What subs for HT on a budget? - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #1 of 43 Old 04-12-2020, 06:50 AM - Thread Starter
Quoted: 37 Post(s)
A friend asked me to build him two subs for his new HT where SPL, LFE and "ooomph" is more important than sound quality, however it should sound good, but dont have to be really high end.
Max budget is 10.000 NOK which translates to around $1000, however with taxes and shipping it's more like a $750 budget in the US, and that should include everything, drivers, sheeting, amp(s) and "stuff"
Size is not a problem, so i am thinking horns or simular, but i have not followed the trends after i built my Lilwreckers som years ago, so any suggestions will be apreciated.
7.1.4
DIY DTQWT, DIY custom Overnight Sensation, DIY LilWrecker DIY class A /Icepower/Anaview poweramps, Denon AVR X6200W, Cambridge Audio Azur 751BD
https://www.avsforum.com/forum/155-d...und-atmos.html
Roadrune is offline
post #2 of 43 Old 04-12-2020, 07:42 AM
johnson636's Avatar
Quoted: 1753 Post(s)
Liked: 1281
Does your budget include the amp? I'd say purchase the Lavoce 21" driver and build the Devastator LFE or Alpha
monty6400 and N8DOGG like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 43 Old 04-12-2020, 08:15 AM
a77cj7's Avatar
Quoted: 1006 Post(s)
Liked: 1065
Not sure how you’re going to accomplish that for $750 for two including material and amp.
Since size is no consideration, should be able to do 4 VBSS. Group them as doubles if needed to meet two sub definition. Up the budget to $1000 and you should be able to do 8.
You could put the pa460 drivers in mini dev’s for more midbass kick. Material cost will go way up though, for a moderate gain.
If you want to go horn, a pair of F20’s should be doable.
Audiophile75 and Heide264 like this.
a77cj7 is offline
post #4 of 43 Old 04-12-2020, 08:18 AM - Thread Starter
Quoted: 37 Post(s)
I should be able to build two mini Devastators with the cheap Dayton 18", but i have no idea how it would compare to the F20's or VBSS...
7.1.4
Roadrune is offline
post #5 of 43 Old 04-12-2020, 08:21 AM
a77cj7's Avatar
Liked: 1065
Mini dev vs vbss. Pa460. Same input power.
Black is mini dev.
Chris
d-rail34 and Roadrune like this.
a77cj7 is offline
post #6 of 43 Old 04-12-2020, 09:18 AM - Thread Starter
Quoted: 37 Post(s)
And the guy (with no patience what so ever) just ordered two PA460's
But the Behringer NX3000 is all sold out here, and not shipping until september :O any other good, cheap amps out there? DSP is not required if we go for the VBSS i suppose (no need for a HPF, and the FR can be adjusted with what he have).
7.1.4
Roadrune is offline
post #7 of 43 Old 04-12-2020, 09:24 AM
johnson636's Avatar
Liked: 1281
I'm not looking to accomplish anything. I already have my subs built
a77cj7 likes this.
post #8 of 43 Old 04-12-2020, 09:33 AM
a77cj7's Avatar
Liked: 1065
Uhh, the vbss definitely needs a hpf.
Chris
smcmillan2 and joker927 like this.
a77cj7 is offline
post #9 of 43 Old 04-12-2020, 09:35 AM
a77cj7's Avatar
Liked: 1065
Impossible, everyone needs more.
Smartass
Chris
a77cj7 is offline
post #10 of 43 Old 04-12-2020, 09:37 AM
smcmillan2's Avatar
Quoted: 1143 Post(s)
Liked: 967
The VBSS relies (heavily, depending on tune) on DSP, and a HPF is needed. Take a look at the settings file in the first post of the thread.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #11 of 43 Old 04-12-2020, 09:40 AM - Thread Starter
Quoted: 37 Post(s)
Oh, i just supposed it wasn't needed beeing a ported design...
7.1.4
Roadrune is offline
post #12 of 43 Old 04-12-2020, 09:42 AM
a77cj7's Avatar
Liked: 1065
All ported need hpf, as the driver unloads below tune. Sealed don’t need the hpf.
Chris
a77cj7 is offline
post #13 of 43 Old 04-12-2020, 01:07 PM
Samps's Avatar
Quoted: 1338 Post(s)
Liked: 1009
Amazon has the Nx3000d for $400.
You definitely need/want the DSP.
That should bring you to about $600. $400 left should be plenty to build the devastators. But ported cabs are good for that driver too. Doesn’t have to be VBSS. You can build them a little larger to get some more low end. Full Marty size should work well, but you can’t use the VBSS dsp settings with that. You would have to come up with your own settings.
Samps is offline
post #14 of 43 Old 04-12-2020, 01:36 PM
a77cj7's Avatar
Liked: 1065
I thought the vbss was sized to hit excursion limits on Inuke power? Additional volume shouldn’t net low-end.
Chris
a77cj7 is offline
post #15 of 43 Old 04-12-2020, 05:22 PM
Samps's Avatar
Liked: 1009
12 cubes gains you 3-4db at 20hz over a 7 cube box. The bigger box is more efficient, so it takes less excursion to reach a given spl. So your 9mm gets you more. Only down low below 30hz. Above 30 you gain nothing and even loose a tiny bit up top.
Samps is offline
post #16 of 43 Old 04-12-2020, 05:36 PM
tk123's Avatar
Quoted: 243 Post(s)
Liked: 154
Interesting.
