Do I need to fix my port? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Augerhandle
post #1 of 10 Old 03-29-2020, 04:06 PM - Thread Starter
Quoted: 52 Post(s)
Liked: 6
I am in the process of building a subwoofer box. There are 3 ports that are about 36" long and makes a 90' degree bend at around the half way point in the design. Somehow in my glue up, I didn't notice that one of the ports veered off path and is about an 1/8"-3/16" wider than it should be at the speaker side, ending up at the correct width at the turn. The glue had already set and I had shot brads and a couple of screws through it as well. I really don't want to tear it apart.
Am I overreacting worrying about this, or will it be fine?
TStubb is offline
post #2 of 10 Old 03-29-2020, 04:14 PM
Augerhandle's Avatar
Quoted: 1456 Post(s)
Liked: 1424
I assume they are slot ports, and you're describing the port rail positions? It'll be fine.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #3 of 10 Old 03-29-2020, 04:30 PM - Thread Starter
Quoted: 52 Post(s)
Liked: 6
Yeah its basically a slot port, or ports I should say. It was the far piece of the end port that drifted when I was tacking it so it did not affect the dimensions of the port next to it. I didn't know if I needed to use some bondo or something to fill in the extra 1/8" or so that it drifted.
TStubb is offline
post #4 of 10 Old 03-29-2020, 04:33 PM
johnson636's Avatar
Quoted: 1729 Post(s)
Liked: 1234
It would be helpful if you could post a picture.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 10 Old 03-29-2020, 05:01 PM - Thread Starter
Quoted: 52 Post(s)
Liked: 6
You are seeing a rear shot of the box. The ports turn toward the front and exit the box there.
Name:	Subwoofer Box Back.jpg
TStubb is offline
post #6 of 10 Old 03-29-2020, 05:21 PM
Quoted: 553 Post(s)
Liked: 471
Its fine, at worst it'll result in a .5hz lower tune.
Trimlock is offline
post #7 of 10 Old 03-29-2020, 05:23 PM
johnson636's Avatar
Liked: 1234
Actually, I was referring to a pic of your enclosure itself.
post #8 of 10 Old 03-29-2020, 05:46 PM
a77cj7's Avatar
Quoted: 971 Post(s)
Liked: 1042
With that large of a port, thats a very small error. I wouldn’t worry about it at all. My guess would be raise tune 0.1hz, lol.
Chris
a77cj7 is online now
post #9 of 10 Old 03-29-2020, 06:31 PM
Samps's Avatar
Quoted: 1334 Post(s)
Liked: 999
What is in that blue box area in the middle? Is there another speaker built into this sub?
Samps is offline
post #10 of 10 Old 03-29-2020, 11:59 PM
Liked: 1424
That's for his center Channel speaker. https://www.avsforum.com/forum/155-d...l#post59110632
TStubb likes this.
