Mini Marty - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By jbrody
  • 1 Post By a77cj7
  • 1 Post By sirjaymz
  • 1 Post By jbrody
  • 2 Post By jbrody
post #1 of 23 Old 03-30-2020, 08:32 AM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Mini Marty
I was all set to just build a mini Marty at the measurements in the original FAQ starting this morning since Im off work this week.... Damn COVID... any way I went an remeasured my room and screen distance and thought I better ask the experts their thoughts. I made a sketchUp or my room (with no skill at this) will post that.. My room is above the garage and is a vaulted attic so slanted walls as shown.. My screen is hung on the long wall hanging form one of the angled walls and is hanging 25" from the back wall ( closer as the wall goes up and angles in)
I was going to build a pretty "stock" mini Marty and park it behind the screen with ports under the screen but the speaker may be behind the speaker. I also attached my planned cutout list. I have been getting help on the main Marty FAQ thread but thought I would start my own build.. This will be a quick and dirty build cause of time constraints
Jason
ID:	2703456   Click image for larger version
Name:	Screen Shot 2020-03-30 at 8.31.12 AM.png
jbrody is offline
post #2 of 23 Old 03-30-2020, 09:47 AM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
I’ll link this over here as well. Model of proposed box and driver:
Originally Posted by a77cj7 View Post
Modeled it in HR. Looks good.
UM18 on 1000w
18hz 2nd order HPF
Tune: 18.9hz
Cone excursion: 19mm
Port velocity: 17m/s
On 1000w, you can take the hpf down to 15hz without excursion or velocity going excessive.
Chris
a77cj7 is offline
post #3 of 23 Old 03-31-2020, 08:01 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
So i jumped in head first. I know just another build, but it is fun for me so why not post it. I’m lucky to have a Father in Law with wood working knowledge and a sweet shop and willing to teach. This MDF mini Marty is standing with no glue and no clamps just held together with the Festool dominos. What a sweet system. We decided to in set the port rails 1/4 in. Into the bottom and back Lee should be able to finish fitting and building the port and then just slide it in with glue. Excited to continue the journey
J
jbrody is offline
post #4 of 23 Old 04-01-2020, 06:54 AM
johnson636's Avatar
Quoted: 1715 Post(s)
Liked: 1209
J
Awesome! What driver will you be using?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #5 of 23 Old 04-01-2020, 07:00 AM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
J
Always happy to see another build. Keep posting pics!
Chris
a77cj7 is offline
post #6 of 23 Old 04-03-2020, 11:27 AM
Augerhandle's Avatar
Quoted: 1454 Post(s)
Liked: 1423
J
You made the port rails taller, so the port height is still 3" with the 1/4" dado, right? Don't forget to paint the inside of the ports black while you can still get to them.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #7 of 23 Old 04-03-2020, 12:00 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Absolutely 3.25 inch rails. I’m actually shopping for paint today. Plan on spraying with primer to seal then do a black color for final. Glued up the port and now able to slid it in and out while fitting up bracing. Then on to prime and glue up and final paint. Excited. I opened the Ultimax 18 last night and hard to imagine its size until you struggle it out of the box haha.
A few more pics attached
So i jumped in head first. I know just another build, but it is fun for me so why not post it. I’️m lucky to have a Father in Law with wood working knowledge and a sweet shop and willing to teach. This MDF mini Marty is standing with no glue and no clamps just held together with the Festool dominos. What a sweet system. We decided to in set the port rails 1/4 in. Into the bottom and back Lee should be able to finish fitting and building the port and then just slide it in with glue. Excited to continue the journey
J
ID:	2705264   Click image for larger version
ID:	2705266   Click image for larger version
Bnaan likes this.
jbrody is offline
post #8 of 23 Old 04-03-2020, 02:29 PM
johnson636's Avatar
Liked: 1209
It's coming along nicely
post #9 of 23 Old 04-21-2020, 09:29 AM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Well. Got some more work done. Box is glued up bracing is in baffled are cut and fit. Getting ready to Install the liner and start finish sanding and paint. I appreciate the help everyone has given.
