Custom 3-way Mains with TPL-200H and 18ds115 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1 of 74 Old 06-21-2020, 08:37 PM - Thread Starter
a77cj7's Avatar
Quoted: 1037 Post(s)
Liked: 1080
I’ve been considering upgrading my Goldenear LCR to some diy designs. I was looking at various proven designs, but traditionally love ribbon, planar, and AMT tweeters.
I ended up getting a decent deal on 3 Beyma TPL-200/H’s. So I’m completely skipping the basics of DIY speakers and jumping off the deep end with a full custom build.
My plan is three way active, with the tpl-200h, an undecided sealed mid, and the 18ds115 woofer ported.
I hope to find crown dci-n amps to use for power and processing. If not, I will get an ashly 24.24m for processing, and use my current analog dci amps.
Planning 1200hz crossover mid to tweet, maybe 350hz woofer to mid.
For mids, I’m currently most interested in the AE TD10M and TD12M, and the Beyma 12p80ndv2. I’m open to other suggestions.
The ae’s seem to be considered the reference mid, while the beyma is significantly cheaper, higher sensitivity, and has more motor force.
The faital 12fh520 and 12pr300 look promising as well.
The 18ds115 will be in 5cu roughly, tuned to 35hz.
I already have 2 of the 18ds currently in mini devastators, and picked up a third open-box recently.
The mini dev’s will be swapped to a modified version of the mini 21 v4, loaded with nsw6021’s.
I haven’t had time to do much modeling yet for volumes.
I plan to build the woofer modules to 25.5” high x 24” deep x 20” wide. This matches the mini-dev profile and will give me a size-matched front lineup.
Here’s the current setup:
There will be a woofer module between the mini dev’s, and one on each end.
Eventual plan is an at screen even with the front of the cabs. Is there a problem with having the mid and tweet farther back than the woofer?
Since the at screen and new projector are a ways off, this leaves me two options for the center. First is to use my current center and the woofer module as a two-way.
Second is to build a horizontal mtm with the beyma and some 8” mids. The faital 8pr200 looks like an excellent driver. Since I’ll be running 3-way, the b&c 8pe21 (Edit: scratch this one. 8mbx51 and 8mdn51 have potential) may make more sense though.
I should have available processing and amp channels to run this 3.5 way, if that would help.
I’m just at the start of the process, and know I have lots of modeling in my near future. Followed by building and measuring.
I will be able to do outdoor measurements on these.
I’m hoping for some guidance, whether I’m even on the right track here.
Driver suggestions for mids are also appreciated.
@Javs , I believe you use the similar tpl150h’s, the beyma mid, and the faital 8’s. Your guidance would be particularly appreciated.
Bonus pic, tpl-200h’s with my current center:
They’re a whole different scale.
Chris
automata21, Javs, gpmbc and 4 others like this.
a77cj7 is online now
post #2 of 74 Old 06-22-2020, 02:45 PM
Javs's Avatar
Quoted: 7222 Post(s)
Liked: 6908
Hey
Good project! I jumped into the deep end too, its very rewarding in the end and worth the time to learn.
I do have some thoughts...
Considered reference by those that have never tried the Beyma? While I havent tried the AE, I cant fault my Beyma's. If they are significantly cheaper for you (which was the case for me too), I say jump on the Beyma and dont look back. Else, if you were to get the AE, I would get the 10" version not the 12. If Beyma made a 10p80Nd or an 8" I would try those. Not that I hear or even measure the 12" beaming, its just always considered large for a mid and a 10 or 78 mid would measure better polar and probably have slightly more compatible directivity for the TPL, again, not that I really measured any issues with mine, its just 'textbook' reasons. Since the TPL has no issue at all with a 1200hz crossover at 24+db octave (I would know) then there is no probs with a 12" mid, even up to about 1600hz.
Dont bother look at the 12FH520 or 12PR300 for your mid, I am actually using 12FH's for my LF woofers in my old towers and my current center and they are outstanding. They actually measure REALLY well up into the mid range too, but the Beyma has a super light diaphragm and its speed is on a whole other level.
Hmm I would reconsider the horizontal MTM idea, you will have guests sitting right in the middle of lobe cancellations, that's probably the worst possible center configuration that exists... I use my 8" MTM in a vertical config and there is no issues with that, but I wouldnt put it on its side, I wish, I would have done it already, but it wont work.
I would go 3 way for your center too, but use two Faital 6PR160's side by side under the TPL so you dont have any issues with lobing and a couple of 12FH520''s on the sides or two other LF woofers as you planned. I made this speaker twice (with 12FH;'s) for a forum member and his mate and its quite good and a beast of a center speaker, it sounded great and very clear along side my modular towers which use the Beyma mids. It digs down to 40hz with crazy authority and can easily shake the windows on its own.. tested it in isolation with the blade runner intro and my wife thought I had all my subs on.
