Looking for TS paramaters for Ascendant Assassin 12" ... - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Uklit
  • 1 Post By Scott Simonian
post #1 of 4 Old 01-02-2008, 12:23 PM - Thread Starter
CFC
CFC's Avatar
Quoted: 62 Post(s)
Liked: 30
Hey guys,
I bought an older 12" ascendant assassin, and thought I had a link with its T/S parameters, but can't seem to find it.
Would any of you know where I can obtain them? This is for the older version (I believe they've been updated recently).
Thanks for the help,
CFC
Signature goes here
CFC is online now
post #2 of 4 Old 01-02-2008, 12:39 PM
Uklit's Avatar
Znom 4 ohms
BL 12.3 n/a
Re 3.5 ohms
Sd 480 cm2
Qes .41
Qts .372
Qms 4.00
Fs 23.1 Hz
Mms 122 g
Vas 128 L
Xmax 15.5 mm
Le 3 mH
Rms 350W
Spl 87.8 dB 1W/1M
Voice Coil diam. 2 inch aluminum
Voice coil Single 4 ohm
Cone Paper pulp
Cutout diam. 11
Outer diam. 12 3/8
Mounting depth 6 1/8
Weight 15 pounds
CFC likes this.
Uklit is offline
post #3 of 4 Old 01-02-2008, 12:39 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5985 Post(s)
Liked: 5114
Not sure if these are the updated T/S specs but I think I got them when they were first posted.
Fs 23.1hz
Re 3.5ohm
Qms 4
Qes .41
Sd 480cm^2
Vas 128 liters
Xmax (one way) 15.5mm
Le 3mH
Power rated @ 350w RMS
Hope that helps. *EDIT* Ahh, nevermind Uklit got them a bit more covered than mine.
CFC likes this.
Scott Simonian is offline
post #4 of 4 Old 01-02-2008, 01:01 PM - Thread Starter
CFC
CFC's Avatar
Quoted: 62 Post(s)
Liked: 30
Thank you!
Hey at least your numbers match confirming each other.
I appreciate it,
CFC
Signature goes here
CFC is online now