I have 3 1299 kits showing up this week so i guess I’m all in to the rabbit hole
Originally Posted by johnson636 View Post
It's coming along nicely[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
ID:	2713634   Click image for larger version
ID:	2713636   Click image for larger version
jbrody is offline
post #10 of 23 Old 04-21-2020, 09:32 AM
johnson636's Avatar
Liked: 1209
Looking good
post #11 of 23 Old 04-21-2020, 10:27 PM
Liked: 1423
Nice work! I think that's the first time I've seen anyone use the place holder bracing from the spreadsheet. Kreg screws, no less.
Take your time on the 1299s, and make them gorgeous. I'm looking forward to what you come up with.
post #12 of 23 Old 04-22-2020, 08:44 AM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Thanks haha, does the bracing look ok? I glued and kregjig at each end and glued and stapled at each joint. I had planed on doing window bracing but I had a few braces I used for place holders and then I just thought why not do it that way......
Also when placing the insulation/padding (I bought a pad from walmart to cut up?) do you/would you wrap the bracing or just put it on the wall avoiding to close to the port opening?
J
jbrody is offline
post #13 of 23 Old 04-22-2020, 09:35 AM
Liked: 1423
With ported, you shouldn't need any lining, but I don't think it will hurt. When lined, most people just put it on the inside walls, avoiding the port area by the width of the port or more.
post #14 of 23 Old 04-22-2020, 10:53 AM
Witchboard's Avatar
Quoted: 222 Post(s)
Liked: 204
One thing I would have changed on my speakers is I would have padded the braces where they come in contact with the speaker wire. I had some speakers make a buzzing noise and I figured out it was the cable and bracing vibrating against each other.
Rumble & Frenzy - My Mini-Marty Build
Screaming Eagles - My Fusion-15 Sentinel Build
Witchboard is offline
post #15 of 23 Old 04-22-2020, 11:04 AM
a77cj7's Avatar
Quoted: 968 Post(s)
Liked: 1039
Foam pipe insulation around the speaker wire works well to prevent this.
Chris
Augerhandle likes this.
a77cj7 is offline
post #16 of 23 Old 04-22-2020, 11:13 AM
Witchboard's Avatar
Quoted: 222 Post(s)
Liked: 204
Yeah, I just saw that in another thread and thought that was pretty slick.
post #17 of 23 Old 04-22-2020, 12:47 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Chris
Ah nice suggestion thanks
jbrody is offline
post #18 of 23 Old 04-22-2020, 01:09 PM
sirjaymz's Avatar
Quoted: 513 Post(s)
Liked: 625
Ok... hold the phone .. !! where is THIS shop?! I see so many clamps, table saw, toolbox, drill press, and router.. not much you can't do in that place !! very nice...
We are expecting to see great things on those 1299's as well
Craig S King likes this.
HT1.0 | HT2.05
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82II/RC-64II/RS-42II/RS-41II/RB-61II/CDT3800-C-II
sirjaymz is offline
post #19 of 23 Old 04-22-2020, 08:43 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
We are expecting to see great things on those 1299's as well [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
Haha ya I married into an awesome father in law with a shop that he chose that happened to come with a house for his wife to live in. Then he continuously keeps filling it with more and more sweet tools. It’s a lot of fun but why wife doesn’t understand why i want to spend so much time with her dad haha
jbrody is offline
post #20 of 23 Old 04-25-2020, 07:49 AM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Getting closer. Final glue up and got some wall liner put in. Just need to do some final sanding and paint. Click image for larger version
jbrody is offline
post #21 of 23 Old 04-28-2020, 09:15 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
routing bondo and sand paper. Soon on to duratex. Thinking about the leather technique that parts express has instructions on? Any thoughts on this?Click image for larger version
jbrody is offline
post #22 of 23 Old 05-11-2020, 08:14 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
Got it painted and wired up. Now to learn how to use REW. Thanks everyone with the help so far
jujuman200 likes this.
jbrody is offline
post #23 of 23 Old 05-11-2020, 08:31 PM - Thread Starter
jbrody's Avatar
Quoted: 16 Post(s)
Liked: 8
It’s size is impressive once you get it into the theater
jujuman200 and sirjaymz like this.
jbrody is offline
