2 different subs with the same port tuning - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By DavidK442
  • 1 Post By Vergiliusm
post #1 of 6 Old 03-23-2020, 09:09 PM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Two drivers, one has an FS of 15hz and the other has an FS of 25hz, if both drivers are placed in two different enclosures with the same port tunings at 20hz, Will the driver with the 15Hz FS have a better response below 20 hz?
qguy is online now
post #2 of 6 Old 03-23-2020, 09:28 PM
DavidK442's Avatar
Quoted: 896 Post(s)
Liked: 758
This feels like a trick question as I don't think you have provided enough information to answer.
There are multiple parameters that impact the low frequency output of a driver in a particular box. QTS, VAS, XMax, etc.
You would need to model both drivers using something like WinISD to answer the question.
johnson636 likes this.
DavidK442 is online now
post #3 of 6 Old 03-23-2020, 10:15 PM - Thread Starter
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Lets assume everything else is equal will the driver with lower FS play better considering both are tuned to 20hz?
Will install Winsd later - thanks
qguy is online now
post #4 of 6 Old 03-24-2020, 03:08 AM
johnson636's Avatar
Quoted: 1537 Post(s)
Liked: 1031
Sooner rather than later.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 6 Old 03-24-2020, 08:01 AM
Vergiliusm's Avatar
Quoted: 279 Post(s)
Liked: 531
Well, everything else wouldn't be equal. Compliance and mass would be different, hence the different Fs'. The admonition to get familiar with WinISD is important because it will make the relationships between drivers and their parameters less mysterious, and let you compare and optimize based on your needs/goals.
mustang guy likes this.
"Rock and roll is alive and alright" Sloan
Vergiliusm is online now
post #6 of 6 Old 03-24-2020, 10:23 AM
Chris Popovich's Avatar
Quoted: 326 Post(s)
Liked: 287
You asked a question that has some different answers depending on what you assume.
What's that mean? To drop the Fs and keep everything else equal, the easiest way to is to add some mass to the cone. Then change other driver parameters as they falls out from the one change (compliance/etc); there is no such thing as two drivers with same everything except Fs.
Anyway, if we lower the Fs via added mass, it will have a little more output at tuning. Primarily this is a "normalized response" artifact, i.e. level matched. Really you have a touch MORE output right at tuning and LESS output up top as governed by increased mass.
Attached is a pic of an ultimax in 11cuft box tuned to 20hz, standard and a cone with about an extra pound of mass added to it.
Name:	added mass lower fs.jpg
Chris Popovich is online now
