Replacement Drivers for Height/Atmos - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Chris Popovich
post #1 of 12 Old 05-20-2020, 02:22 PM - Thread Starter
Liked: 4
I know this is going to sound crazy but I think I need to replace my 4" drivers in my JBL n24's that Im using as height speakers. Yes, I said n24 LOL. I picked them many years ago thinking they would match fairly well with the tonality of my JBLS38's. These n24's are "breaking up" at volume which makes me think I need something to handle the power. If I run the same height signal to one of my mains, the sound does not distort. The n24 are only rated to 100 watts. Im thinking I need something better than 150 watts. I tried a speaker rated at 125 but still experienced the distortion. (less at the same receiver volume but still there). Can I get a 4" driver to bring the power rating up of these little speakers? This is a budget system so purchasing SVS, Klipsch, or other purpose made height speaker is not an option.
This is about the only one I could find in a higher wattage.
https://www.parts-express.com/morel-...-ohms--297-002
GrabberGT is offline
post #2 of 12 Old 05-22-2020, 08:52 AM
buggers's Avatar
Quoted: 55 Post(s)
Liked: 36
If you change a driver you will most likely need to re-design the crossover. Are you going to be doing that?
buggers is offline
post #3 of 12 Old 05-22-2020, 09:38 AM
Chris Popovich's Avatar
Quoted: 367 Post(s)
Liked: 342
I don't think you're going to have success messing with it like that, and likely going to spend more money for no/minimal results than if you just used different speakers. Can you adjust the signal in your AVR to filter out even more low end? Can you simply lower their level a couple dB and get by? A 4" driver isn't going to do miracles.
Chris Popovich is offline
post #4 of 12 Old 05-26-2020, 06:58 AM - Thread Starter
Liked: 4
No I wanst going to change the crossover. Being that these are height/surround speakers, the quality doesnt exactly have to be the best so current crossover should work.
I've adjusted crossover all the way up to 250 and still have distortion. Reducing levels helps but I'd rather not have to do that.
Im going to go ahead and buy one of these Morel speakers. Is 4ohm the correct version to get? I assume both the tweeter and woofer are 4ohm and wired in series to get 8ohm. If the speaker is max watts 300 in 4ohm doesnt it become 150 as 8ohm?
post #5 of 12 Old 05-26-2020, 08:23 AM
Quoted: 367 Post(s)
Liked: 342
That's not how it works, just pull your JBL woofer and measure with a multimeter.
Max watts is max watts, it's not an amplifier that capacity changes with impedance...
Chris
post #6 of 12 Old 05-26-2020, 12:50 PM - Thread Starter
Liked: 4
Chris
DOH! Thanks. Im overthinking it. LOL
post #7 of 12 Old 05-26-2020, 12:56 PM
Quoted: 367 Post(s)
Liked: 342
If you're happy with the JBL's in general I'd just go up a size and check ebay. I saw some N26's on there for about the same cost as two morel woofers.
Edit: Less money, shipped, for two used N26's. I'd def try that before any other option.
post #8 of 12 Old 05-26-2020, 10:11 PM - Thread Starter
Liked: 4
Tried them. They max out at 125 watts and also a higher sensitivity rating. It was better but still nowhere near as good as my S38. They still had distortion. The S38 playing the same levels and excerpt was clean.
post #9 of 12 Old 05-26-2020, 10:14 PM
Quoted: 367 Post(s)
Liked: 342
eh?
You're replacing the woofers in your N24 speakers used for height, right? Replace those N24's with N26's. No one said anything about your S38's. Are you into the sauce? Am I?
Do you mean the 26's are better than 24's but not as good as you want? How much are you asking out of height speakers?
post #10 of 12 Old 05-26-2020, 10:46 PM - Thread Starter
Liked: 4
eh?
LOL... Just using the S38 as reference. Making sure that the sound Im hearing from the N24's isnt just an anomaly in the soundtrack. If it was, then the S38 would also have it.
Yes the 26's are better than the 24's but still introduce distortion... (and they are huge). My height speakers are 14' away from my listening position. I SPL match them to 85db to match the ear level speakers. Its the peaks that they have trouble keeping up with which just happens to be where the soundtrack needs then to shine.
post #11 of 12 Old 05-26-2020, 11:21 PM
Quoted: 367 Post(s)
Liked: 342
Something is off. The atmos speakers don't have that much going on, nevermind breaking up a decent 6" bookshelf speaker. You sure it's not the amp kicking the bucket when all channels are driven into that particular load? 14' away is a bit much for a 4" woofer, I'd cross that sucker over as high as possible and kick it down a couple db's.... call it good. Have photos of the setup?
SuperFist likes this.
post #12 of 12 Old Yesterday, 07:53 AM - Thread Starter
Liked: 4
The atmos speakers have lots going on. Sure they primarily add to atmosphere but when the sound engineer wants true object based tracking, the atmos channels can have quite a bit of output. Also, the largest amnt of distortion is found when watching 5.1 or 7.1 content that the receiver is up-mixing to the height speakers. Bad Boys 3 in 5.1 for example has multiple scenes where the music gets played thru height speakers during some flying sequences. Really neat effect but too much for my little speakers to handle.
Its shouldnt be the amp for 2 reasons. 1. The same signal was played thru a larger speaker at the same volume level (all other speaker levels turned all the way down) and there is not any distortion. 2. I've already off loaded the main channels to a 5-channel amplifier so that My Marantz is now only powering the height channels. My system is 5.4.4.
Here is a good overall photo of my setup. Taken from as far back in the room as possible. (About 4' behind the seating position.) The room is 19x19. The screen is 10' wide. Height speakers are mounted at the top of the pillars on each side. Each speaker is aimed at the center of the listening position.
