FI Audio HT-1 vs HT-3 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By ratm
  • 1 Post By Russdawg1
  • 1 Post By markmon1
  • 2 Post By Gorilla Killa
  • 1 Post By a77cj7
  • 3 Post By neo_2009
post #1 of 20 Old 03-26-2020, 11:33 AM - Thread Starter
Liked: 0
I am looking at the 2 of these for building a pair of 18 sealed subs and wondering of there is a big difference i am using a 1500W rms amp for each. If you have alternatives i would be willing to hear those out as well and if i am not satisfied with sealed i will probably be building ported subs but no bigger than a Johnny Sub.
Ed
emcnicholas is offline
post #2 of 20 Old 03-26-2020, 01:27 PM
ratm's Avatar
Quoted: 286 Post(s)
Liked: 117
Ed
I built dual 6 cubic foot sealed subs using the HT3. I am using a Nx600oD for power (one per channel) and they absolutely pound and have crazy output. I will be using them again when I build 2 - 4 more.
emcnicholas likes this.
ratm is online now
post #3 of 20 Old 03-27-2020, 02:47 AM
Quoted: 2013 Post(s)
Liked: 1645
Um18 is $300 and practically identical.
Craig S King likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 20 Old 03-27-2020, 03:00 AM
markmon1's Avatar
Quoted: 6197 Post(s)
Liked: 4243
I don't think so. The UM18 is fantastic for the money, but the Fi is a beast. For one thing, the Fi offers a lot more cone travel with 34mm xmax vs 22 on the UM18. The Fi is also rated 2dB more efficient. The Fi has *double* the power rating at 2000 watts RMS vs 1000 RMS on the UM18. Based on power handling and efficiency, a single Fi UM18 should be able to put out more SPL than 2 UM18's. I love Fi speakers.
neo_2009 likes this.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #5 of 20 Old 03-27-2020, 03:24 AM
Gorilla Killa's Avatar
Quoted: 1596 Post(s)
Liked: 2362
The Fi don't have shorting rings or share Le spec. Inductance hump will be apparent compared to the UM
JohnDean and Trimlock like this.
Gorilla Killa is offline
post #6 of 20 Old 03-27-2020, 06:03 AM
JohnDean's Avatar
Quoted: 569 Post(s)
Liked: 268
Everyone forgets this. It's not just power and xmax.
JohnDean is offline
post #7 of 20 Old 03-27-2020, 06:14 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 860
Uhh, the ht-3 specs do list a shorting ring.
I messaged then about Le when I was considering it for use in a v3. The ht-3 is 2.5-2.6mh.
Chris
a77cj7 is online now
post #8 of 20 Old 03-27-2020, 10:04 AM
Vergiliusm's Avatar
Quoted: 280 Post(s)
Liked: 532
The HT-1 looks similar to the UM and is around the same price with the sale. If you got the extra $400, why not do the HT-3?
I've never used a Fi, but folks who have seem to happy with them. I was thinking about trying one of the new Adire subs as part of a "blast from the past" build, but they're not as good of bang for the buck as the Dayton drivers.
"Rock and roll is alive and alright" Sloan
Vergiliusm is online now
post #9 of 20 Old 03-27-2020, 10:08 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 860
You’re not going to match bang-for-buck of the Dayton drivers, don’t even try.
I chose to run high end, made-in-usa drivers, but don’t pretend its cost effective. I use HST’s in my theater. Would have picked up a pair of HT3’s for my living room setup, but they won’t fit my recesses in my old 4cf boxes. So more HST’s it is.
Chris
post #10 of 20 Old 03-27-2020, 10:32 AM
Vergiliusm's Avatar
Quoted: 280 Post(s)
Liked: 532
True, true.
The HST's are beasty--great for low tuned ported enclosures with a lot of power, but could go either way. If I had the coin, or rather if I wanted to part with it, it'd be my first choice.
post #11 of 20 Old 03-28-2020, 07:26 AM
ratm's Avatar
Quoted: 286 Post(s)
Liked: 117
Chris
This and this. I knew I wasn't getting the most cost effective build by not using the Dayton's. More important to me was Fi Car being 100% American made.
ratm is online now
post #12 of 20 Old 03-30-2020, 12:46 PM
neo_2009's Avatar
Quoted: 374 Post(s)
Liked: 291
It depends on where you're from.
In Europe, and particularly in the UK, the difference between the HT3 and the UM18 is much smaller (500£ vs 350£ ??).
neo_2009 is offline
post #13 of 20 Old 03-30-2020, 01:03 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 860
This is true. But in your case, avoid both. You can do it for cheaper with some lavoce san214.50’s.
Chris
post #14 of 20 Old 03-30-2020, 03:38 PM
neo_2009's Avatar
Quoted: 374 Post(s)
Liked: 291
Chris
It depends, doesn't it ?
As good as the Lavoce is, it cannot match neither of those bellow 30Hz.
I also share your perspective, i also prefer to use high-end drivers (i have two BMS 18N862) ... in the long run, these drivers will run for more than a decade, and with that in mind, an extra $$ is insignificant ... its always preferred to save for a bit longer and buy the best you can afford.
neo_2009 is offline
post #15 of 20 Old 03-30-2020, 03:53 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 860
The lavoce will actually beat the um below 30hz as well. The extra cone area makes up for the reduced excursion.
Fully driven, the ht-3 will still win.
From what I’ve heard if prices in europe, isn’t the lavoce cheaper than the um?
Chris
post #16 of 20 Old 03-30-2020, 04:30 PM
neo_2009's Avatar
Quoted: 374 Post(s)
Liked: 291
The data-bass.com review seems to indicate that the UM still beat the lavoce bellow 30HZ ...
These are the cheapest prices in Europe, but there is no availability:
- SAF214.50: 360€
- SAN214.50: 424€
Here one of the best prices in Europe for the UM18: 409€.
neo_2009 is offline
post #17 of 20 Old 03-30-2020, 04:41 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 860
- SAF214.50: 360€
- SAN214.50: 424€
Just looked at databass. Looks to me that they are tied at 106db long term at 20hz in the same box. The lavoce gains from there.
I’ll believe you on the pricing. I was just going by what other European members had reported.
I’d still pay the slight extra for the more efficient 21”
Chris
post #18 of 20 Old 03-30-2020, 04:46 PM
neo_2009's Avatar
Quoted: 374 Post(s)
Liked: 291
I know, i just posted them as it may help others
Between the UM18 and the Lavoce 21", i would also go with the Lavoce
a77cj7, MKtheater and jujuman200 like this.
neo_2009 is offline
post #19 of 20 Old 03-31-2020, 07:16 AM
MKtheater's Avatar
Quoted: 2678 Post(s)
Liked: 3063
Get the 21, about the same low end and more midbass at the same price!
Building the room, speakers, and subs.
MKtheater is online now
post #20 of 20 Old 03-31-2020, 07:54 AM
N8DOGG's Avatar
Quoted: 1432 Post(s)
Liked: 1693
The 21"... It's an easy choice.
N8DOGG is offline
