UM-18 Selaed to Ported Help - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 5 Post By johnson636
  • 1 Post By OJ Bartley
  • 1 Post By Augerhandle
  • 1 Post By johnson636
post #1 of 8 Old 03-22-2020, 08:59 AM - Thread Starter
Liked: 0
Purchased 2x 4cft PE bundle w/ a Um18 back in September been loving it, but missing some of the impact I had from ported.
I had a friend over recently with his pair of SVS PB4000 and really enjoyed them in comparison. Its hard for me to explain but I liked the way they pressurized.
Moving on
I want to build 2x Mini-Marty for UM 18's. I have pretty much an unlimited footprint.
But Mini Marty laying sideways seems to be the best fit for my space.
Here is the thing, I am a total noob.
I plan on renting a jig saw and table saw from a local company, and grabbing MDF from Home Depot.
MDF https://www.homedepot.ca/product/met...-97/1000167404
Cut list seems it should be
But this doesn't include bracing?
I have clamps and glue from the sealed setup.
But really any tips would be much appreciated.Wife might not let me make another box in the future.
Side questions, any thoughts on what to do with the 2 old 4cft boxes?
Xenccrx is offline
post #2 of 8 Old 03-22-2020, 09:18 AM
johnson636's Avatar
Quoted: 1537 Post(s)
Liked: 1032
Convert them into 35-40Hz ported cabs and purchase 2 PA460 for them
Once you finish building your mini marty and have your Ported PA460s completed, then have your friend bring his PB4000 back over there to be put to shame
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 8 Old 03-22-2020, 01:34 PM
OJ Bartley's Avatar
Quoted: 593 Post(s)
Liked: 701
If you're going to ported and have room to spare, have you considered the Devastator horn designs? They would definitely be wort a look.
johnson636 likes this.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
post #4 of 8 Old 03-24-2020, 07:08 PM
Quoted: 951 Post(s)
Liked: 777
Build a pair of LLTs and then build the mid-bass monsters suggested above...
sigpig is online now
post #5 of 8 Old 03-25-2020, 01:00 AM
Augerhandle's Avatar
Quoted: 1446 Post(s)
Liked: 1421
...Side questions, any thoughts on what to do with the 2 old 4cft boxes?
Make them into mid-bass modules.....
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #6 of 8 Old 03-25-2020, 03:43 AM
johnson636's Avatar
Liked: 1032
Well, you could give them to me. I'm sure I'd find something to do with them
post #7 of 8 Old 03-25-2020, 03:47 AM
johnson636's Avatar
Liked: 1032
Has anyone built a devastator with a UM18-22? Would be interesting for sure.
Craig S King likes this.
post #8 of 8 Old 03-25-2020, 05:15 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 860
UM doesn’t model well for dev, very peaky at port and horn tune.
a77cj7 is online now
