FM Transmitter rexommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-18-2019, 09:34 AM - Thread Starter
Liked: 0
My lot is about a third of an acre and I have a 170 inch outdoor screen in my backyard. For now, my basic solution for my audio is that I would like an FM transmitter that I can connect to the audio out out on my projector so that I can broadcast to the stereo boom box that I have out in my yard. Eventually, I would like dedicated outdoor speakers, but that's an upgrade for next Spring.
What FM transmitter that provides clean audio broadcasting for up to 25-30 yards would you recommend? Thank you!
MovieYard86 is offline
post #2 of 3 Old 09-19-2019, 06:40 AM
b curry's Avatar
Quoted: 1067 Post(s)
Liked: 678
I don't have personal experience using it, but the Whole House FM Transmitter is a popular unit, seems to work well, and gets good reviews for a reasonable price.
There used to be a Backyard Theater forum elsewhere on the internet and the Whole House FM Transmitter was kind of a go to unit. It was popular to encourage people to bring a transistor radio with them and use it kind of like the window hanging speakers Drive-In's used for audio.
People also use the Whole House FM Transmitter to broadcast music with Christmas yard light displays too. You can find reviews and see it being used on YouTube.
https://wholehousefmtransmitter.com/
b curry is offline
post #3 of 3 Old 09-26-2019, 06:36 AM
Liked: 5
I have the one below and use it for my Christmas Projector display.
Signstek 0.5 W 05B Dual Mode Long Range Stereo Broadcast Home FM Transmitter with Antenna and Free Audio Cable Fashion Black (Amazon)
It is awesome and you can adjust the power... It easily will do 1/4 circle- and I have picked it up over a mile away.
You will want to control the power and only use the amount you need the FCC allows these- but for a limit of about 100 yards.
I have also used it in my Harley to broadcast music so all the motorcycles could play the same music in a parade.
[email protected] is offline
Reply Outdoor Theaters
