Mini Marty Cut Sheet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-23-2020, 01:49 PM - Thread Starter
Liked: 0
I'm very new to this page. Could someone please assist me in finding the cut sheet for Mini Marty's? One that I could plug into a CNC. One with UM18 hole and recess portion would be super! Thank you!
Mandy0766 is offline
post #2 of 8 Old 03-23-2020, 02:01 PM
johnson636's Avatar
Quoted: 1533 Post(s)
Liked: 1027
Here you go. (G) on the cutlist has a typo. It should be 2 bottom rails instead of 1
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 8 Old 03-23-2020, 02:05 PM - Thread Starter
Liked: 0
Sir, Is this using 3/4" material thickness? Just want to make sure. Thanks again!
post #4 of 8 Old 03-23-2020, 02:07 PM
johnson636's Avatar
Liked: 1027
Yes
post #5 of 8 Old 03-24-2020, 09:09 AM
Quoted: 12 Post(s)
Liked: 4
what is the tuning of the box?
bribassguy is offline
post #6 of 8 Old 03-24-2020, 09:30 AM
johnson636's Avatar
Liked: 1027
I believe the minimarty is tuned to 17Hz.
post #7 of 8 Old 03-24-2020, 10:26 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Hornresp models it at 18.5hz with that cutlist.
Chris
a77cj7 is offline
post #8 of 8 Old 03-24-2020, 11:48 AM
smcmillan2's Avatar
Quoted: 1067 Post(s)
Liked: 906
Tunes listed on the first page of the Marty Sub FAQ: https://www.avsforum.com/forum/155-d...tysub-faq.html
John recovered many of the missing images (cut lists) awhile back: https://www.avsforum.com/forum/155-d...l#post57121996
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
