sonotube purveyors in the Maryland/Metro DC area? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-26-2007, 01:00 PM - Thread Starter
ZiZou's Avatar
Anyone know of where I can get my hands on a sonotube in the DC metro area for subwoofer making?
Many thanks for any and all suggestions!
ZiZou is offline
post #2 of 15 Old 07-26-2007, 05:33 PM
Warpdrv's Avatar
Call a concrete dealer in your area, they will know...
Warpdrv is offline
post #3 of 15 Old 07-26-2007, 05:50 PM
nichol1997's Avatar
I can't find the receipt for the place where I bought mine. It was in Sterling VA at some building supply store and they had a lot of this stuff (all different sizes). Email www.sonotube.com and they will send you a list of stores in the area. As I recall there were several.
nichol1997 is offline
post #4 of 15 Old 07-26-2007, 06:15 PM
Gir_1337's Avatar
If ya wanna drive 2-3 hours I have some in Hershey, PA 17033. I'll sell ya 24" x 7' for $60 (cost me $141 for 12')
Gir_1337 is offline
post #5 of 15 Old 07-27-2007, 07:52 AM - Thread Starter
ZiZou's Avatar
Thanks for the tips guys!!!! My friend in construction just told me that he thought that home despot had some in stock. I'll give that a shot tonight or over the weekend!
@Gir - if you stick some end caps on it, and a driver into it I'll take it for $60!!!
ZiZou is offline
post #6 of 15 Old 07-27-2007, 09:34 AM
BoomieMCT's Avatar
The Home Depot's I check in the NoVa area do not carry sonotube. They have up to 12" "Quiktube" which is much thinner.
BoomieMCT is offline
post #7 of 15 Old 07-27-2007, 10:08 AM - Thread Starter
ZiZou's Avatar
Yeah - I've seen that QuickTube. Looks waaay too light to support end caps and a driver. Would probably crumple when placed on end.
I'll email sonotube then!
ZiZou is offline
post #8 of 15 Old 07-27-2007, 10:50 AM
BoomieMCT's Avatar
There was a place in Woodbridge I went to. I believe it was Wharton Supply. I can't seem to find the web page right now.
post #9 of 15 Old 07-27-2007, 12:10 PM - Thread Starter
ZiZou's Avatar
Thanks for the tip! I just did a quick run to the home despot near the office and they have a 4' tall x 16" diameter "sakrete" concrete form tube with probably 5-7mm thick (what's that about a 1/4 inch?) tube. The sakrete is *much* heavier and more robust than the "quiktube" I found in Lowe's. Probably weighs 20 lbs or so.
ZiZou is offline
post #10 of 15 Old 07-27-2007, 12:33 PM
BoomieMCT's Avatar
Which HD is this and how much was it?
post #11 of 15 Old 07-27-2007, 01:33 PM - Thread Starter
ZiZou's Avatar
Off Oxon Hill Rd. go west from exit 4b on 495, and it's on your right.
You any good at cutting end caps? I am worried about my circle cutting abilities!
This link will help...
http://www.homedepot.com/webapp/wcs/...ce_2=50&store=
ZiZou is offline
post #12 of 15 Old 07-27-2007, 01:48 PM
BoomieMCT's Avatar
There are attachments for a router that help you cut big circles - similar to the Jasper jig just bigger. With the right tool it is a piece of cake.
post #13 of 15 Old 07-27-2007, 08:54 PM
nichol1997's Avatar
Here is the circle jig that I bought at the Rockville Woodcrafters: http://www.woodcraft.com/family.aspx?familyid=3172
Worked perfect, really easy once you get the correct setting.
The home depot near me sells the 16" diameter tube as well, nothing bigger though.
post #14 of 15 Old 07-27-2007, 09:27 PM
nichol1997's Avatar
It has been bugging me for several days now so I gave a more thorough search for the receipt and I found it. The place is called Sheets Wholesale 22293 Shaw Road in Sterling VA, 703-450-4823. I will be surprised if this place doesn't have what you need.
post #15 of 15 Old 07-27-2007, 11:47 PM
Gir_1337's Avatar
If you check out my sonosub thread, at the bottom of the first page you can see the $8 jig I used to cut the end caps with a jig saw. We couldn't find the router base for use with a jig (of course we find it when the project is done with...), so we just made a little extension for a $8 jig at HD and got perfect circles.
NOTE: if you use a jig saw, make sure you get a thick blade, otherwise it will bend and try to cut in a straight line. Also try to get one with bigger teeth, that seemed to help a bit.
Gir_1337 is offline
