Need some help for Outdoor Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-13-2020, 11:18 AM - Thread Starter
dja2k's Avatar
Quoted: 12 Post(s)
We have a large shed outside that we've been using a small 55" TV to show games and movies in the day or night. We want to upgrade to something bigger but not break the bank. So we were thinking either a cheap 75" TV or a go with Projector setup. The shed is open on all 4 sides so in the afternoons, there is a lot of light out there. Can someone help as to what would be the best thing to use, thanks.
Panasonic 65" 1080P Plasma, Onkyo TX-NR656
Bic Acoustech (2 PL-89 Fronts, 1 PL-28 Center,
4 PL-66 Side & Rear Surrounds, 2 PL-200 Subs)
dja2k is offline
post #2 of 3 Old 01-14-2020, 07:09 AM
b curry's Avatar
Quoted: 1100 Post(s)
Liked: 706
In your situation, go with a TV. Outdoors with daylight/sunlight just doesn't work with a projector. It's like bringing a knife to a gun fight. A 75"-85" LED/LCD TV will produce a much better picture for you during the daylight hours.
A projector outside really doesn't work well until 20-30 minuets after sundown. A projection screen reflects light to work and with sunshine coming in all directions during the daylight hours, the little lamp on a projector is no competition for the sun. You could close in the shed to control the light, but that really negates the reason to be outside.
b curry is offline
post #3 of 3 Old 01-14-2020, 10:54 AM - Thread Starter
dja2k's Avatar
Quoted: 12 Post(s)
Got it and thanks for the reply!
dja2k is offline
Reply Outdoor Theaters
