Absolute Best LF Driver for Music Only Application - AVS Forum | Home Theater Discussions And Reviews
post #1 of 109 Old 06-08-2007, 07:09 PM - Thread Starter
jxo
jxo's Avatar
It's been a few years since I looked at sub drivers and am being a bit lazy.
TCSounds still looks like they've got some impressive stuff.
For me, I have a high end 2-channel music system. Room size: 35x15x9-1/2. This will be for music only. No HT. The mains will be crossed at 80Hz or so.
Can anything beat the TC3k in a 3.6 cu.ft. sealed box?
How's the SDX15?
Will use Crown or QSC amp with either Bryston or Marchand crossover.
Jim
jxo is offline
post #2 of 109 Old 06-08-2007, 07:24 PM
poormanq45's Avatar
Check out the LMS5400
poormanq45 is offline
post #3 of 109 Old 06-08-2007, 07:31 PM
meeks32's Avatar
Liked: 27
They claimed that the lms4000 was their best sounding driver, but they dont make them anymore. Also many say that the tc2k is a better sounding driver than the 3000.
meeks32 is offline
post #4 of 109 Old 06-08-2007, 07:58 PM
kramskoi's Avatar
How's the SDX15?
don't you know that NOTHING beats the tc3k in 3.6 sealed??? ...just kidding...it IS a formidable driver though, especially in multiple sealed configurations...i'll leave it at that.
"Frequency response is NOT efficiency response."
Klipsch RB-35's main
Klipsch RB-35's surround
Acoustech HT-65 center
Cerwin-Vega CV-2800
Subwoofer
B&C 21SW152-4  [21" critical-Q]
kramskoi is offline
post #5 of 109 Old 06-08-2007, 08:23 PM
crackyflipside's Avatar
crackyflipside is offline
post #6 of 109 Old 06-08-2007, 08:49 PM
deneb's Avatar
Supposedly the TC2k is the 'sound quality' driver, while the TC3K is more of an excursion driver. My guess is that either of those would sound excellent in a sealed enclosure of the appropriate size.
One or a pair of the Rythmik kits deserves consideration as well IMO.
http://www.rythmikaudio.com/
deneb is offline
post #7 of 109 Old 06-08-2007, 09:04 PM
The Rythmiks are good for the price,but to put them on par with a tc3k or a 5400 is kind of silly. I think the OP is looking for an extreme driver.
post #8 of 109 Old 06-08-2007, 09:25 PM
zkaudio's Avatar
if it's for a 2.1 setup, the rhythmik is probably the best option... how loud are you going to go? the 15" rythmik is i think over 100db flat from 80 down. I am kinda on the same fence as this guy.. lots of audiophilic listening, minor ht duty. I think the 2k and 3k are great drivers but are bound to have slightly lower sq than a servo controlled tc 1k (which is pretty much what a rythmik is)
zkaudio is offline
post #9 of 109 Old 06-08-2007, 09:32 PM
I don't know man, I have a Rythmik and agree it's a great sub. But to say it's the best option for a sub... Maybe if the OP gave a size restriction for a very small sub then the Rythmik would win.
post #10 of 109 Old 06-08-2007, 10:26 PM
TheEAR's Avatar
TC-3000 an SPL driver.... Watch out it is also a SQ driver in the proper hands and...setup.
I am going to order dual TC-1000 and TC-2000 this monday. I want to hear it all...TC-5200 and LMS comming later when they have stock.
Anything TC Sounds/Sound Splinter can sound darn good when installed in a proper cabinet and with the correct filters applied.
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
post #11 of 109 Old 06-08-2007, 11:09 PM
Gir_1337's Avatar
I still stick with a t-line for music only subs. I've only had the pleasure of listening to one t-line, but I loved it! Great stuff for music, with a great natural and clean sound.
Gir_1337 is offline
post #12 of 109 Old 06-09-2007, 12:02 AM
Willd's Avatar
I'd definitely look at the SDX15 and the TC-2000
Willd is offline
post #13 of 109 Old 06-09-2007, 06:41 AM - Thread Starter
jxo
jxo's Avatar
Great feedback. thanks much. Cabinet size is 3.6 cu.ft. max. I would NOT listen at extreme SPLs and don' need ultra low extension. 100% music-- of all kinds, orchestral, organ, etc... As a previous poster indicated, this has an audiophile slant not HT (no bombs will be going off).
