Beyma TPL150H/AE TD12M/Beyma 158P80ND Active - AVS Forum | Home Theater Discussions And Reviews
 18Likes
  • 1 Post By neo_2009
  • 1 Post By BassThatHz
  • 1 Post By noah katz
  • 1 Post By Javs
  • 1 Post By A9X-308
  • 1 Post By Javs
  • 1 Post By Javs
  • 1 Post By Javs
  • 1 Post By PrimeTime
  • 1 Post By Javs
  • 1 Post By Javs
  • 1 Post By Vince_B
  • 2 Post By neo_2009
post #1 of 27 Old 05-21-2020, 09:05 AM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
This project started almost 2 years ago, initially as this, but as time went by, it evolved to this final iteration.
Unfortunately, lots of unpredictable factors were in the way, but fortunately, i've learned not to rush things, and look at this from a long term perspective, so i'm hopeful in the long term it was for the best.
The final project was inspired by Javs fenomenal Javs' Modular Tower WMTW - 15FH520 / Beyma 12P80ND-V2 / TPL-150H project:
The final speaker will be a 3 way speaker, composed of:
- Beyma 15p80nd: X < 350Hz
- AE TD12M: 350 < X < 1500Hz
- Beyma TPL-150H: 1500Hz < X < 20000Hz
(Crossover points will be dictated by real measures, but should be around those values).
Crossover will be Active,using a Monacor DSM-48LAN.
I'll start with the TPL-150H and the AE TD12M, and when funds allow, will add the Beyma 15p80ND.
For amplification, i'll start with budget amplifiers, the TPL will be driven by a Parasound Zamp V3 ([email protected]), which has variable gain controls that i'm hoping will help to avoid any potential hiss, and the AE TD12M by a Crown xli 800.
While i'm waiting to get the boxes, i'm trying to plan everything i will need to connect all components, namely AV (NAD T758V3) -> DSP -> Amps.
The following diagram describes how all components will be connected, showing the real hardware from each component (pre-outs, inputs, etc):
Cables will be made with Sommercable SC-Galileo 238 Plus, for RCA plugs, Hicon HI-CM03-NTL, and for XLR plugs, XLR Male NC3MXX and XLR Female NC3FXX
I would like to ask your help, please have a look at the connections, is everything correct or am i missing anything?
donivan likes this.
neo_2009 is offline
post #2 of 27 Old 05-21-2020, 09:31 AM
BassThatHz's Avatar
Quoted: 4052 Post(s)
Liked: 4568
Should work.
You'll have to reduce the output db's on the tweeter substantially to make everything match. -48db should be plenty (I think).
neo_2009 likes this.
BassThatHz is online now
post #3 of 27 Old 05-21-2020, 11:13 AM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Than you for your response.
The TD12M is [email protected], and the TPL [email protected], so it i assume around 6db should work.
Nevertheless, i will be measuring these on the outside, so this will be dictated by measurements.
neo_2009 is offline
post #4 of 27 Old 05-21-2020, 11:27 AM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
One of the things that i'm worried with, are the tweeter levels.
Even using a 45W amplifier with gain controls, if someone messes with the controls, and the AV volume control, it can achieve dangerous levels.
Using this calculator, it would achieve near 115db at 2m, which could hurt someone.
I'm considering using these In-Line attenuators.
But i'm not sure where to place them? Would they work between the DSP OUT and the Power amp IN, as in this image?
neo_2009 is offline
post #5 of 27 Old 05-21-2020, 12:10 PM
noah katz's Avatar
Quoted: 2619 Post(s)
Liked: 986
It might waste a watt or two, but you could also use a resistor in series with the tweeter, which might also simplify gain structure issues.
Noah
noah katz is offline
post #6 of 27 Old 05-21-2020, 12:20 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Assuming the atenuador would work the same way, i would prefer to go through that route, its not only easier, but more flexible.
neo_2009 is offline
post #7 of 27 Old 05-21-2020, 01:40 PM
Javs's Avatar
Quoted: 7222 Post(s)
Liked: 6908
Awesome!
I have attenuators on my DSP output to tame some hiss and DSP noise floor.
I also set my AVR as such that 0mv is a couple db under reference, so you could do that too.
My sweet spot is 1200hz crossover with 48db slopes, it sounds awesome, I tried just about every other crossover slope but keep coming back to that one. It's steep enough that the top doesn't break a sweat and low enough that the mid is definitely not beaming.
Sent from my SM-G988B using Tapatalk
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #8 of 27 Old 05-21-2020, 02:58 PM
A9X-308's Avatar
Quoted: 2034 Post(s)
Liked: 1748
You'll also need to factor in the gains of the various amps used to set levels correctly.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #9 of 27 Old 05-21-2020, 03:03 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
My sweet spot is 1200hz crossover with 48db slopes ...
