I have to do a full breakdown of my theater and it’️s going to take a bit of time to do including a new amp rack and paint for all my DIY boxes AND I just finished a new build so I figured “what better time to do a full on comparisonâ€.
Here is how I will set all this up. I need all of you to help me / tell me what tests you want run. Now, I still need to setup another amp before I can start and that might take me a little bit (an hour or a day) so this will give some time for you to help me through what sweeps you want. BTW, I have to take these out the back door to my garage so all these boxes WILL AT SOMETIME BE OUTSIDE, wink.
All subs will be measured in pairs because I have two F20 ported through my left wall setup as a pair ( see black grille in photo ) so if you really need a single sub sweep let me know.
Mains being used - HTM12s on Yamaha Rxa2060 160 watts ran through YAPO xo at 80hz unless specified.
MBMs - PA460 8 ohm each 4cuft ported at 42hz - high pass xo at 40hz on inuke 1000dsp stereo 160 watts each.
Mini Narrow Dev - PA460 8 ohm each high pass xo at 20hz on inuke 3000dsp stereo 440 wats —> limited to 300 watts each