What are people's views on simple sealed vs. PRs? Nick McKinney (Lambda Acoustics) liked the PRs and helped me with an older design. I just never got around to building it-- now's the time.
I need to locate electronics away from the sub-- so crossover, amp, bass management are going in the equipment rack and the sub will be passive. Guess this may rule the servos (I assume you need coordinated electronics in the sub).
thanks,
Jim
Jim
jxo is offline
post #14 of 109 Old 06-09-2007, 06:58 AM
poormanq45's Avatar
If you're listening to organ music you are going to need good extension down to ~16hz
post #15 of 109 Old 06-09-2007, 09:18 AM - Thread Starter
jxo
jxo's Avatar
Organ music will once in a blue moon; would not want to make compromises elsewhere just to accommodate an occasional listen in the 15-16Hz area. performance, quality and integration in the 20-80Hz region would seem to be more important.
Jim
jxo is offline
post #16 of 109 Old 06-09-2007, 10:27 AM
poormanq45's Avatar
With a properly designed sub tuning down to 15hz will not cause any compromises near the crossover frequency.
It's all a matter of the Le(inductance) of the driver used
post #17 of 109 Old 06-09-2007, 12:06 PM
Okay so the box size is restricted to 3.6cuft
Making it bold so anybody who wanders in the thread notices.
post #18 of 109 Old 06-09-2007, 04:25 PM - Thread Starter
jxo
jxo's Avatar
Feels like there have been a few polite debates on this topic already.
OK with a 3.6 cu.ft. limit:
1. lms 5400 in a simple sealed box with decent crossover (bryston, marchand, velodyne) and amp crown or qsc
vs.
2. Rythmik 15" servo ???
I looked at the Rythmik site and it sure talks the right game from a musical performance perspective. I know squat about servos. can the servo be adapted for use for higher end tc sounds drivers?
the 15" Aura Sound looks interesting too..
Jim
jxo is offline
post #19 of 109 Old 06-09-2007, 08:18 PM
kgveteran's Avatar
Quoted: 837 Post(s)
Liked: 246
I think the key to a design is an accurate use of drivers and amplifiers. The idea is to out sub the mains.
What are the mains ? What do you power them with.How far from the mains do you sit ? Have you measured what level you really listen at ? With a 20hz low limit your choices are vast. Lets get some of these questions answered so we don't overkill this design.
Cheers KG
In a thread i started, another point of integration is what driver takes the signal after the subwoofer ? What you want to avoid is handing over a signal @ 80hz to a 6.5" driver . There is no way that type of driver can relay the same character or intentsity.Some food for thought
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #20 of 109 Old 06-09-2007, 09:12 PM
Looneybomber's Avatar
Liked: 29
I may be alone on this, but I find that horn loaded enclosures sound good for music. Trying to have others pick out an "end all" SQL woofer is a losing battle due to personal preferences in music. Some people perfer sealed, others ported and I am voting for horn loaded. Each has a woofer better suited for that application, so knowing what alignment you want would help too.
Purely "bench racing" here since I've not listened to these in person, but I would think a sealed Dayton RS 15" or a Rythmic 15" would be more than sufficiant to deliver very clean sounding bass for music. Maybe two for big rooms. No need to spend tons on an LMS5400
How's the SDX15?.
Since they just started shipping a week or so ago, no ones had one long enough to get any testing done on it. Theoretically it should be a very good driver and thus the reason why I will be using two in my HT system.
YID DIY
Looneybomber is offline
post #21 of 109 Old 06-10-2007, 09:03 AM
Rythmik's Avatar
Quoted: 446 Post(s)
Liked: 737
Originally Posted by TheEAR View Post
xxxxxx can sound darn good when installed in a proper cabinet and with the correct filters applied.
EAR,
I know you have a lot of expericence. But I think you also would agree that above quote has too often become the escape goat for driver manufacturers (explain why the driver does not sound good). We have never done that. And to be honest, anyone should be surprised why our kits are so "consistent" in many different rooms, cabinets, and systems. Of course, we are selling a solution, not a piece in a solution. That is main difference.
Brian
Rythmik
Rythmik is offline
post #22 of 109 Old 06-10-2007, 01:32 PM - Thread Starter
jxo
jxo's Avatar
Cheers KG
KG: thanks for looking at this. My mains are custom: Focal audium T5 tweeter with 2 PHL 1240 in MTM design. box= 12x24x8 (ported). Use an ARC tube amp (Classic 60). Very detailed/revealing tweeter, so I am a little nervous about the quality of any high pass that I use to integrate. I sit around 10 feet away. Listening room size noted above.
