Veneer finishing question - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By ccssid123
  • 1 Post By scottvalentin
  • 1 Post By Trimlock
  • 3 Post By dftkell
post #1 of 13 Old 05-29-2020, 03:04 PM - Thread Starter
dftkell's Avatar
Quoted: 131 Post(s)
Liked: 90
Hello everyone,
I've just veneered my two subs and it's time to finish them. When I did this is the past, I lightly sanded them and then applied polyurethane and then repeated.
Is this the correct way to do it? Should I be included something to protect the finish?
It is a paper backed walnut veneer.
Dan
dftkell is offline
post #2 of 13 Old 05-29-2020, 04:09 PM
Quoted: 81 Post(s)
Doesn’t polyurethane protect the finish?
hessc50 is offline
post #3 of 13 Old 05-29-2020, 05:34 PM
smcmillan2's Avatar
Quoted: 1148 Post(s)
Liked: 969
Originally Posted by dftkell View Post
Hello everyone,
Dan
That's all I do - Sand, stain, poly. What elements are you trying to protect them from?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #4 of 13 Old 05-29-2020, 08:04 PM - Thread Starter
dftkell's Avatar
Quoted: 131 Post(s)
Liked: 90
I didn’t know if there was anything needed. I guess it shouldn’t need protection.
But, you add a stain before you poly? Or is it okay to just poly the veneer as is?
dftkell is offline
post #5 of 13 Old 05-29-2020, 08:06 PM - Thread Starter
dftkell's Avatar
Quoted: 131 Post(s)
Liked: 90
What stain or wood finish would you recommend? Thanks.
dftkell is offline
post #6 of 13 Old 05-30-2020, 12:35 AM
Quoted: 146 Post(s)
Liked: 159
This article should be of some help. Note....there is just plain stain ( which you would apply your poly over) and they make a stain /sealer product. I would go the plain stain route..if I had my druthers.
https://www.minwax.com/how-to-finish...E&gclsrc=aw.ds
Note: there are many other brands of stains out there. Stain only colors your wood/veneer. I had a painter make his own stain 40 years ago (when i built my house) by mixing some paint tint with gasoline. I am still admiring his workmanship to this day.
Sent from my SM-T800 using Tapatalk
dftkell likes this.
ccssid123 is online now
post #7 of 13 Old 05-30-2020, 06:31 AM
Quoted: 62 Post(s)
Liked: 61
If you want to change the colour/tone of the wood, then you would use a stain. Usually wiped on or sprayed on.
To protect the wood and stain, then you would use polyurethane on top of that. That is your finish. Poly cures and creates a protective layer.
For brands, I like any of the General Finishes stains or polyurethanes. Arm-R-Seal is what I would use for polyurethane. For walnut, I wouldn't do a stain unless you needed it much darker to match other furniture in the room. Sand to 220 or greater and 3-4 light coats of Arm-R-Seal wiped on with very light sanding in between coats and you should have a beautiful finish.
smcmillan2 likes this.
scottvalentin is offline
post #8 of 13 Old 05-30-2020, 06:58 AM - Thread Starter
dftkell's Avatar
Quoted: 131 Post(s)
Liked: 90
Will definitely check it out. Thanks.
dftkell is offline
post #9 of 13 Old 05-30-2020, 06:59 AM - Thread Starter
dftkell's Avatar
Quoted: 131 Post(s)
Liked: 90
Thanks! I have some left over that I'll play with and see how it looks with no stain and just poly.
dftkell is offline
post #10 of 13 Old 05-30-2020, 07:19 AM
smcmillan2's Avatar
Liked: 969
Depends on the look you're going for, as scottvalentin mentioned.
I've mostly used Minwax stains and poly. Sheen is another personal preference, I prefer satin (haven't found a decent flat poly, although I have some Varathane matte that I haven't tried yet).
post #11 of 13 Old 05-30-2020, 08:16 AM
Quoted: 571 Post(s)
Liked: 474
If you are still considering finish I’d give Osmo a look. Only needs a little, has good protection and is very easy to apply.
scottvalentin likes this.
Trimlock is online now
post #12 of 13 Old 05-30-2020, 08:13 PM
Quoted: 62 Post(s)
Liked: 61
I would second this suggestion as well. OSMO is VERY easy to apply, creates a nice non-glossy finish, and has decent protective properties. It is so so easy and looks amazing.
post #13 of 13 Old 05-31-2020, 05:06 AM - Thread Starter
dftkell's Avatar
Quoted: 131 Post(s)
Liked: 90
r I used a leftover sample to test first and it looked great with just the poly. Here are the two boxes, you can see what the poly does vs the unfinished, raw veneer. It’s exactly the look I was hoping for.
ccssid123, Jk7.2 and scottvalentin like this.
dftkell is offline