6PR160
TPL 150H
Speaker:
12p80Nd from my modular tower.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #3 of 74 Old 06-22-2020, 03:50 PM - Thread Starter
a77cj7's Avatar
Liked: 1080
Originally Posted by Javs View Post
Hey
6PR160
TPL 150H
Speaker:
Thanks Javs!
I find glowing reviews of the ae and the beyma, but nothing that anyone has tried both.
Without the apollo upgrade, the td10m is $409. The Beyma is $349 from usspeaker, so not a significant difference.
If I go apollo upgrade, the td is $559.
I can snag some 12p80nd’s off ebay for under $280 shipped, but they are not v2. I believe the v2 is a big upgrade, specifically toward cone breakup.
Good to know on the faital 12’s, thanks.
That center is beautiful, but absolutely won’t fit in my setup. With the planned woofer module, I already have to raise the screen an inch or two to clear the tpl.
That said, I can build a temporary, non-matching woofer module.
20” wide by 36” tall x 24” deep is the limit.
I’d really like to use the 18ds115, as I already have it.
If I push it all the way to the bottom of the cab, I can fit the 6” mids and tpl above it. Might have to get a bit crazy with triangle ports, but should be able to get enough area.
I can get the faital mids from usspeaker for 145 + shipping.
I can get the VERY similar w6n8-120 for $135 shipped from PE, if that will work just as well. If not, I’d rather spend extra than lose performance.
Thanks again,
Chris
post #4 of 74 Old 06-22-2020, 04:16 PM
Javs's Avatar
Liked: 6908
Thanks Javs!
Thanks again,
Chris
Got a link to the ebay page? I know what V2 looks like on sight. Are they used? The V2 has been around since 2016
the w6n8-120 wont measure as well. The 6PR160 is a brand new driver from Faital. I was the first to use it. Its really very good.
Javs is offline
post #5 of 74 Old 06-22-2020, 04:27 PM - Thread Starter
a77cj7's Avatar
Liked: 1080
I know they are v1’s. Double-roll surround instead of triple. Brand new, 4 ohm.
https://www.ebay.com/itm/264759269717
Spend more for the 6pr160, got it. How come the answer to everything around here is spend more?
Honestly surprised the apollo td10m isn’t required too. But I guess you use the Beyma.
Hope I don’t have to buy one of each to play with.
Thanks again,
Chris
post #6 of 74 Old 06-22-2020, 04:33 PM
Javs's Avatar
Liked: 6908
Thanks again,
Chris
Ah yeah def v1. I wouldnt buy those.
I havent tried the AE drivers, And frankly I am not interested in them being in Australia. I get the Beymas landed directly from Beyma having trade pricing not interested in full price AE drivers... From what you were saying even your pricing is $150 each higher or so for the phase plug, thats still too high. If you go over to DIYAudio a lot of people are using the 12P80 with the TPL for a reason.
I would try the AE to see what the fuss is about but I am really not sure I would hear a difference worthy of the extra money it would cost to get them.
Javs is offline
post #7 of 74 Old 06-22-2020, 04:40 PM - Thread Starter
a77cj7's Avatar
Liked: 1080
Yup, there was some rapid driver-identification when I found that listing, lol.
The apollo upgrade isn’t the phase plug, that’s standard.
Here’s their writeup:
http://aespeakers.com/apollo-upgrade...ortion-option/
Again, they’re similar cost to me without apollo. I might have to post over on diyaudio to see if anyone has tried both.
Chris
post #8 of 74 Old 06-22-2020, 05:19 PM
johnson636's Avatar
Quoted: 1759 Post(s)
Liked: 1285
Man, can't wait for this build to get started. I'll be following every step of the way
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #9 of 74 Old 06-25-2020, 12:28 PM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
As you are in the USA, the TD10M is the best option, no need to get the Apolo upgrade for home use.
The TD10M will allow for a higher crossover point, thus giving you a wide range of crossover points to try.
Moreover, if for some reason one driver gets damaged, it should be easier to get it repaired by AE.
neo_2009 is online now
post #10 of 74 Old 06-25-2020, 02:12 PM
donivan's Avatar
Quoted: 57 Post(s)
Liked: 46
What about the TD15M, seems like that is the gold standard from AE.. I have seen two measurements showing -6db at 40 deg off axis at around ~1200 hz which matches the TPL horn; one of them was on diyaudio. It may limit your crossover points but if you are already thinking 1200 then it may work. It's been a while but seems like the TD15M with its curvilinear profile wasn't too far off the TD12M in terms when it started beaming.
donivan is offline
post #11 of 74 Old 06-25-2020, 05:59 PM
BassThatHz's Avatar
Quoted: 4058 Post(s)
Liked: 4579
Should be able to get away with a 1.5khz XO, definitely want to stay away from that 5.5khz peak.
