Mixing different size sub - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By johnson636
  • 1 Post By BassThatHz
post #1 of 8 Old 05-23-2020, 08:53 AM - Thread Starter
aaks38's Avatar
Quoted: 37 Post(s)
Liked: 27
I purchased 2 15 Dayton ultimax 15s and wanted to purchase 2 more for a configuration of subs at all four corners of the room, my question is can I use 2 Ultimax 18 subs at the front corners and 2 Ultimax 15s at the rear corner or would it be better to stick to the same diameter at all 4 corners. My plan was to place them all in sealed 3-4 cu ft boxes.
Thanks for the help.
aaks38 is offline
post #2 of 8 Old 05-23-2020, 10:11 AM
johnson636's Avatar
Quoted: 1714 Post(s)
Liked: 1208
Yes, you definitely can use UM18-22 and UM15-22 in the same setup. However, the UM15-22 will run out of steam before the UM18-22
jujuman200 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 8 Old 05-23-2020, 11:38 AM - Thread Starter
aaks38's Avatar
Quoted: 37 Post(s)
Liked: 27
Thanks, so even though the two drivers have different performance in their sealed boxes, would there be any issues in terms of phase and frequency performance which would cause cancellations or odd response. I have audyssey xt32 in my av receiver and plan to calibrate the fronts as a group relative to the rears as a group.
aaks38 is offline
post #4 of 8 Old 05-23-2020, 12:05 PM
smcmillan2's Avatar
Quoted: 1116 Post(s)
Liked: 942
XT32 doesn't do that. It measures distance of LFE outputs 1 and 2 individually, but EQs them as a single entity.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 8 Old 05-23-2020, 12:35 PM - Thread Starter
aaks38's Avatar
Quoted: 37 Post(s)
Liked: 27
Sorry I meant that my front two subs would be connected to sub 1 output and the rear two connected to sub 2. I know when calibrated, the fronts would be measured as a pair separately than the rears by having different distance calculations and hopefully the distance calculation compensates for the phase variation.
aaks38 is offline
post #6 of 8 Old 05-23-2020, 02:58 PM
BassThatHz's Avatar
Quoted: 4011 Post(s)
Liked: 4527
The UM-15's will give up before the UM-18's will, and so it will start to distort earlier too, and ultimately place a limit on how loud the system will go before they become damaged or start sounding ugly.
...Unless you de-tune them to compensate for that difference, which is what I do with my fronts; this of course causes them to play quieter / less excursion so you don't over stress them.
It won't, as the two drivers will have a slightly different response for any given input signal.
It is unavoidable in a mixed system.
I have 5 different subwoofer drivers in my system: the SAB-24, MalX-21's, LMS-18's, UM-15's and PA-460's.
It's not "ideal" but it still sounds really good, and is still loud as hell.
Too bad TC and Exodus went bankrupt before I could finalize. Is what it is...
Luckily though humans don't hear phase, they hear SPL.
I mean, everything causes a phase shift, moving your head 1 inch is all it takes to shift the phase of all drivers based on the changed distance "ray" paths, and changing seats or walking around the room? Forget about it!!!
It happens in every system, even if you had all the same subwoofers. Only one seat can be golden, the rest will just be average.
I mean I suppose you "could" put a nearfield subwoofer behind every seat in the room, that would help (up to a point). It's been done before! Or you could implement a double bass array with quarter-wave placement.
but in summary: Adding more subwoofers, is always a good thing...
BassThatHz is offline
post #7 of 8 Old Yesterday, 10:11 AM - Thread Starter
aaks38's Avatar
Quoted: 37 Post(s)
Liked: 27
Thanks for the feedback, so im curious for those of you whom are doing this, do you have different crossover points based on the diameter and response of the sub or do you guys keep the low pass point the same across all drivers?
aaks38 is offline
post #8 of 8 Old Yesterday, 10:48 AM
noah katz's Avatar
Quoted: 2518 Post(s)
Liked: 940
Are either set of subs significantly closer to the listening position?
If so, place the 15's at the closer position to lessen their SPL requirement.
Otherwise, why not just get two more 15's?
Noah
noah katz is offline
