Covered Patio TV Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-12-2020, 10:38 AM - Thread Starter
azzaba's Avatar
Hello everyone. We are currently putting a roof over our existing patio. See images attached (the hand sketch is the new design for the fireplace wall). My question relates to the TV. We were going to put two (2) TV's out there and the Sunbrite TV's are extremely expensive in comparison to other OLED TV's I can buy from a big box store. My question is whether the Sunbrite is really worth it? As you can see from the drawings, the roof will be covering the TV and it really will not be exposed to rain, etc. Any thoughts are welcomed!
ID:	2684004   Click image for larger version
Name:	Azzara 12.5 3d kitchen.jpg
ID:	2684006   Click image for larger version
Name:	Azzara 12.5 3d fireplace.jpg
ID:	2684008   Click image for larger version
Name:	Azzara 12.5 3d2.jpg
azzaba is offline
post #2 of 3 Old 02-12-2020, 01:45 PM
b curry's Avatar
Quoted: 1297 Post(s)
Liked: 835
If it doesn't rain sideways you're probably ok. Usually with the standby power on the units stay dry. There are a lot of sports bar's with covered patio bars using LCD TV's with out Sunbrite or Sunbrite type enclosures.
Another option is to use a mount that will allow relatively quick or easy removal of the unit if you're not using it for an extended period of time or you run into extremely bad weather.
b curry is offline
post #3 of 3 Old 05-18-2020, 08:18 PM
Liked: 0
What is your final decision? From the drawing, it looks ok. I am recently designing my backyard. I'm going to put my 55inch TV out there, but I don't have a good roof like yours. I have to get a cover to it.
michealKT is offline
Reply Outdoor Theaters