You may also want to boost the 10k-20khz flat *if* that doesn't make it sound too bright or increase the wattage/strain too much.
Other than that, looks good.
BassThatHz is offline
post #12 of 74 Old 06-25-2020, 06:05 PM - Thread Starter
a77cj7's Avatar
Liked: 1080
Hmm, one vote for the ae, one for Beyma. I hope I don’t have to buy one of each and see what measures/sounds better. It is an option though.
I’m not too concerned with damaging a mid. Should be the least likely of three drivers to fail in this setup.
Still, a valid point.
Chris
post #13 of 74 Old 06-25-2020, 06:09 PM - Thread Starter
a77cj7's Avatar
Liked: 1080
I’m pretty sure I’ll go with the TD10m if I go AE.
I’m not sure what the advantage of the larger drivers would be in this system.
With the 18ds115 bringing up the low end, I certainly shouldn’t need more displacement.
Since I’ll be running active, with 600w available to the mid, sensitivity matching shouldn’t matter too much.
The 10 is similarly sized to the tpl, and will require a smaller cab. That plus the crossover option seems to be a win.
Chris
neo_2009 and donivan like this.
post #14 of 74 Old 06-25-2020, 07:06 PM
Quoted: 571 Post(s)
Liked: 474
I’ve only ever seen one other project use the TPL200, kind of excited to see the outcome of this.
BTW I vote for BMS.
Trimlock is offline
post #15 of 74 Old 06-25-2020, 07:17 PM - Thread Starter
a77cj7's Avatar
Liked: 1080
BTW I vote for BMS.
I’ve only seen one project use them as well.
This one: https://www.avnirvana.com/threads/bu...tpl-200h.1510/
Luckily (or sadly), I now own that pair of tpl-200h’s.
I was planning on tpl-150h’s, but got a decent deal on the 200’s.
What BMS are you suggesting? I didn’t look at them very close, as they seem to be very hard to get in the US. A quick look at the 12” shows nothing as good as the Beyma or AE.
Chris
post #16 of 74 Old 06-26-2020, 01:49 AM
Javs's Avatar
Liked: 6908
I think thats the 6PR160 you are looking at?
Javs is offline
post #17 of 74 Old 06-26-2020, 03:02 AM
A9X-308's Avatar
Quoted: 2035 Post(s)
Liked: 1751
Superb driver. I have 4 and have used them in a number of projects the last being my TD15/TD10/CD+WG surrounds.
The next use for them after the move is a 2xTD10, ATC SM75/150S mid and TPL150H active 3 way.
One thing to note is the frame is a bit larger than most pro 10's.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #18 of 74 Old 06-26-2020, 03:32 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
I assume he's referring to the BMS 18N862.
An amazing driver, but: 1) you already have the B&C 18ds115; 2) Given that you're in the USA, if you wanted a 18" and weren't looking for max extension, the best option would be an AE TD18H+
post #19 of 74 Old 06-26-2020, 07:42 AM
Quoted: 571 Post(s)
Liked: 474
Chris
Oops meant the Beyma, have BMS on the mind
You can order BMS drivers through Assistance audio, if you were to ever want to give most BMS drivers a shot.
Trimlock is offline
post #20 of 74 Old 06-26-2020, 07:53 AM
Quoted: 571 Post(s)
Liked: 474
Hah! If only...
Trimlock is offline
post #21 of 74 Old 06-26-2020, 08:43 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Hah! If only...
Would you mind to elaborate? I'm sorry, i'm not following your line of thought
I have 2 BMS 18N862 as subwoofers, they are amazing drivers.
But for a 3 way speaker, unless the goal is max extension, the AE TD18H+ is a better driver, moreover as the OP is in the USA.
Nevertheless, its a moot point, as the OP already has the B&C 18ds115 he want's to use.
Unless ...
@a77cj7 , what about trying to sell the B&C drivers, you should be able to sell them for a good price ...
Then you could go with a TPL-200 + TD10M + TD18H+ !!!
IIRC, @Mike Garrett uses a TPL-150H + TD10M + TD18H+, so maybe he can provide his input
post #22 of 74 Old 06-26-2020, 09:31 AM
Quoted: 571 Post(s)
Liked: 474
Unless ...
The 18N682 is practically unobtanium here in the US, you can order it but it’s even more expensive then. I’ve watched ebay and other online retailers for a while trying to snag a few but the prices are usually outrageous. I eventually broke down and got the NSW6021’s and bought a few FP1030’s.
I don’t think it’ll be worth it for the OP to switch at this point, with the planned cross over with the 18DS I don’t think he’d notice much difference with the 18H+.
neo_2009 likes this.
Trimlock is offline
post #23 of 74 Old 06-26-2020, 09:56 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
I agree, when we reach these type of quality, i doubt we would be able to distinguish between a proper speaker implementation using the drivers mentioned here.
