Mounting TV outdoors in brick? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-04-2019, 06:40 PM - Thread Starter
relentless85's Avatar
Has anyone had any experience in mounting a TV to an outdoor brick wall? I am wanting to install one on my back patio. IÂ’m getting different answers on how/what to use to anchor the mount to the wall.
The TV size would be 40 inches or larger.
Mounting it directly to the brick seems like a stronger material to mount a TV to. I am very leary about mounting it to the brick mortar, seems like the mortar is not as strong and the anchors would pull out easily.
I have used the blue tapcon masonry screws in concrete but not brick before. Anytime I have tried to use the tapcons in mortar they just strip out and donÂ’t hold. So I havenÂ’t had that great of luck with the tapcon anchor screws. I am considering a sleeve anchor directly into the brick since I have not had good luck with the tapcons. I would hate to drill a hole in the brick and have the tapcons come back out.
Looking for advice on how I can mount the TV without it falling. Where to anchor it and whatÂ’ anchors to use.
relentless85 is offline
post #2 of 3 Old 08-05-2019, 03:46 PM
b curry's Avatar
Quoted: 1067 Post(s)
Liked: 678
Use "Red Head" brand anchors. Drill and mount to the brick not the mortar.
b curry is online now
post #3 of 3 Old 08-05-2019, 08:27 PM - Thread Starter
What diameter and length do you recommend? I want to mount a 40-50 inch tv on a tilting mount.
Reply Outdoor Theaters