Do you have a FR graph that shows this comparison? Also, at what tuning frequency for each cab size ?
tk123 is offline
post #17 of 43 Old 04-12-2020, 06:20 PM
mtg90's Avatar
Quoted: 903 Post(s)
Liked: 1740
The bigger box is more efficient because there is less air spring pressure for the woofer to fight against. So you have more cone excursion (and therefore output) for a given input. Max output is however still tied to available excursion.
Heide264 likes this.
mtg90 is offline
post #18 of 43 Old 04-12-2020, 07:03 PM
Samps's Avatar
Liked: 1009
Thanks, I misunderstood how efficiency worked.
But max output seems to be effected by box size. The excursion doesn't change, but a bigger box adds more spl potential, down low anyhow. I assume the bigger box somehow adds more output from the port.
Here is the max spl tab in winisd for the PA460 in 7 cubic feet vs 12 cubic feet.
Samps is offline
post #19 of 43 Old 04-12-2020, 10:25 PM
Vergiliusm's Avatar
Quoted: 355 Post(s)
Liked: 656
From John Murphy's website:
"The following mathematical relationship between these parameters can be found in Small's paper :
Closed-Box Loudspeaker Systems
published in the Journal of the Audio Engineering Society
Vol. 20 No. 10 (DEC 1972)
Efficiency = k * f(3)^3 * V(B)
(where k is the so called "efficiency constant")
(f(3) is in Hz, and V(B) is in cubic meters)
for closed boxes: k = 2 * 10^-6
for vented boxes: k = 4 * 10^-6"
https://trueaudio.com/st_trade.htm
"Rock and roll is alive and alright" Sloan
Vergiliusm is offline
post #20 of 43 Old 04-12-2020, 10:37 PM
mtg90's Avatar
Quoted: 903 Post(s)
Liked: 1740
If you look at the SPL graph and adjust input power down on the larger enclosure until the output level near port tuning is equal to the smaller enclosure (~40%) then switch over to cone excursion you'll see that excursion at port tuning is also equal to one another.
Another way to look at it is to change xmax to 1mm, you'll find that the larger enclosure doesn't give you anymore max output then the smaller one as xmax is always hit before the rated input power is reached.
I choose the volume of the VBSS because I felt it was the best compromise of physical enclosure size and utilizing the displacement of the PA460 with the power provided by the inuke 3000. A larger enclosure will give you more output near port tune where the extra displacement available at the excursion minimum can be taken advantage of. That said I also think a larger enclosure will also allow the PA460 to be pushed too far around 25-35hz. Damage is unlikely but the woofer has a tendency to bias in one direction at certain frequencies quickly moving the coil out of the gap and into heavy distortion. I may try and get a video of that with the driver free air. I can't recall which frequencies the effect is most pronounced but IIRC it biases inwards at some frequencies and outwards at others.
mtg90 is offline
post #21 of 43 Old 04-13-2020, 03:40 AM
tk123's Avatar
Quoted: 243 Post(s)
Liked: 154
I do think I remember running into excursion problems when modeling for my VBSS. The driver definitely gets into trouble at lower frequencies with power applied. It seems that port velocity was also too high at this point if I remember correctly.
tk123 is offline
post #22 of 43 Old 04-13-2020, 04:16 AM - Thread Starter
Quoted: 37 Post(s)
Yeah, but thats in the US, 2 PA460's shipped to Norway is $360, then you can add 25% taxes to that, the same goes for the amp.
However i have been thinking of swapping out my own Inuke 3kDSP, so he can get one cheap.
Can a Nuke 3000 run to Mini Devs in parallel from a single channel to a decent level? The guy wants to use the other channel to run some other subs he have...
7.1.4
Roadrune is offline
post #23 of 43 Old 04-13-2020, 04:47 AM
Heide264's Avatar
Quoted: 69 Post(s)
Liked: 39
Just to make sure you are aware, Roadrune, the inuke series was replaced by the 'NU' series. They are the same amplifier with a prettier face, as far as I know. If you are seeing the inuke sold out, look for the corresponding NU amp (i.e. NU3000 DSP or whatever it is)
Enjoy the builds!
Heide264 is offline
post #24 of 43 Old 04-13-2020, 05:08 AM - Thread Starter
Quoted: 37 Post(s)
Enjoy the builds!
Yeah, i know they have been replaced by the NX, thanks.
7.1.4
Roadrune is offline
post #25 of 43 Old 04-13-2020, 05:10 AM
johnson636's Avatar
Liked: 1281
I was under the impression the NX series replaced the NU series.
post #26 of 43 Old 04-13-2020, 05:28 AM
a77cj7's Avatar
Liked: 1065
Yes, the 3k can run 1, 2, or 4 pa460’s per channel
Roadrune likes this.
a77cj7 is offline
post #27 of 43 Old 04-13-2020, 05:37 AM
Heide264's Avatar
Quoted: 69 Post(s)
Liked: 39
Sorry about that! I should know better than to post before finishing my first cup of coffee!
johnson636 likes this.
Heide264 is offline
post #28 of 43 Old 04-13-2020, 06:44 AM
johnson636's Avatar
Liked: 1281
Ah man, can't forget the coffee...it gets the morning started
post #29 of 43 Old 04-13-2020, 05:40 PM
Quoted: 1281 Post(s)
Liked: 1120
Ah man, can't forget the coffee...it gets the afternoon started
Fixed it for you... lol
sigpig is offline
post #30 of 43 Old 04-14-2020, 02:25 AM - Thread Starter
Quoted: 37 Post(s)
It seems to me the Mini Dev V4 is the best option here, are you experts agreeing?
Also, reading the Dev thread i found a lot of mentions of BOSS, what's that?
7.1.4
Roadrune is offline
