What would your preferred DIY gear be for a 7.2.4 system - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #1 of 35 Old 03-31-2020, 05:20 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 5
I am in the beginning phases of designing a house, complete with a theater room. Breaking ground will be a few years away yet, but I’m trying to get a design now that I can continually modify and start the planning and budgeting. A theater room is going to be high priority in this new house. It will either be in a bonus room over the garage (most likely), or in a basement. I’ve got a design Ive come up with for the theater room that is 22x30, with 2 rows of seating, and a bar behind the 2nd row. Movies 25%, gaming15%, music, sports, and entertaining 60%.
With all that being said, I’m curious to see what everyone’s thoughts are on the “best” DIY gear. If you had a clean slate, what would you want your ideal set up to look like? I’ve been researching the site a lot over the past few months, and there’s a ton of information scattered which makes it difficult to search through.
LCR: DIYSG 1099s
Would 1299s have more output and overall sound “better”? Titans? HTM’s?
Surrounds and Atmos : HTM-10s
Would HTM-12s be better? Volts? 4 or 6 speaker Atmos?
Subwoofers: HST-18 MKIII in ported enclosures
Would FI HT-3 be a better option? I would like to make 2 dual enclosures to resemble JTR captivator 4000s
Amps: iNUKE 12000s or Sinbosen FP20000 for subs, Emotiva for mains and surrounds.
Bryce2320 is offline
post #2 of 35 Old 03-31-2020, 05:30 PM
BassThatHz's Avatar
Quoted: 4016 Post(s)
Liked: 4533
I highly suggest you place it under the garage, if you play bass at the levels I enjoy...
I assume you are building 4 HST-18's, given the quad channel fp20k.
I wouldn't recommend the inuke for those woofers (inuke is too weak!)
The FP20k on the other hand should be great, if not a bit overkill, which is always a good thing in this hobby.
If you really want to "feel the bass" then I'd recommend quad B&C 21's with a 2nd fp20k if you can.
Car and HT subs are great for generating earthquakes but not so much for the >40hz-300hz which is where 90% of the bass is (and 100% of the chestkick/drums/explosions/rock/metal/dance/pop).
BassThatHz is offline
post #3 of 35 Old 03-31-2020, 05:30 PM
johnson636's Avatar
Quoted: 1733 Post(s)
Liked: 1242
What will your budget be for this project? Asking "What would your preferred DIY gear be for a 7.2.4 system" can get really, expensive really quickly around these parts.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #4 of 35 Old 03-31-2020, 05:36 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 5
The budget for the equipment will be around 15-20k. Hoping to get the theater done for around 30k.
post #5 of 35 Old 03-31-2020, 05:56 PM
johnson636's Avatar
Liked: 1242
Option 1 Quad NSW 21 Ported or Devastator
Option 2 two ported HS24 and two NSW 21 Devastator.
Amplification FP20000Q or SpeakerPower SP2-12000 HT for silent operation
Jk7.2 and BP1Fanatic like this.
post #6 of 35 Old 03-31-2020, 06:15 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 426
Option 2: two ported HS24 and two NSW 21 Devastator......YES PLEASE ALL DAY LONG!!!
IJS....
Juju
johnson636 and BP1Fanatic like this.
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #7 of 35 Old 03-31-2020, 06:22 PM
johnson636's Avatar
Liked: 1242
IJS....
Juju
That really would be a killer setup. Actually, I've thought about ordering a NSW 21, but I'd have to build another Dev that works best with that driver.
jujuman200 likes this.
post #8 of 35 Old 03-31-2020, 06:24 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 426
Yep..... That system would be my system on steroids..... I'm currently rocking the stuff in my sig..... AWESOME. That system would just be SICK!!!!
Juju
Red Five likes this.
post #9 of 35 Old 03-31-2020, 06:30 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 5
Amplification FP20000Q or SpeakerPower SP2-12000 HT for silent operation[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
IJS....
Juju
Is there a benefit to doing 2 of each instead of 4 of one or the other?
post #10 of 35 Old 03-31-2020, 06:37 PM
johnson636's Avatar
Liked: 1242
Don't get me wrong, 4 devastators loaded with NSW 21 would be killer in its own right, but 2 20 cuft ported HS24s would have more low end output due to massive Xmax. The NSW 21 would dominate above 40Hz.
post #11 of 35 Old 03-31-2020, 07:21 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 426
Exactly this ^^^^^ AND you can vary the mix to get the exact tone that you want for your space...
