Single SI HT 18DD4 with Inuke NX6000D wiring Q - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-25-2020, 01:39 PM - Thread Starter
rfbrang's Avatar
Quoted: 355 Post(s)
Liked: 114
I have a single full marty built so I can baseline our basement theatre as I add layers of sheetrock. I thought I have everything correct until I tried it and got virtually no sound. It might be the Denon or inuke settings, but I saw something about another DVC in a recent thread. (maybe a UM18-22 thread?)
On an SI HT18d4, do I use the top or bottom wiring scenario. I went back to the12volt.com and I can't tell where the jumper wire is supposed to be. Between the red and black post on the same side or opposite sides of the speaker?
Name:	DVC wiring Q.png
Our Old Space
New House
PSN: brotj7
rfbrang is offline
post #2 of 9 Old 06-25-2020, 01:40 PM
a77cj7's Avatar
Quoted: 1043 Post(s)
Liked: 1085
Bottom.
Top will be powering one coil, and shorting the other.
Chris
a77cj7 is online now
post #3 of 9 Old 06-25-2020, 01:41 PM - Thread Starter
rfbrang's Avatar
Quoted: 355 Post(s)
Liked: 114
Originally Posted by a77cj7 View Post
Bottom.
Chris
Thank you, that explains it.
Our Old Space
New House
PSN: brotj7
rfbrang is offline
post #4 of 9 Old 06-25-2020, 02:07 PM
smcmillan2's Avatar
Quoted: 1148 Post(s)
Liked: 971
For D4 don't you want to wire in parallel to provide a 2Ohm load to the amp?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 9 Old 06-25-2020, 02:27 PM - Thread Starter
rfbrang's Avatar
Quoted: 355 Post(s)
Liked: 114
I think I read it is not 2 ohm stable. But with all I read, I am only now learning what this all means. I just hope I don't fry the coils running only 1 full marty on channel A.
While I'm at it, do these look right? I am currently using a Denon 4520cl --> inuke NX 6000D --> 50ft speakon cable --> full marty in the basement directly below. I just want to measure what the living room hears and and what the basement hears prior to adding sheetrock, not dial it in yet.
ID:	2748874   Click image for larger version
ID:	2748876   Click image for larger version
Our Old Space
New House
PSN: brotj7
rfbrang is offline
post #6 of 9 Old 06-25-2020, 02:43 PM
smcmillan2's Avatar
Liked: 971
Ahh yes, true. I forgot the 6k is a pair of the 3k bridged so not 2-ohm stable, my bad.
As you were...
post #7 of 9 Old 06-25-2020, 07:07 PM
Liked: 2
Set your limiter to the rms wattage of your sub and you shouldn't need to worry about blowing your sub.
filter 1 should be an -4 at 20hz and HS12, with the main gain set to +4
SSinstaller is offline
post #8 of 9 Old 06-26-2020, 03:34 AM - Thread Starter
rfbrang's Avatar
Quoted: 355 Post(s)
Liked: 114
Thank you, will finally be able to test today.
Does the dual or stereo matter if it is just one sub?
When I set/load the gain in the software to the amp, where should the dial be on the amp?
Our Old Space
New House
PSN: brotj7
rfbrang is offline
post #9 of 9 Old 06-26-2020, 10:33 AM
Liked: 2
Doesn't matter if you're only using one channel.
Those knobs are input attenuation, they should be set so your just at/below clipping at your max listening volume.
