Dual 12cuft Ported Lavoce SAN214.50 21" - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #1 of 39 Old 05-30-2020, 09:53 AM - Thread Starter
johnson636's Avatar
Quoted: 1759 Post(s)
Liked: 1285
So, the backstory on the purchase of these drivers is, I had two of these SAN214.50 drivers in my cart and forgot about them. They had been sitting there for maybe 3 months. PE sends me a one day 10% off offer and I jumped on them My original intentions were to purchase a Eminence NSW6021-6, but they're out of stock until June 5th...at least they're out of stock at PE. Besides, 2 ported SAN214.50 will best one ported Eminence NSW6021-6. I decided to go with ported for ease of build. I will wire the two cabs together for a 4ohm load and run them off a channel of the FP20k. Each sub should receive 1000w at full tilt. Should be interesting
ID:	2734616   Click image for larger version
ID:	2734618   Click image for larger version
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #2 of 39 Old 05-30-2020, 10:03 AM - Thread Starter
johnson636's Avatar
Liked: 1285
A little woofer porn
post #3 of 39 Old 05-30-2020, 10:56 PM
Sekosche's Avatar
Quoted: 1551 Post(s)
Liked: 3954
Good luck man! A pair of these are going to be downright wicked. I just got done moving the 10cu ft coffin upstairs into the new media room, and barely got it there safely without killing myself and my 19 year old nephew that helped (the extra long 72” dimension made it very difficult). I haven’t even hooked it up yet, but hopefully will get a chance this week.
Speakers: PSA MTM-210T x2, MTM-210C, Volt-10 x2
Subs: PSA S1812 x2; MA’s: Crowson x2
Processing: Denon X4200, MiniDSP 2x4 HD
PJ: Epson 5050UB
Screen: Silver Ticket 106" HC
Sekosche is online now
post #4 of 39 Old 05-31-2020, 03:35 AM - Thread Starter
johnson636's Avatar
Liked: 1285
Originally Posted by Sekosche View Post
Wow! That's one helluva sub! You did a magnificent job with it. Do you have a build thread? These two subs will replace 3 ported PA460. They'll be in the center position of the pic below. Once that's done, I won't have a subwoofer driver under 21"
filtor1 likes this.
post #5 of 39 Old 05-31-2020, 04:59 AM - Thread Starter
johnson636's Avatar
Liked: 1285
@a77cj7 and anyone else who can provide input on this matter. I want to use wood inserts to secure my driver to the baffle, but unsure how to go about installing the wood insert into a double baffle. This will be a bit different from the Dev, being it only has a single baffle. The longest insert I have is 0.789", so would one wood insert be enough?
post #6 of 39 Old 05-31-2020, 06:19 AM
mumbles60's Avatar
Quoted: 87 Post(s)
Liked: 47
.789 is about 20mm... the longest I have seen are 25mm, so not much bigger but should work if you are using something like baltic birch. If you're using MDF, I would recommend something like the T-nuts in the attachment, which allow you to secure with nails so the nut won't twist under repeated use. I also recommend using glue along with whatever insert you choose for added security.
jujuman200 likes this.
mumbles60 is offline
post #7 of 39 Old 05-31-2020, 08:41 AM - Thread Starter
johnson636's Avatar
Liked: 1285
Yep, using Baltic Birch for these. I've used wood inserts on my single baffled devs, but this will be the first time attempting to use wood inserts on a double baffle. I'll be using the insert below
post #8 of 39 Old 05-31-2020, 08:57 AM
Sekosche's Avatar
Liked: 3954
Thanks! You’ve got some ridiculous firepower now, and with only 21” subs I bet it’s incredible. You dropped a comment on my build thread last year. I’m actually downsizing all my drivers because the new media room is much smaller, so I don’t need the output and really want to simplify my system. I only muscled the LaVoce into the room because there’s a long delay on the new PSA subs I have on order and not having bass for this long sucks when the rest of the room is ready to rock.
https://www.avsforum.com/forum/155-d...0-a.html?amp=1
I used 3” wood screws for the driver, but I had a double baffle with a block of plywood also behind each hole. I did use threaded inserts for the feet though with gorilla glue and seemed to work very well for stability. I haven’t worked with tee nuts before, so I opted for something easy.
johnson636 likes this.
PJ: Epson 5050UB
post #9 of 39 Old 05-31-2020, 09:53 AM
a77cj7's Avatar
Quoted: 1037 Post(s)
Liked: 1080
In baltic birch, you will break the fastener before the insert spins in the wood. You are good to go.
Even in mdf, I’ve had no issue with 1” inserts in double or triple baffle.
Chris
a77cj7 is online now
post #10 of 39 Old 05-31-2020, 10:35 AM - Thread Starter
johnson636's Avatar
Liked: 1285
Don't forget about the two ported 24s
Originally Posted by a77cj7 View Post
In baltic bitch, you will break the fastener before the insert spins in the wood. You are good to go.
Chris
Thanks Chris, I feel better now. I had to tag you being as you're the king of inserts
a77cj7 likes this.
post #11 of 39 Old 05-31-2020, 11:02 AM
Sekosche's Avatar
Liked: 3954
I thought those looked like HS24’s, good grief man. What’s the tune and cab size on those?
PJ: Epson 5050UB
post #12 of 39 Old 05-31-2020, 11:48 AM - Thread Starter
johnson636's Avatar
Liked: 1285
If I remember correctly, they're 20 cuft tuned to 15Hz. They were an absolute pain to move into place
SpinMonster and Sekosche like this.
post #13 of 39 Old 05-31-2020, 11:57 AM
Bandyka's Avatar
Quoted: 2542 Post(s)
Liked: 1637
Yeah, the rabbit hole...
I definitely get you now
Mike Butny and johnson636 like this.