Juju
post #12 of 35 Old 03-31-2020, 07:25 PM
Red Five's Avatar
Quoted: 1280 Post(s)
Liked: 1199
I would wait and see how the Alpha loaded with an NSW does port plugged. Jared said it was tactile on concrete with the 19Hz. Four of those would just be bonkers either way!
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #13 of 35 Old 03-31-2020, 08:32 PM
MKtheater's Avatar
Quoted: 2733 Post(s)
Liked: 3176
24 all the way.
Building the room, speakers, and subs.
MKtheater is online now
post #14 of 35 Old 04-01-2020, 10:03 AM
BlueGhost's Avatar
Quoted: 82 Post(s)
Liked: 52
With that large of a space, I think the Titans would be a good call for LCR.
I tend to go conservative on surrounds/atmos. I would say HT-10s for surrounds and volt 10s for atmos. Save a little money here, spend a little more on the subs.
BlueGhost is offline
post #15 of 35 Old 04-01-2020, 10:05 AM
johnson636's Avatar
Liked: 1242
If I'm not mistaken, EricH will be coming out with a Titan 18. I'd go that route or the 1899 lcr
18Hurts likes this.
post #16 of 35 Old 04-01-2020, 07:03 PM
Quoted: 241 Post(s)
Liked: 205
I thought he discontinued the 1899.
Randy_J is offline
post #17 of 35 Old 04-01-2020, 10:50 PM
Augerhandle's Avatar
Quoted: 1456 Post(s)
Liked: 1424
...I’ve got a design Ive come up with for the theater room that is 22x30, with 2 rows of seating, and a bar behind the 2nd row. Movies 25%, gaming15%, music, sports, and entertaining 60%. ...
With music, sports, and entertaining at 60%, I would recommend getting creative with your seating, and moving away from "theater" mode. I'm thinking swivel rockers arranged in semicircles, so guests can visit, but still swivel into position for movies, sports, or concert videos. Speaker choices remain the same.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #18 of 35 Old 04-02-2020, 04:35 AM
Jk7.2's Avatar
Quoted: 1819 Post(s)
Liked: 3349
Originally Posted by Red Five View Post
I would wait and see how the Alpha loaded with an NSW does port plugged. Jared said it was tactile on concert with the 19Hz. Four of those would just be bonkers either way!
What I was trying to say is tactile on concrete! I suggest 4 Alphas. Nsw’s are fun.
Jk7.2 is online now
post #19 of 35 Old 04-02-2020, 05:28 AM
johnson636's Avatar
Liked: 1242
Wow, I didn't know that.
post #20 of 35 Old 04-02-2020, 06:42 AM
lawdogx's Avatar
Quoted: 214 Post(s)
Liked: 249
Hey Bryce, great project, and it sounds like you’re on the right track and asking all the right questions! Addressing this one directly, the answer is “perhaps.” Different sub boxes and different drivers have their individual strengths and weaknesses. Some large ported enclosures excel at making low-end bass but are far less efficient in mid and upper bass. Other designs, like the devastators, while good at the low end, but are absolutely insane at producing mid bass. Enough identical units of either design properly EQ’ d and placed strategically can fill in the entire bass spectrum nicely. But mixing the strengths of different designs could allow you to do the same thing with fewer subs and more “tuneability.”
A second advantage comes into play when you consider the most important factor - your room. Nobody’s room is like anybody else’s, and yours will likely have locations that deliver one area of bass better than other locations. One corner may give you tons of mid and upper bass but have a huge hole at 20-30 hz. Another may be great down low but just eat bass in a higher spectrum. Putting a sub that excels at making the spectrum of bass that a specific room location delivers could allow you to get the most from both your subs and your room.
I’ve done it both ways, and both ways can sound great. However, I’ve gotten my best results mixing designs and placing each design in a location that plays to its strengths.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is offline
post #21 of 35 Old 04-02-2020, 07:32 AM
Quoted: 241 Post(s)
Liked: 205
I just looked and they are in the clearance section. I would guess that once the run out if someone really wanted them you could still get some but might cost more. I believe they are 908$ each though on the limited supply clearance page.
