Dual 12cuft Ported Lavoce SAN214.50 21" - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #31 of 45 Old 06-15-2020, 01:09 PM - Thread Starter
johnson636's Avatar
Quoted: 1764 Post(s)
Liked: 1292
Originally Posted by Sekosche View Post
Building two cabs at once seems like you’d save some time from repetition
Yeah, tell that to Lowes and Home Depot with their Covid-19 Policy and lack of supply
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Firestick- 125" wide 2.4:1 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 2 Lavoce SAN214.50 ported cabs 15Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #32 of 45 Old 06-15-2020, 02:19 PM - Thread Starter
johnson636's Avatar
Liked: 1292
First one is complete.
post #33 of 45 Old 06-21-2020, 02:12 PM - Thread Starter
johnson636's Avatar
Liked: 1292
First one done and in place
I promise that's a 21" Lavoce driver in a huge ported cab. The HS24, and its cab, make it look smaller than it is. After putting the sub in place, I see that I should've oriented the HS24 enclosures with the ports on top as well. It will be an absolute pain to flip them over to match the ports on the ported Lavoce 21
ID:	2746536   Click image for larger version
post #34 of 45 Old 06-22-2020, 05:09 PM - Thread Starter
johnson636's Avatar
Liked: 1292
Second cab coming soon I want to put this one together with some urgency. I'll be on vacation the week after 4th of July and I promised myself I wouldn't spend one second building anything. All I want to do is enjoy my theater
ID:	2747154   Click image for larger version
a77cj7 likes this.
post #35 of 45 Old 06-22-2020, 11:13 PM
Bandyka's Avatar
Quoted: 2546 Post(s)
Liked: 1641
Promises, promises
johnson636 likes this.
EPSON TW-9300 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, DIY Subs 18" 24hz tune and 12" 17hz tune Panasonic UB900, HTPC, etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-di...l#post50298297
Bandyka is online now
post #36 of 45 Old 06-23-2020, 07:38 AM
Craig S King's Avatar
Quoted: 469 Post(s)
Liked: 573
Nice work!
Craig S King is offline
post #37 of 45 Old 06-25-2020, 04:16 PM - Thread Starter
johnson636's Avatar
Liked: 1292
A little more work done today. Not sure if you can tell from the pic, but my roundovers came out a little better on this enclosure than the first one.
post #38 of 45 Old 06-28-2020, 10:56 AM - Thread Starter
johnson636's Avatar
Liked: 1292
I'm nearly done with the second cab. All that's left is cut out the port openings, flush trim, roundover the baffle, install wood inserts, install speakon connector, install driver and done
I knew the rear horizontal brace seemed off. The level was spot on, so that means my table is unbalanced
ID:	2750282   Click image for larger version
ID:	2750284   Click image for larger version
ID:	2750286   Click image for larger version
ID:	2750290   Click image for larger version
ID:	2750294   Click image for larger version
ID:	2750296   Click image for larger version
ID:	2750300   Click image for larger version
ID:	2750302   Click image for larger version
ID:	2750306   Click image for larger version
post #39 of 45 Old 06-29-2020, 05:54 PM - Thread Starter
johnson636's Avatar
Liked: 1292
Done All that's left to do now is the fun stuff; measuring, eq, listening, movies etc. I don't think I'll be building anything for my theater anytime soon... it is what it is for now Also, I got rid of my hum issue. It seems as though the Dayton dsp-408 was causing something funky when in the signal chain. I switched it out and replaced it with 2 minidsp 2x4s and the hum is no more I then tried the Dayton dsp-408 in my Man room connected to a xls1500, via rca input, and no hum is present I'm a happy camper right about now
Before roundover
After roundover
ID:	2750880   Click image for larger version
ID:	2750882   Click image for larger version
ID:	2750884   Click image for larger version
ID:	2750886   Click image for larger version
ID:	2750890   Click image for larger version
ID:	2750892   Click image for larger version
LTD02, filtor1, Bandyka and 3 others like this.
post #40 of 45 Old Today, 12:19 PM - Thread Starter
johnson636's Avatar
Liked: 1292
After dialing things in, I took a demo vid of my Theater. My UMIK was clipping to hell and back, so it's hard to say what SPL was being outputted. It was a little difficult to breath so I tapped out.
Name:	ALL Subs 7-12-2020.jpg
femi, Sekosche and Craig S King like this.
post #41 of 45 Old Today, 02:14 PM
Quoted: 469 Post(s)
Liked: 573
Impressive! You might want to anchor the top 2 devastators above the 24"s, looks like the top right cabinet was walking off the top.
post #42 of 45 Old Today, 03:16 PM - Thread Starter
johnson636's Avatar
Liked: 1292
And so was the left one I'll have to find a solution before something bad happens. Oh, daughter took a vid of the upstairs floor while I was in the basement.
femi, Bandyka and Sekosche like this.
post #43 of 45 Old Today, 03:38 PM
Sekosche's Avatar
Quoted: 1553 Post(s)
Liked: 3957
Nice videos! Based on your table dancing, it looks like you’re hitting 130dB or more at some frequencies, reminds me a little of @lukeamdman kitchen table videos
Did you set the dip switches and modify the config file on the UMIK for higher SPL before clipping? Based on your PJ movement and curtains shaking, that definitely seems like a lot more than 120dB so no doubt you’re clipping. I’ve had 120dB at my MLP with a lot less violence, and you definitely have way more firepower to hit well above that.
Speakers: PSA MTM-210T x2, MTM-210C, Volt-10 x2
Subs: PSA S1812 x2; MA’s: Crowson x2
Processing: Denon X4200, MiniDSP 2x4 HD
PJ: Epson 5050UB
Screen: Silver Ticket 106" HC
Sekosche is offline
post #44 of 45 Old Today, 04:01 PM - Thread Starter
johnson636's Avatar
Liked: 1292
Man, I've seen that video of @lukeamdman room. That was crazy! I'm not sure who the guys were in the video, but they measured over 100db outside his house
After screwing up my first umik, I decided to roll with the default settings on the new one. I believe I could squeeze a little more out of the 24s and devs, as those channels weren't even at -4. @femi @Nexgen76 I think my system is almost GTG worthy. That is whenever this damn Covid19 allows us to get back to our normal lives
Sekosche likes this.
post #45 of 45 Old Today, 11:09 PM
Bandyka's Avatar
Liked: 1641
https://youtu.be/Erf4_w-ZfZk
That's just nuts, and here I am worried about structural damage to my house
I've a spare boat anchor I can land you but I can't help with ear replacement