EPSON TW-9300 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, DIY Subs 18" 24hz tune and 12" 17hz tune Panasonic UB900, HTPC, etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-di...l#post50298297
Bandyka is online now
post #14 of 39 Old 05-31-2020, 11:58 AM - Thread Starter
johnson636's Avatar
Liked: 1285
A little work done today. They is my stopping point
@Bandyka Man, I'm so deep down that damn hole it isn't even funny. I've had the sickness for quite some time now. Luckily for me, there's plenty of company down the hole
jujuman200, Sekosche and Bandyka like this.
post #15 of 39 Old 06-04-2020, 06:44 AM - Thread Starter
johnson636's Avatar
Liked: 1285
It seems I miscalculated how many 4x8 sheets I needed to complete my first cab...one short. So, yesterday I went to 3 different HDs in three different cities, each panel saw was out of service Decided to go to Lowes and no "out of service" notice on the panel saw Asked an employee alert someone to help me with the saw and he told me they are not allowed to use the saw due to Covid19
post #16 of 39 Old 06-04-2020, 07:36 AM
Sekosche's Avatar
Liked: 3954
Oh that’s ridiculous, I actually had them cut down a few things for me at HD and Lowe’s in the last couple weeks, but maybe their policies changed. That’s a lot of busted saws! Hope you get up and running soon. Nothing like wasted time on a build.
PJ: Epson 5050UB
post #17 of 39 Old 06-04-2020, 07:46 AM - Thread Starter
johnson636's Avatar
Liked: 1285
For the life of me, I can't understand how using the panel saw puts anyone in anymore risk than any other activity that goes on at Lowes Looks like I'll have to load up a 4x8 sheet on my truck and break it down when I get home
post #18 of 39 Old 06-04-2020, 02:58 PM - Thread Starter
johnson636's Avatar
Liked: 1285
OK, I'll break it down myself
Sekosche likes this.
post #19 of 39 Old 06-04-2020, 08:42 PM
N8DOGG's Avatar
Quoted: 1494 Post(s)
Liked: 1760
Chris
That Baltic Bitch is always bustin wood.....
Blasting brown notes for 20 years and counting!
N8DOGG is offline
post #20 of 39 Old 06-04-2020, 09:04 PM
a77cj7's Avatar
Liked: 1080
Oops, smartphone typing fail.
Chris
N8DOGG likes this.
post #21 of 39 Old 06-05-2020, 06:31 AM - Thread Starter
johnson636's Avatar
Liked: 1285
A little more progress
ID:	2738674   Click image for larger version
ID:	2738676   Click image for larger version
ID:	2738678   Click image for larger version
ID:	2738680   Click image for larger version
Niavlys and Bandyka like this.
post #22 of 39 Old 06-05-2020, 10:54 AM - Thread Starter
johnson636's Avatar
Liked: 1285
My wood insert work is not on par with @a77cj7 , but it'll do
ID:	2738692   Click image for larger version
ID:	2738694   Click image for larger version
ID:	2738696   Click image for larger version
ID:	2738698   Click image for larger version
Niavlys and a77cj7 like this.
post #23 of 39 Old 06-05-2020, 11:32 AM
dasa2131's Avatar
Quoted: 109 Post(s)
Liked: 116
Looks like you've also got a Festool track saw. They are wonderful! I like using mine much more so than using a table saw. I'm eager to hear how you like this new build - I've been considering buying some of the Lavoce subs.
Dave
dasa2131 is offline
post #24 of 39 Old 06-05-2020, 11:43 AM - Thread Starter
johnson636's Avatar
Liked: 1285
Dave
It does come in handy when dealing with large stock. I love the repeatability of the the table saw though
post #25 of 39 Old 06-06-2020, 03:37 PM
Craig S King's Avatar
Quoted: 468 Post(s)
Liked: 572
What's going to happen with the PA460s now?
Craig S King is offline
post #26 of 39 Old 06-06-2020, 07:16 PM - Thread Starter
johnson636's Avatar
Liked: 1285
The last two will go into my Man Room
jujuman200 and femi like this.
post #27 of 39 Old 06-07-2020, 05:25 PM - Thread Starter
johnson636's Avatar
Liked: 1285
Nearly done All that's left is flush trimming, install the speakon, and mount the driver.
ID:	2738702   Click image for larger version
ID:	2738704   Click image for larger version
ID:	2738706   Click image for larger version
ID:	2738708   Click image for larger version
ID:	2738712   Click image for larger version
ID:	2738714   Click image for larger version
ID:	2738716   Click image for larger version
Sekosche and chadsmith013 like this.
post #28 of 39 Old 06-15-2020, 09:43 AM
Sekosche's Avatar
Liked: 3954
Looking good! You jamming out with these yet?
I really wish I put handles on my coffin build, maybe next time.
PJ: Epson 5050UB
post #29 of 39 Old 06-15-2020, 09:48 AM - Thread Starter
johnson636's Avatar
Liked: 1285
Not yet. I still have to build the second enclosure. I had other things that required my attention.
Oh, in your case, handles alone wouldn't do. You'd also need two pallbearers as well
post #30 of 39 Old 06-15-2020, 01:02 PM
Sekosche's Avatar
Liked: 3954
Not yet. I still have build the second enclosure. I had other things that required my attention.
Haha! I nearly killed myself getting it up the stairs into my media room with my nephew helping, and we’re both about 225lbs each. And now I’ve got two more 18” subs coming, so I’m going to probably move the 21” back out of the room until I build it a more appropriate enclosure for this space.
Building two cabs at once seems like you’d save some time from repetition, but it still took me twice as long with my pair of nearfield cabs as building my first single sub. I know these big cabs are a bear to work with, so I feel your pain!
Good luck finishing up!
PJ: Epson 5050UB
