GSG-Sub Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-29-2020, 02:04 PM - Thread Starter
Liked: 0
GSG-Sub Questions
I am finishing 2 mini builds with UM-18. Can I use them on there sides?
Plan on L/C/R being the 1099 can I set the 1099 on top of the 2 subs for the center and L/R on each side of the sub?
So Left then 2 mini on there sides with center 1099 on top and then the right 1099.
New to all of this looking for input.
Thank you
Upsidedown2 is offline
post #2 of 3 Old 03-29-2020, 02:12 PM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
GSG-Sub Questions
Thank you
That will work fine.
I suggest using some foam to isolate the speakers from the subs.
You want the waveguides of the 1099’s to be at ear level if possible.
Chris
a77cj7 is offline
post #3 of 3 Old 03-29-2020, 04:35 PM
Augerhandle's Avatar
Quoted: 1454 Post(s)
Liked: 1423
Thank you
https://www.amazon.com/gp/product/B00JJ191Z6/
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