Jim
jxo is offline
post #23 of 109 Old 06-10-2007, 05:55 PM
kgveteran's Avatar
Quoted: 837 Post(s)
Liked: 246
KG: thanks for looking at this. My mains are custom: Focal audium T5 tweeter with 2 PHL 1240 in MTM design. box= 13x33x16 (ported). Use an ARC tube amp (Classic 60). Very detailed/revealing tweeter, so I am a little nervous about the quality of any high pass that I use to integrate. I sit around 10 feet away. Listening room size noted above.
My favorite sub wasn't a sub at all. I got my hand on some 6.5" B&W woofers.I think they were the ones that went in the 601 series, yellow kevlar. I mounted four in a sealed enclosure.There were two separate cabinets.They were powered by a Nakamichi PA7 in stereo.The key was the gentleman was using smallish twoways with some Golden tube SE40's.What a pair.The sealed woofersystem probably never was able to go much lower than 35hz, but for music they were the bomb.We use a Creek headphone preamp as a remote volume.perfect.We just "Y" jacked out of the preamp.Never was it part of the systems pathway, just an add on.
KG
post #24 of 109 Old 06-10-2007, 08:07 PM - Thread Starter
jxo
jxo's Avatar
KG
... well that was a lot of help.
Jim
jxo is offline
post #25 of 109 Old 06-11-2007, 06:57 AM
kgveteran's Avatar
Quoted: 837 Post(s)
Liked: 246
I just found that woofers make a better transition than subs in some applications.
I like to do four RS225's in a sealed box.Two forward two backward.You would need two separate enclosures.They don't have the most Xmax, but would blend better.
Or just get a SVS PB12.
post #26 of 109 Old 06-11-2007, 07:01 AM
tf1216's Avatar
How about an underhung motor subwoofer from ATC? If you check out diyaudio.com you will find some interesting results there.
tf1216 is offline
post #27 of 109 Old 06-11-2007, 10:37 AM
jjw350z's Avatar
JL W6 ... new model.
Audiomobile MASS2012
Aura NRT (12")
Peerless XXLS
Seas Lotus 12"
ACI Titan
Jim
jjw350z is offline
post #28 of 109 Old 06-12-2007, 09:14 PM
Quoted: 1333 Post(s)
Liked: 769
Sorry, the TC3k has too much inductance to have any role in a serious music system. Might be fine to boom around with, for rattling your bones on synthetic explosions. But that nasty and amusical old 3HP motor, even updated with shorting rings, is just not for serious music listening.
Some drivers not mentioned on this thread that are worth considering are the JBL W15GTi, McCauley 6174, and (barely mentioned) the 15" and 18" Aura NRT-based drivers.
In that volume, for music listening with smallish mains and if I had to pick one driver, I'd probably go with the W15GTi because it's cheaper than the Auras, though the new Creative XBL^2 driver might get the nod just because it's something I haven't yet played with.
But what I'm actually doing for a similar preferences (sub designed to mate with superior mains, with high-fidelity reproduction of live acoustic music as the primary consideration by far, only difference being it is a system designed for multichannel music) is using three Peerless XLS12's with their matching PR's in ~105L of cabinet volume. The cabinet I've commissioned (six sided, with the woofers firing 60deg from each other to balance the internal forces) would exceed your height criteria, so if you must do a rectangular box I'd consider upping the volume to 4.5 cubic feet and running four of them instead of threee. Multiple motors mean less excursion at typical listening levels for greater linearity and subjective dynamic "ease."
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #29 of 109 Old 06-13-2007, 01:56 AM
Vinculum's Avatar
Quoted: 13 Post(s)
DS-21,
Any opinions on the newer XXLS drivers from Peerless?
The McCauley is interesting as it is a prosound driver with a neo motor - a very exclusive club! Not to mention a very low mms.
If the W15GTi wasn't so damn gaudy looking... that poor driver!
Your project is interesting. Didn't you once mention that the high $$ Genelec subs use these same Peerless drivers?
Dr V
Scratch that. I thought the 6174 was using a neo motor for some reason? I must have been thinking of the Bassmaxx drivers...
Vinculum is offline
post #30 of 109 Old 06-13-2007, 02:00 AM
armystud0911's Avatar
Do you have any experience with the TC3k? I know Aurther likes them more than his F113's in every aspect, and the F113's sound very good, by pretty much anyone's standards.
armystud0911 is offline
