Using an Indoor LED - Outdoor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-25-2019, 04:45 PM - Thread Starter
Liked: 5
Unhappy Using an Indoor LED - Outdoor
Hi
I'm a newbie - but have been listening to Scott Wilkinson for years on the Tech Guy Podcast. I need advice please...
We had a 50 * LED HDTV mounted on a heavy tripod- that we move in and out. We watch it on our deck- and may leave it out a few days- but when weather is inclement or we will be away for a few days we bring it in- carrying it still attached to the tripod. In less than 30 days cracks appeared on the sceen and the TV died.
Was it likely a bad TV??? or as I suspect- the frequent stress of moving? (The Mount we use is below)
I am getting a new TV? Can I do this a better way? Or not with an indoor TV? We do have a cover to use when we leave it out at night.
Sheepishly...
[email protected] is offline
post #2 of 2 Old 10-01-2019, 01:01 PM
drballard33's Avatar
I would suspect the constant moving inside and outside did this. The TV's are getting lighter and lighter which means the plastic on the back and around the TV is getting thinner and thinner, thus its bending as you pick it up and bring it in. I would imagine this would happen overtime with almost any indoor rated TV in an outdoor setting. I'm not sure where you are located but the outdoor temps and humidity may also pose issues as it could weaken the plastic over time in addition to if the wind is causing the TV to move back and forth further bending it enough to crack it...but that's just a guess. When you are picking it up to move it are you picking it up by the tripod or the TV itself? Its possible if your picking it up by the tripod that's whats causing it to bend as well and would suggest picking it up by the TV itself. Another suggestion may be to beef up the TV mount where it connects to the TV by possibly using some metal to create a square box so it doesn't bend the plastic backing. All just a few guesses. Outdoor TV's are expensive so I understand the idea of using a lower cost indoor one (I am sure someone will be critical and say you should never use one outdoors), but is it possible you can build a box that it could go in permanently with some vents to allow heat to dissipate?
drballard33 is offline
Reply Outdoor Theaters
inside tv outdoors; broken screen
