which sub should i build? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By johnson636
  • 2 Post By ClevelandFreeman
post #1 of 24 Old 05-25-2020, 07:19 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
so i modeled three subs a UM-12, SQL-15 and LaVoce SAN214.50
the UM-12(blue) is in 3.5ft^3 box, the SQL-15(green) and the LoVace(red) are in 5ft^3, all tuned to 18Hz and getting their maximum RMS power handling
the Air velocity
the UM-12 pros: costs only $200
good performance from only 3.5 cubes
digs low for the size
4 ohms so getting watts is easy
cons: limited dynamically
the SQL-15 pros : above reference output for most of the FR
costs $300
good comprise between "midbass" output and deep bass output
cons: needs a bigger box than the UM-12
nothing major really
the LaVoce pros: 21" yo
insane midbass output and is extremely sensitive in that region
cons : costs $480 so 46% more than the SQL-15 and 82% more than the UM-12
needs 1700 watts to have close output in deepbass to the SQL-15.
here its SPL at 1000W compared to the SQL-15
needs more costly amp.
so far im leaning towards the SQL-15
bogaboga is offline
post #2 of 24 Old 05-25-2020, 07:56 AM
johnson636's Avatar
Quoted: 1756 Post(s)
Liked: 1283
Seems you have all the info you need to make a decision. My vote is LaVoce SAN214.50
jujuman200 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 24 Old 05-25-2020, 08:01 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
why?
bogaboga is offline
post #4 of 24 Old 05-25-2020, 08:08 AM
johnson636's Avatar
Liked: 1283
Why not? Very respectable low-end and insane midbass...just as you described in your model.
post #5 of 24 Old 05-25-2020, 08:22 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
still too expensive and requires more powerful amp, also im not sure i would ever listen that loud.
bogaboga is offline
post #6 of 24 Old 05-25-2020, 08:24 AM
johnson636's Avatar
Liked: 1283
Then I have to ask, why is that one of your options
post #7 of 24 Old 05-25-2020, 08:37 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
21" bruh
bogaboga is offline
post #8 of 24 Old 05-25-2020, 08:40 AM
johnson636's Avatar
Liked: 1283
Originally Posted by bogaboga View Post
21" bruh
Then buy it and don't look back
post #9 of 24 Old 05-25-2020, 09:02 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
Does building 4-3 subs change your recommendation?
bogaboga is offline
post #10 of 24 Old 05-25-2020, 09:11 AM
johnson636's Avatar
Liked: 1283
To use your own words
21" bruh
4 subs will smooth things out though.
post #11 of 24 Old 05-25-2020, 10:58 AM
Audiophile75's Avatar
Quoted: 281 Post(s)
Liked: 277
The um is a disaster waiting to happen - although rather inexpensive the most common post from UM owners here on avs is, How do I get more midbass? This route will lead you to another amp and another midbass setup (VBSS?).
On the good side you will have four subs (2-2) and who knows how many amps and then you may be satisfied.
The Si looks like an okay safe choice for ...... an average setup I guess, but you may still have the urge to upgrade.
And the 21s will have plenty of everything although the initial cost will be high. The 21s are a great choice and you may not have to upgrade for a while, satisfied.
Audiophile75 is offline
post #12 of 24 Old 05-25-2020, 11:10 AM
Chris Popovich's Avatar
Quoted: 385 Post(s)
Liked: 365
The UM is fine. I have LaVoce 214.50's I'm testing out right now and I had UM18's and guess what -the midbass on UM18's was fine. This is mostly an AVSForum myth IMO, once eq'd and calibrated properly. It is true that the LaVoce has more midbass than you will know what to do with, but you'll be eq'ing that down with more than one filter.
That said, the Lavoce needs more than a 5cuft box. I have my test box at 6cuft @ ~16hz and it wants more. Doable with DSP.
Personally I'd go with the LaVoce, since that's what I'm doing now and IMO it's more comparable to a UM18 than anything else in your list. I do like the higher sensitivity drivers, but they need more help on the bottom, significant eq, or both.
Second is a slew of the new stereo integrity units, no data on them yet but they look good and AKAIK most of their products seem spot on. Great small box woofer.
UM12 last since it's "only" a 12" driver thus are pretty limited overall IMO.
Chris Popovich is offline
post #13 of 24 Old 05-25-2020, 11:41 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
Why though? Let’s assume I built the 3-4 SI subs, that will have more than 120db of midbass output why would I need more than that? Also I’m don’t listen very loud, most of the time I’m at -15db and lower.
bogaboga is offline
post #14 of 24 Old 05-25-2020, 12:54 PM
Quoted: 281 Post(s)
Liked: 277
You said it right, the 3-4 SIs look pretty good for your setup and listening habits. I don’t disagree. The 21s are more for going the extra mile (which we all do at some point) so this route would keep you satisfied longer UNTIL you need more.
Four SIs vs two two 21s would be a hard choice. I’m a big fan of midbass boxes up front behind my screen and just about anything in the back of the room so I would pick the 21s and put them up front just for that reason alone. If I had a living room / tv type room the four SIs would be my pick, and if your mains are not capable of an upgraded setup then that comes into play as well.
post #15 of 24 Old 05-25-2020, 02:02 PM
Quoted: 24 Post(s)
Liked: 5
If you want to keep the enclosure size down you can just put SI SQL-15 in a smaller 4cu.ft. net enclosure with very little output lose on the very low-end, with the same port tuning hz.
RBhifi is offline
post #16 of 24 Old 05-25-2020, 02:56 PM
johnson636's Avatar
Liked: 1283
Will the subs be colocated though? I could be wrong, but winisd doesn't calculate spl of subs in different locations. Again, I could be wrong.
post #17 of 24 Old 05-25-2020, 03:43 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
That would be good, thanks.
bogaboga is offline
post #18 of 24 Old 05-25-2020, 03:43 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
No. one in each corner.
bogaboga is offline
post #19 of 24 Old 05-25-2020, 03:47 PM
johnson636's Avatar
Liked: 1283
That may not be true in that case.
post #20 of 24 Old 05-25-2020, 03:59 PM
Quoted: 18 Post(s)
I would go with the biggest woofer that you can fit in your space. I went from 1 Dayton Audio 15 with a plate amp to 1 SI 18. Ended up building another 18. Downsized homes, now I have 1 DS115 18. My suggestion is go with the LaVoce 21, get a pro amp and be done with it. You can always turn down the bass. That 12 inch sub will probably not pressurize your room very well. My .02 cents.
johnson636 and jujuman200 like this.
ClevelandFreeman is offline
post #21 of 24 Old 05-25-2020, 05:19 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
How much gain I should expect then from adding three subs? I’m mostly doing it to deal with room modes.
bogaboga is offline
post #22 of 24 Old 05-25-2020, 06:02 PM
johnson636's Avatar
Liked: 1283
You will gain a smoother frequency response across all seats
post #23 of 24 Old 05-26-2020, 04:24 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
what style of bracing should i go with? window bracing or this style in the marty calculator
and how much is needed?
bogaboga is offline
post #24 of 24 Old 05-26-2020, 04:29 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 26
Also should I line the sub with insulation like fiber glass or rockwool? And can I just use the acoustic foam?
bogaboga is offline