Thank you very much for your feedback.
Could you please clarify how are you doing this on your AVR?
neo_2009 is offline
post #10 of 27 Old 05-21-2020, 03:04 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Thank you for the clarification, it makes sense.
As mentioned, i will perform proper measures outside, and use them to decide which values to use.
neo_2009 is offline
post #11 of 27 Old 05-21-2020, 03:08 PM
Javs's Avatar
Liked: 6908
Combinations of the actual speaker line levels set in the AVR, and also the DSP. MiniDSP defaults to mute if it loses settings too.
I dont have a big fat gain knob on the front of any of my power amps, I use Emotiva amps, so its literally impossible for me to drive my tweeter over about -3db from reference peaks. I personally never listen at ful reference so having it always at -3 was good for me. I am a wierd person in the fact that I prefer to just go right to -0Mv when watching something so its fool proof to reach a known preferred level.
I dont see how if you know even the slightest what you were doing you would send any volume over reference to your tweeter anyway. That really should be part of the setup process IMO when you are doing your gain matching.
Javs is online now
post #12 of 27 Old 05-21-2020, 03:13 PM
Javs's Avatar
Liked: 6908
One tip with the TPL.
When you take the backing plate off, LEAVE the felt strip glued to the back of the TPL. It keeps the response smoother than when you remove it. It seems crazy but it took me years to figure out that one quirk.
Javs is online now
post #13 of 27 Old 05-21-2020, 03:20 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
The Monacor is built by AllDSP, and the Software is really interesting.
It allows to apply Gains and a Limiter in both INPUT and OUTPUT, so assuming the software behaves well, it should allow to configure the system gain levels properly:
Nevertheless, i will feel more comfortable by adding a physical attenuator, in case of something crashes at the software level
neo_2009 is offline
post #14 of 27 Old 05-21-2020, 03:56 PM
Javs's Avatar
Liked: 6908
An attentuator is not going to change your power amps ability to drive an input though. It does not reduce the power of your power amp. At the end of the day you are still effectively usung your dsp or processor to set the overall levels. Even though I have a 10db attenuator on my tweeter, I could still turn knobs and set things so my tweeter gets 80w without any issues at all.
I only see an attenuator as useful to reduce the noise floor of your dsp.
Javs is online now
post #15 of 27 Old 05-21-2020, 04:09 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
I see, thank you for the feedback.
The Zamp actually has gain knobs, so i assume that by using those, and the DSP Gain and Limiter functions, it should be possible to prevent any potential problem?
Or maybe use an resistor in series, as mentioned above, just in case
neo_2009 is offline
post #16 of 27 Old 05-21-2020, 04:36 PM
Javs's Avatar
Liked: 6908
I think you are making a mountain out of a mole hill.
Put a cap to protect the tweeter if you are really worried about sending too much power to tweeter, this will stop it getting damaged. but again, a resistor will not stop max power being sent to a tweeter, it will only reduce it in relation to other drivers.
Just because a tweeter is sensitive it doesnt mean you are going to send 115db to it with any more easy than you could to another driver. Just set your levels in the DSP and your amp and your max volume level will be whatever you want.
Javs is online now
post #17 of 27 Old 05-21-2020, 06:16 PM
noah katz's Avatar
Liked: 986
...but again, a resistor will not stop max power being sent to a tweeter, it will only reduce it in relation to other drivers.
Whatever the tweeter's Re is, if a resistor of equal value is put in series with it, the amp output voltage applied to it will be cut in half, and the power will be reduced by 4X.
Noah
post #18 of 27 Old 05-23-2020, 03:14 PM
BassThatHz's Avatar
Liked: 4568
More.
You are stepping down from XLR voltage to RCA voltage; you could easily clip the input stage of that amplifier if you aren't careful.
But well before that point, you'd be running for the exit...
The cool thing with all-active is that you can adjust the timing of every driver,
so you don't have to worry (as much) about the physical-alignment.
post #19 of 27 Old 05-24-2020, 03:56 PM
PrimeTime's Avatar
Quoted: 842 Post(s)
Liked: 550
Don't forget a Raychem RXE-075 to protect the tweeter.
PrimeTime is offline
post #20 of 27 Old 06-13-2020, 08:34 AM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
All gear (almost) in the house
The Beyma's
One of the AE's
Interconnects
The Neutrick plugs with sommer cable:
The Monacor DSM-48 LAN
I'm waiting for this type of speaker connectors for the TPL150, so i can test it with the Parasound Zamp and the Monacor, hopefully i won't have the dreaded hiss problem, or if its there, that the gain knobs on the Zamp can eliminate it:
Now patiently waiting for the cabinets to be concluded, hopefully it won't take more than 2-3 weeks ...
neo_2009 is offline
post #21 of 27 Old 06-13-2020, 12:16 PM
BassThatHz's Avatar
Liked: 4568
Switching from all passive to all active I saw HUGE efficiency increases.
