Allowed a make a subwoofer but need help - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Chrisipod4s
post #1 of 10 Old 05-22-2020, 07:23 PM - Thread Starter
Quoted: 48 Post(s)
Hey guys,
My wife got rid of this old bookshelf in the corner of our living room and wants a end table to put there I told her I can build it and put a sub in the bottom to hid it and she said ok. So was thinking an ultimax 18 but not sure.
I have currently have a klipsch 12 and a infinity 12 subs and I am a lil worried about blending them all. Is that or should it be a concern as space will not allow for a second end table sub at this time
which amps and subs should I be looking at? Budget is $1000
The space I have to work with is 32x32 and 26 high. So which sub build would work with in that space it would have to be down firing so I can make the top an end table for a lamp.
head_unit likes this.
Chrisipod4s is offline
post #2 of 10 Old 05-22-2020, 07:31 PM
joker927's Avatar
Quoted: 78 Post(s)
Liked: 52
You have two 12" subs and are looking for advice on building a third with an end table size cabinet? If yes, are those subs ported or sealed?
Sent from my ONEPLUS A6013 using Tapatalk
joker927 is offline
post #3 of 10 Old 05-22-2020, 07:44 PM - Thread Starter
Quoted: 48 Post(s)
Originally Posted by joker927 View Post
You have two 12" s and are looking for advice on building a third with an end table size cabinet? If yes, are those subs ported or sealed?
Yes I have a klipsch and an infinity sub both 12 inch both ported this will be my first build
post #4 of 10 Old 05-22-2020, 09:22 PM
Liked: 0
With those dimensions you could modify a marty cube to downfire with a dayton RSS460HO-4, and adjust the port lenght to favor movie or music listening. If you need a plate amp the dayton SPA500DSP will work. If you can deal with the noise(or mod the fan) and wiring the bheringer nx3000d would let you add another sub in the future but the proaudio amp has drawbacks in a dual use spac.
SSinstaller is offline
post #5 of 10 Old 05-23-2020, 08:48 AM
Quoted: 153 Post(s)
Liked: 134
Build a VBSS into an endtable.
Cheap and shockingly effective.
dorri732 is offline
post #6 of 10 Old 05-23-2020, 10:02 PM - Thread Starter
Quoted: 48 Post(s)
I’ll look into that it will be mostly be used for ht
post #7 of 10 Old 05-23-2020, 11:03 PM
head_unit's Avatar
Quoted: 738 Post(s)
Liked: 399
Originally Posted by Chrisipod4s View Post
down firing
The thing about that is this thing called "gravity" inevitably pulls the coil and suspension out of their prime alignment. Since this goes in a corner, can't you put the woofer on the back/side? Do consider at high SPLs the air "jets" straight in/out of the port so you need a few port diameters of clearance ideally. Hmmm...maybe you could build a shelf port into the bottom, but recessed so it is not easily visible?
Actually considering port difficulties, and the 12.5 cubic feet you have, I'd be considering 2 woofers on each out-of-sight side, kind of slot loaded into the corner and loading each other. Well stuffed, Q low, would probably extend really well with room gain. Higher driver cost though, unless you used somewhat less godly drivers.
P.S. We DEMAND a build thread, we wanna see this!
P.P.S. As for the other subs, with a monster like this, make your wife even happier and ditch them.
head_unit is offline
post #8 of 10 Old 05-24-2020, 08:34 AM
psyduck103's Avatar
Liked: 37
Hey guys,
UM18-22 on sale now for $279 from $324. I just bought two more. That will make eight.
psyduck103 is offline
post #9 of 10 Old 05-24-2020, 02:32 PM - Thread Starter
Quoted: 48 Post(s)
Been thinking about this and grabbing 2 ultimaxs while on sale. Have a few questions on how it would work.
1 are you talking sealed?
2 Would it be two box’s in “one” or Would they just share the space inside?
3 How much output would gained
post #10 of 10 Old 05-24-2020, 09:01 PM - Thread Starter
Quoted: 48 Post(s)
Thanks I went and purchased one
