driver.
A9X-308 is offline
post #9 of 13 Old 03-25-2020, 07:04 PM
Mike Garrett's Avatar
Quoted: 13459 Post(s)
Liked: 11099
Here in the US, we also have Acoustic Elegance. Fantastic products.
Mike Garrett is offline
post #10 of 13 Old 03-25-2020, 09:46 PM
A9X-308's Avatar
Liked: 1631
"Xmax 2.5 mm
Gap ht 8mm"
But it still doesn't really tell you all that much. At what excursion will the distortion become objectionable for example? Motor and suspension linearity determines that. I was just looking for an idea of what SPL it might be capable of to get an estimate of whether it was a potentially useful driver.
I know. I bought my first 8, 4 TD10M and 4 TD15X not long after John took over from Nick in 2008. Got another 4 TD15S locally secondhand a few years later. I agree, they're excellent. Until recently the 15S were used 2/side in my mains and the 15X as midbass in 4 surrounds. The 10M are reserved for another project next year.
However, I don't really consider them 'pro' drivers in the usual sense, as whilst the non M driver have good Xmax, the Xmech is lower than I'd want in a pro driver.
A9X-308 is offline
post #11 of 13 Old 03-26-2020, 11:02 AM
Liked: 11099
TD18H+
Xmax: 14 mm(peak)
Xmech: 25 mm(peak)
Looks pretty good to me.
post #12 of 13 Old 03-26-2020, 04:12 PM
A9X-308's Avatar
Liked: 1631
TD18H+
Xmax: 14 mm(peak)
Xmech: 25 mm(peak)
Still a low Xmech/Xmax ratio compared to many pro drivers.
Recones are also not easily available and I'm not convinced of the rated power handling as John doesn't state which methodology he uses, eg, AES1994.
A9X-308 is offline
post #13 of 13 Old 03-31-2020, 04:39 AM
eXa
eXa's Avatar
Quoted: 31 Post(s)
Liked: 36
eXa is offline