Randy_J is offline
post #22 of 35 Old 04-02-2020, 08:27 AM
johnson636's Avatar
Liked: 1242
I didn't even know they had a clearance section
post #23 of 35 Old 04-02-2020, 11:57 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 5
Thanks for the feedback so far. Here’s a sketch of what I’ve got dreamed up in my head so far. I think there should be room on the sides of the bar area to put a sub if need be. Would be nice to keep everything behind the screen though.
If I decide on speakers and subs, I may start building those and use them in my current garage where I have a 150” screen, with 4 Revel 8” in ceiling speakers.
Are the Titans better speakers then the 99 series?
post #24 of 35 Old 04-02-2020, 12:18 PM
johnson636's Avatar
Liked: 1242
That is a very subjective question. Each has its strengths and weaknesses.
post #25 of 35 Old 04-02-2020, 01:01 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 5
I knew better then to use that word....
I have not had the chance to listen to any DIY audio gear, and probably will not before buying. I think I am more concerned with smooth and clear highs at reference levels. I will have plenty of subwoofer power to take care of the LFE. What are the pros and cons of each if you have experience with both? Thanks
post #26 of 35 Old 04-02-2020, 04:10 PM
Quoted: 12 Post(s)
Liked: 5
Is there a thread on this anywhere?
Sent from my SM-N975U using Tapatalk
Jefro6996 is online now
post #27 of 35 Old 04-02-2020, 04:32 PM
johnson636's Avatar
Liked: 1242
Erich H has mentioned on a couple of occasions. Below is a post from Matt
http://www.hificircuit.com/community...e-3#post-11208
post #28 of 35 Old 04-03-2020, 08:34 AM
gil393's Avatar
Quoted: 104 Post(s)
Liked: 79
My space is 23x28 with the back closed and 23x47 with the back opened up (big events). 10ft walls, 15ft ceilings. My system is not 100% diy but close enough. I use 3xAltec A7 cabinets purchased on craigslist filled with TD15M and PRV D290Py-B compression drivers on Altec 511 horns. Extensive DIY cabinet reinforcement, horn dampening, etc. Low end is handled by 3 DIY dual PA460 cabinets about 24cu.ft. each tuned around 29hz. The LCR are tri-amped active crossovers. The sides, rear, and eventually atmos are currently using jbl 8330a speakers. These can be had for about $65 each (with patience and persistence). They are reasonably durable and cheaper than any DIY speaker of similar capabilities. I'm using Ashly amps I find on craigslist and ebay to power it all, with a Yamaha TSR-7810 receiver and Echo Layla interfaces. Total audio system expenditure about $3500 all-in.
Do not underestimate how much headroom is needed. With the room full of people when the Super Bowl halftime show comes on you will want it louder than any movie. I had the subwoofer and td15m amps almost clipping at points, so basically cranked as loud as it would go. Nobody complained, but I did have to make people move away from the front row. That is in the 125db range at the speaker.
Your budget is bigger than mine so you have more choices. I'd think 3xTitan 615lx, 2xSubmaximus v3, volt-10s for the rest if I could do it over again.
gil393 is offline
post #29 of 35 Old 04-03-2020, 09:45 AM
johnson636's Avatar
Liked: 1242
Originally Posted by gil393 View Post
Your budget is bigger than mine so you have more choices. I'd think 3xTitan 818lx, 4xSubmaximus v3, volt-10s for the rest if I could do it over again.
Fixed it for you
gil393 and asarose247 like this.
post #30 of 35 Old 04-04-2020, 08:44 PM
mhutchins's Avatar
Quoted: 351 Post(s)
Liked: 315
LCR: DIYSG 1099s
LCR - Titan 630LX
Surrounds - HTM12
Atmos - Vortex 12, HTM12 if you have the ceiling height
Subs - Devastator Finalizer with B&C, Eminence or LaVoce 21" driver, whichever models best
Amps - QSC or Hypex Ncore for mains and surrounds, Speakerpower for subs
Mike
monty6400 likes this.
mhutchins is offline