Before I was nearly clipping my FP10k's trying to drive my fronts, now it barely registers signal-detected while STILL being louder/cleaner.
If the Monacor produces too much hiss the Motu 16A or 24A is as silent as a DAC can be.
With my Motu rig and the FP's even with the 108db/w/m SOES's I have to be within a foot to hear the hiss over the stock fan-noise from 15ft away. The only downside is that it requires software-based DSP hosted by a dedicated computer, so that drives the cost/risk/complexity up significantly.
I may wire the fans to the remote switch on the amp so that I can turn them off because honestly I doubt the idle power is enough to kill the amplifiers via heat from pushing mids and tweeters. But I should probably wait until I can add the dedicated air conditioner to the room because right now the room gets unusably nuclear-hot in the summer.
1st worlder problems I tells ya!
post #22 of 27 Old 06-13-2020, 03:56 PM
Javs's Avatar
Liked: 6908
The Beyma's
One of the AE's
Interconnects
Soon as you get those connectors, lets hear that hiss??
If its going to do it, it will do it even on MUTE. BUt if you have gain knobs, unless your power amp also has a high noise floor (I tested the iNuke 3000DSP - but that also has DSP built in) you should be able to easily fix it with the input gain.
I mean its not really a huge issue because after you build attenuators you push the noise floor way down anyway, when I was researching it there was a whole subset of people who used them anyway because they were of the opinion that if you push the pre-amps more into the high range it was actually sound more dynamic, I think there is something to that.
Javs is online now
post #23 of 27 Old 06-13-2020, 04:31 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
That's the plan
The cable is too thick, and i don't want to risk an accident, so i need to wait for the connectors, should be here next week ...
Cabinets are almost done, what's left are the final polish, the frames for the grills, and cover the grills with acoustic fabric (which i already have).
I've been waiting for this for almost 2 years, so i don't mind waiting a few weeks more, the plan is to keep these speakers forever
The best thing in going for the best you can afford (and i had to save a lot for these), is that you don't need to second guess ...
Once these are completed and fine tuned, i hope i "never" need to think about speakers again
neo_2009 is offline
post #24 of 27 Old 06-13-2020, 04:36 PM
Javs's Avatar
Liked: 6908
That's the plan
Thats how I feel about my towers too. At least for LCR.
But I did make them modular for a few reasons, if I wanna try a new mid, easy, just build a new mid cabinet.
Or if I wanna add 18's, I can add 18's.
But these have enough bass to violently shake the windows in my room and I can hear the drywall flexing, so I think I am alright
Javs is online now
post #25 of 27 Old 06-13-2020, 04:51 PM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
When funds allow, i will add the Beyma's 15.
For 18", i already have 2 18" (BMS18N862), and the boxes build for 2 more if needed, hidden as furniture:
This is how it looks from behind, Subs 3) and 4) are already completed, 2) and 1) are waiting for funds:
I have so much to thank to this and avforums (UK), if not for all the help i had, i would probably still have 5.5" woofer speakers, a 10" sub, and a lot of fancy cables :-D
18Hurts likes this.
neo_2009 is offline
post #26 of 27 Old 06-13-2020, 05:08 PM
Vince_B's Avatar
Quoted: 346 Post(s)
Liked: 246
Well done front view that is clean!
Vince_B is offline
post #27 of 27 Old 06-26-2020, 11:30 AM - Thread Starter
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
I finally have great news
I tried the following today:
1 - Connect TPL + Monacor + Zamp
- XLR to RCA from Monacor Output to Zamp Input
- Zamp speaker outputs to TPL
No Hiss at all !!!!
The Zamp has variable gain knobs, and only in the maximum setting there is a very very slight hiss which can only be heard with the ear inside the TPL Horn.
2 - Connect TPL + Monacor + Zamp + NAD T758
- NAD Right speaker Pre-out, using an RCA to XLR cable to the Monacor Input
No hiss at all
When using maximum gain, the same very very small hiss and only with the ear inside the Horn, it can't be heard 5cm away from the TPL.
(i was actually a bit afraid, thinking that if for some reason there was a glitch, it could fry my ear ...)
I'm not entirely sure these are 100% valid tests, as i haven't changed any of the Monacor configurations, but nothing was muted (the Monacor has a front panel that lights when something is muted).
Nevertheless, it seems that the Hiss that some Emotiva/Nak users were having even when connecting the DSP/Amp/Speaker isn't here.
The next great news is that the Boxes are finished, will be having a final polish next week, so as soon as i have some availability i will be able to pick them up.
And then, the next phase, is where the real fun begins
a77cj7 and Javs like this.
neo_2009 is offline
