Need help putting together an outside thearter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-10-2018, 02:36 PM - Thread Starter
NickB123's Avatar
Quoted: 61 Post(s)
Liked: 26
Hi -
I would really like to sit outside with the kids and watch classic movies next summer. To do it I know I will need a projector ($1,000 or less), but what else?
I have a TiVo Bolt, Denon 4300H Heos AVR and two Omni directional Tic GS 's that are in ground out by the pool (where I want to watch movies) and hard wired to the AVR via Zone 2. Basically I can play anything from the Tivo on the outdoor speakers....
The question is, how does this all go together? How do you guys pull it off?
Any help would be appreciated,
Nick
NickB123 is offline
post #2 of 6 Old 12-10-2018, 03:56 PM
b curry's Avatar
Quoted: 1067 Post(s)
Liked: 678
Originally Posted by NickB123 View Post
Hi -
Nick
It's the same check list as an indoor theater or a TV. You need a display/projector, a sound system, and a source. The difference is that it's set up outside.
This is a great place to start for a projector and screen.
https://www.visualapex.com/projector...ectoScreen_144
You need to decide what you want for a sound system. What you've listed should work ok. Sound systems range from a single monaural speaker, to stereo, streamed to headphones/small radios, and full 5.1 or 7.1 surround systems.
Questions to ask yourself are how much do you want to spend, do you want it to be portable and how portable, or a fixed installation.
b curry is online now
post #3 of 6 Old 12-10-2018, 05:57 PM
recoveryone's Avatar
Liked: 33
Here is a break down of my system
Family main setup:
Pioneer Elite SC LX502/BDP Pioneer Elite 85FD/Logitech Touch
Pioneer Elite N50/Cassette Pioneer M66R/
Panamax M5300 EX/TV Vizo UHD P55-E1
recoveryone is offline
post #4 of 6 Old 12-11-2018, 07:30 AM - Thread Starter
NickB123's Avatar
Quoted: 61 Post(s)
Liked: 26
Thanks for the reply. I guess what I really need to find out is if there is a projector that can connect to a Tivo Bolt wirelessly and if so, can video go from the Tivo to the projector while the audio goes to the AVR?
NickB123 is offline
post #5 of 6 Old 12-11-2018, 02:31 PM
b curry's Avatar
Liked: 678
IOGEAR Wireless HDMI Digital Kit model number GW3DHDKIT or GW4K30KIT
The transmitter will accept two inputs with a pass through. Plug the Tivo HDMI into the transmitter with the pass through to the AVR. Attach the IOGEAR receiver to the projector HDMI input. Voilà! HD video to the projector and HD audio to the AVR.
Here's a link to IOGEAR. You can buy them at Best Buy, Amazon, etc.
https://www.iogear.com/product/GW3DHDKIT/
post #6 of 6 Old 12-11-2018, 02:35 PM - Thread Starter
NickB123's Avatar
Quoted: 61 Post(s)
Liked: 26
Thank you! I will investigate this ASAP!!
NickB123 is offline
Reply Outdoor Theaters
directional