It's just that when using these high end driver, why not using the best there is just from the start, so there's no "regrets" or "what if's" later ...
@a77cj7 , an interesting approach is the one used by Javs, by using separate enclosures for each driver, which would allow you in the future to swap drivers if needed.
Trimlock likes this.
post #24 of 74 Old 06-26-2020, 10:09 AM - Thread Starter
a77cj7's Avatar
Liked: 1080
@Trimlock , @neo_2009
I’m not ignoring you guys, I just prefer to answer somewhat informed. I’m trying to run models on the bass modules, but keep getting distracted/called away.
As of now...
The 18ds115’s are for sale in my mini dev’s, over in the FS section. If someone chooses to buy them that way, it would leave my options completely open. I have 40 days to return the third to PE, or I bet I can sell it for the awesome open-box price I got on it.
(The box was opened, but the driver was still banded into cardboard. Had never been powered or mounted)
I consider the 18ds115, the TD18H, and the 18n862 to be excellent options.
The 18ds has by far the most motor force. That may be good for small-box, or may be bad for port velocity.
The 18n862 will cost the most, and is only rated to 200hz response. The graph looks clean above that, but maybe distortion is an issue. Along with the difficulty of getting them, probably the least likely candidate. Looks like it would work well sealed.
The TD18h+ seems to be the go-to driver for cost-no-object builds (as are the td-m mids). Looks like it will work sealed or ported.
I’ll share models if I ever get them done. Will be modeling the td10m and 12p80ndv2 also.
Chris
post #25 of 74 Old 06-26-2020, 10:27 AM
Mike Garrett's Avatar
Quoted: 14044 Post(s)
Liked: 11709
Unless ...
I use dual TD12M's with TD18H+ and TPL-150H. I already had three TD12M's, is why I used those. If starting from scratch, I would use the TD10M. Not because I am unhappy with the TD12M's, I just think the TD10M is a little better match and would allow you to experiment with higher crossovers.
Mike Garrett is online now
post #26 of 74 Old 06-26-2020, 10:29 AM - Thread Starter
a77cj7's Avatar
Liked: 1080
Awesome. What crossovers are you using (Frequency and hardware)?
Got any pics?
I feel like I’ve seen your build before, but its been awhile.
Chris
post #27 of 74 Old 06-26-2020, 10:51 AM
Liked: 11709
Got any pics?
Chris
Using a couple DBX DriveRack PA2's for crossover and DSP. Like these much better than the MiniDSP10x10HD's I was using.
TD18H+ in separate cabinet and TPL-150H is boxed out with back cup removed.
High pass 1.2kHz LR24db for TPL-150H
High pass 250Hz LR24db TD12M/TD12M low pass 1.1kHZ LR24db
Low pass 200Hz LR24db TD18H+
Name:	Angled baffle wall.jpg
ID:	2749430   Click image for larger version
Name:	V6 installation pic 1.jpg
ID:	2749434   Click image for larger version
Name:	TD18H+ for LCR's.jpg
ID:	2749436   Click image for larger version
Name:	V6 completed.JPG
neo_2009 and CallingMrBenzo like this.
post #28 of 74 Old 06-26-2020, 11:02 AM - Thread Starter
a77cj7's Avatar
Liked: 1080
Awesome setup, thanks for sharing. How big is the screen?
Yeah, I use a minidsp 4x10 for my sub channel. Works great for that, but has quirks and I didn’t feel they were appropriate for high-sensitivity mains. Plus, one channel short, as are most dsp’s.
I’m hoping to use crown dci-n amps with internal dsp. I figure that if its good enough for the JBL m2, it should be good enough for me.
Otherwise, I’ll ebay a ashly 24.24m. Reportedly completely silent on high efficiency cd’s, and can have plenty of channels with right cards installed.
Why the dual mids?
Any issue with the woofer being forward of the mid and tweet? I hope not, as that is my intention as well.
What volume on tpl rear chamber? Lined with denim? Foam still in place on tpl?
post #29 of 74 Old 06-26-2020, 11:15 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
According to Ricci from data-bass.com:
Parameter testing and impedance measurements show that the inductance is very well controlled, which is not surprising due to the triple shorting rings in the neo motor. When combined with the light moving mass this gives the 18N862 a very nice top end, which should be useful up till at least 400-500Hz. It would make a great woofer for a large three way
This driver makes a lot of sense in Europe, not so much in the USA, as its way expensive.
post #30 of 74 Old 06-26-2020, 01:29 PM
Quoted: 571 Post(s)
Liked: 474
Troels uses it in his large 3 way, don’t remember what his cross over was, I think 500hz?
I’m sure the 18DS will be a good large bottom end, I’d have to look up more about it but I don’t see why it couldn’t handle even a 300hz cross over.
Trimlock is offline
